Story Map Journal Navigate to Section highlight feature on Map ?
694
09-17-2018 02:02 AM
MayurDodiya
HI,
I have created story map Journal using Portal for ArcGIS 10.5.1, I then downloaded templates from here Story Map Journal GitHub and deployed in my web server, it is working.
Now, in 0 index section I have roads name and set navigate section for each so clicking on roads name it navigate to section & map Zoom in to the location, Now I also want to highlight feature on Map when you navigate to that section.
How can I highlight feature(polygon )on map when I navigate to section ?
Thank you.
Tags (1)
OwenGeo
Esri Notable Contributor
To highlight a feature on the map map you can pick Custom Configuration for your pop-up display settings. Choosing this will then let you pick a feature on the map to display when readers navigate to that section.
Owen Evans
OwenGeo
Owen Evans
