Story Map Short List
635
05-19-2022 01:24 PM
JohnKuhn
I created a web map from a gpx file and now I want to create a Story Map Short List.  I've created a web map, but when I click on web application and story map I don't see Short List template which I  can choose.  Appreciate any help.
John
OwenGeo
Esri Notable Contributor
Hi John -- The classic story map templates went into extended support in September 2021 and were removed from the default template gallery in December 2021. It's recommended that you use ArcGIS StoryMaps for all new projects. The explorer tour block of ArcGIS StoryMaps is similar to the classic Shortlist template.
However, the classic templates are still available if you have a short-term need to use one of them. For more information see:
Owen Evans
