Story Map Basic doesn't show up
1366
01-18-2022 06:57 AM
StephanieGrady
I'm just trying to share my ArcGIS online webmap to a basic Story Map, but the option to build a Story Map is not showing up under "Create a Web App". Has anyone run across this issue?
Thanks!
OwenGeo
Esri Notable Contributor
Hi @StephanieGrady! - The classic Esri Story Maps templates are in Extended support and Story Map Basic is in Mature support. All of these apps have been removed from the Esri default template gallery.
Please see the articles below for more information and the previous announcements about these changes.
As mentioned in the first article, the current "Basic" configurable app is the recommended alternative for the Story Map Basic.
Owen Evans
OwenGeo
Owen Evans
StephanieGrady
Thank you so much!!
