I'm trying to set my initial extent in Story Map Swipe and Spyglass so I can embed it in another story map. However, every time I set the extent and then reopen the story map it reverts back to the original extent.
BEGIN
SET NEW EXTENT and APPLY TO MAP
APPLIES TO MAP
SAVED AND REFRESH AND RETURNS TO ORIGINAL EXTENT
I am having this problem too! Has anyone figured out a solution?
Anyone found a solution yet? This appears to be a consistent problem!
Unfortunately no, I haven't heard or seen anything. I also haven't used the swipe app in quite in sometime either.
Good Morning
This problem still persists.
I am having the same issue. The Swipe Map does not honour the extent set on the web map.
Regards.
Jeremy.
