Story map "issues" are fixed, but still says there are "issues"
4260
10
05-10-2016 10:02 AM
deleted-user-wgzH2d-p_0_f
New Contributor III
Hello All,
I have a tabbed story map that I've created in the Map Series Builder.  We had some issues with a server going down, so all of our stuff needed to be re-served.  I've fixed all of the rest services URLs, and made sure the maps display correctly.  However, when I go to my story map, it says that I have issues that need to be fixed.  My layer draws correctly, but in the issues window, the layer is "inaccessible."  I've tried to remove the map and re-add it, but there are still issues with the layer.  I suspect that something is hidden, but I don't know how to fix the issue!  (See the attached screen shot for clarification).  To reiterate--the layer is showing on the screen as it should.
HELP!
annina
RyanColeman
It would be helpful if the error message suggested http/https as the possible reason why its inaccessible.
