Story map image filling available space
740
10-19-2016 03:33 PM
MattO_Keeffe1
I have a story map which I'm authoring point by point in AGOL.  The images I'm adding to the story map are great but when I view the story map either on my computer or on a device the images don't fill the available space in the 'image' section of the page.  I'm ending up with grey wasted space around the image as the page tries to preserve the aspect ratio of the photo.  I could change the pixel height and width to accommodate but that won't work particluarly well as the map will be loaded on different devices, etc.  Is there a way I can force the image (and subtitle text/description) to 'fill' the available space in the image area?
OwenGeo
Esri Notable Contributor
Hi Matt,
The answer depends on which story map app you are using. A list is here.
Could you let us know which one you've chosen for the story you're working on and/or share a link to or screenshot of your story?
Owen
Owen Evans
