Unable to Create Map: Story Map Templates on Portal
7212
11
08-13-2013 05:53 AM
JohnReynolds2
I've already successfully created a Playlist story map site from template files.  But I can't seem to get the slider, or the map tour playlists configured correctly.  The map ID works, I've used the working map id, I've copied over the sharing service url, and the geometry url.  I've tried it with or without authorized users, with or without titles and subtitles, with or without multiple map ids, and I've made a successful ArcGIS Online slider version with the online story map template.  Any ideas?
JosephJose
Not sure if my organization will allow a portal deploy
But I will give it a try and see if there are improvements. And like you said, I will have to wait for certain strange timings to get it. Revert back to you then.
Thanks once again
GregoryL_Azou
You are welcome. You won't need to deploy a Portal, you can continue to use the webmap you have created in ArcGIS Online with the downloadable. You just have to deploy it on a web server...
