Story Map tour - Basemap gallery/toggle
4754
6
04-20-2015 11:29 AM
ShruthiSrinivasan1
Does the Story map tour template have an option to add a basemap gallery or basemap toggle?
Tags (1)
ShruthiSrinivasan1
If the map tour template does not have that option, can the customization be done in the user downloadable archive?
Thanks.
OwenGeo
Esri Notable Contributor
Hi Shruthi,
Map Tour doesn't currently support a basemap picker, but you could add one in the downloadable version of the app. I believe the easiest way would be to use the Basemap dijit included in the ArcGIS API for JavaScript (Documentation here).
Before adding an additional widget to the app, however, we'd recommend having a solid justification of the value it will provide to your audience. Adding too many options can sometime confuse more than help. That being said, there are reasons to add additional basemap choices, but we'd recommend limiting the number of basemaps to the two or three most useful ones.
Another thing you could do (without customization and hosting the app yourself) is to put a scale dependent basemap in your web map to switch the basemap automatically for your viewers. For example, you could use the NatGeo basemap at small scales for reference but switch on the imagery basemap at large scales to get more local detail.
Owen
Owen Evans
DarrylKlassen1
Hi Shruthi,
Have you found a way to do this?  I am looking to do the same thing?
Thanks
Darryl
BrandonPrice
Hey Darryl,
Were you able to solve this? I would like to do this with the story map series.
-Brandon
DarrylKlassen1
No, I don't think it possible without customization of the code - i.e. we weren't able to figure out how to do it with the default template on AGOL.
BrandonPrice
No problem. Thanks for getting back to me.
-Brandon
