Topographic and zoom to imagery
1150
06-09-2017 05:57 AM
SteviKosloskey
Hello,
I was wondering how to have a basemap in a story map be topographic, but then when zooming in to the map it changes to imagery? I am unable to find where to do that in the map or the story map app settings. This is an example, it starts as gray canvas, but when you zoom to a certain point it changes to imagery.
A selection of Frank Lloyd Wright buildings
Thanks for the help!
~Stevi
Tags (3)
JayantaPoddar
You could do it in ArcGIS Online while creating a map.
http://www.cloudpointgeo.com/blog/2016/4/26/creating-a-multi-layer-basemap-in-arcgis-online
Add the other basemaps from http://server.arcgisonline.com/arcgis/rest/services
Do not Check "Use as BaseMap"
b1
Keep the Options under the layer > Move to Basemap
b2
Set visibility range for every basemap layer
b3
Rename the Basemap layer, as desired.
b4
Then you could save and share the map to web appbuilder or a story map.
Think Location
JayantaPoddar
b1
b2
b3
b4
Think Location
SteviKosloskey
This was exactly what I was looking for! Thank you so much for your help!
