Story Map Journal Issue
1774
8
01-19-2017 11:27 PM
MiraEl-Koussa
Greetings,
I am working on a Story Map (Journal). It was working fine. Now I am getting the error below in red on two feature layer.
Also, the Story is public and all the web maps & items inside the story map are public. However, whenever I try to view the story, It asks to enter username & password.
Any idea ??
Appreciate your help.
Secure services
Tip: Remove the secure service from your story or follow the procedure described here.
MiraEl-Koussa
Problem solved.  I should have updated the sharing of the services after federating the server with the portal.
AdrianWelsh
MVP Honored Contributor
Mira,
Can you post the link to the story since it is public?
AdrianWelsh
MiraEl-Koussa
Im using Portal for ArcGIS and not ArcGIS online
AdrianWelsh
Oh, good point
https://community.esri.com/community/gis/web-gis/portal-for-arcgis?sr=search&searchId=b65f627e-160b-...
So maybe it is not related and it could be a portal issue.
Are you able to access other maps from Portal?
MiraEl-Koussa
It seems that I have published two layers as " secure service" .. when I have removed those layers, it worked fine without log in ! do u have any idea if i can remove this security from ArcGIS for Server without the need to republish again ??
MiraEl-Koussa
AdrianWelsh
I am glad that you resolved the problem and were able to find where the issue was. You should mark your reply as answered so that this thread can be closed out.
