Greetings,
I am working on a Story Map (Journal). It was working fine. Now I am getting the error below in red on two feature layer.
Also, the Story is public and all the web maps & items inside the story map are public. However, whenever I try to view the story, It asks to enter username & password.
Any idea ??
Appreciate your help.
Secure services
Tip: Remove the secure service from your story or follow the procedure described here.
Solved! Go to Solution.
Problem solved. I should have updated the sharing of the services after federating the server with the portal.
Mira,
Can you post the link to the story since it is public?
Maybe it's a bug with ArcGIS Online story maps. There was another issue of this earlier today:
https://community.esri.com/thread/188907-public-story-map-asking-for-login
Im using Portal for ArcGIS and not ArcGIS online
Oh, good point
So maybe it is not related and it could be a portal issue.
Are you able to access other maps from Portal?
It seems that I have published two layers as " secure service" .. when I have removed those layers, it worked fine without log in ! do u have any idea if i can remove this security from ArcGIS for Server without the need to republish again ??
I am glad that you resolved the problem and were able to find where the issue was. You should mark your reply as answered so that this thread can be closed out.
