I've recently added a fifth color to the markers in my maptour. The markers look fine, but the the background color behind the number of the thumbnail photos in the carousel aren't showing for the new colour, orange. I went in to maptour-config.css and changed what I think this thread was suggesting.
you can change the font-color in the carousel for each class in the maptour-min.css.
For example to change the font color for class 1, add:
#organizePopup .number-class1{background-color:#003d00;color:#YOURCOLORHERE}
I have a link to my repo here, hopefully someone can take a look? my maptour repo
Snippet of what I changed here
.numberLabel{background-color:red;width:20px;height:20px;position:absolute;top:5px;left:5px;text-align:center;color:#fff}#organizePopup .number-blue{background-color:#1880f3}#organizePopup .number-red{background-color:red}#organizePopup .number-green{background-color:#369A22}#organizePopup .number-purple{background-color:#8A26FD}#organizePopup .number-orange{background-color:#e67e22}#organizePopup
Cheers, Lindsay (screenshot of the issue below)
good point Adrian, that the change must be made somewhere else in the script. I did a search of one of the colors and then based off of that looked for where a fifth colour was missing, copy and pasted a line to make a fifth one and substituted in the color code for orange. all good now!
Lindsay,
A couple of things. In your screenshot, it looks like the orange is showing up. Is this not what is supposed to happen? Also, this may make no difference, but have you tried capitalizing all of the letters (to make it #E67E22)?
Hi Adrian,
I've changed it to #E67E22, but no change.
Below the boxes in red are what I am referring to. See 1 and 2? They have a green background like their markers on the map. 3, 4, and 5, don't have orange backgrounds on the thumbnails, but should.
Let me know if you have any ideas or if you figure it out you can send through changes to the repo.
Oh, I get it now. That makes more sense. I am guessing the changing of the color must happen somewhere else which is why it isn't being picked up.
Would it be possible for you to copy and paste more of your code from your CSS and format it a little more code-block-like (to make it more easily readable)? And then use the syntax highlighter in order for the code to be more color-coded (also making it more readable)?
(to get to the syntax highlighter, click on "Use advanced editor" in blue in your post reply, then click on the ellipses (...), then "More", then Syntax highlighter)
Hi Adrian, you can find it in my maptour repo, or as you've asked, below:
*/.slider{display:inline-block;vertical-align:middle;position:relative}.slider.slider-horizontal{width:210px;height:20px}.slider.slider-horizontal .slider-track{height:10px;width:100%;margin-top:-5px;top:50%;left:0}.slider.slider-horizontal .slider-selection{height:100%;top:0;bottom:0}.slider.slider-horizontal .slider-handle{margin-left:-10px;margin-top:-5px}.slider.slider-horizontal .slider-handle.triangle{border-width:0 10px 10px;width:0;height:0;border-bottom-color:#0480be;margin-top:0}.slider.slider-vertical{height:210px;width:20px}.slider.slider-vertical .slider-track{width:10px;height:100%;margin-left:-5px;left:50%;top:0}.slider.slider-vertical .slider-selection{width:100%;left:0;top:0;bottom:0}.slider.slider-vertical .slider-handle{margin-left:-5px;margin-top:-10px}.slider.slider-vertical .slider-handle.triangle{border-width:10px 0 10px 10px;width:1px;height:1px;border-left-color:#0480be;margin-left:0}.slider input{display:none}.slider .tooltip-inner{white-space:nowrap}.slider-track{position:absolute;cursor:pointer;background-color:#f7f7f7;background-image:-moz-linear-gradient(top,#f5f5f5,#f9f9f9);background-image:-webkit-gradient(linear,0 0,0 100%,from(#f5f5f5),to(#f9f9f9));background-image:-webkit-linear-gradient(top,#f5f5f5,#f9f9f9);background-image:-o-linear-gradient(top,#f5f5f5,#f9f9f9);background-image:linear-gradient(to bottom,#f5f5f5,#f9f9f9);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff5f5f5', endColorstr='#fff9f9f9', GradientType=0);-webkit-box-shadow:inset 0 1px 2px rgba(0,0,0,.1);-moz-box-shadow:inset 0 1px 2px rgba(0,0,0,.1);box-shadow:inset 0 1px 2px rgba(0,0,0,.1);-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px}.slider-selection{position:absolute;background-color:#f7f7f7;background-image:-moz-linear-gradient(top,#f9f9f9,#f5f5f5);background-image:-webkit-gradient(linear,0 0,0 100%,from(#f9f9f9),to(#f5f5f5));background-image:-webkit-linear-gradient(top,#f9f9f9,#f5f5f5);background-image:-o-linear-gradient(top,#f9f9f9,#f5f5f5);background-image:linear-gradient(to bottom,#f9f9f9,#f5f5f5);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fff9f9f9', endColorstr='#fff5f5f5', GradientType=0);-webkit-box-shadow:inset 0 -1px 0 rgba(0,0,0,.15);-moz-box-shadow:inset 0 -1px 0 rgba(0,0,0,.15);box-shadow:inset 0 -1px 0 rgba(0,0,0,.15);-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box;-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px}.slider-handle{position:absolute;width:20px;height:20px;background-color:#0e90d2;background-image:-moz-linear-gradient(top,#149bdf,#0480be);background-image:-webkit-gradient(linear,0 0,0 100%,from(#149bdf),to(#0480be));background-image:-webkit-linear-gradient(top,#149bdf,#0480be);background-image:-o-linear-gradient(top,#149bdf,#0480be);background-image:linear-gradient(to bottom,#149bdf,#0480be);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff149bdf', endColorstr='#ff0480be', GradientType=0);-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);-moz-box-shadow:inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);box-shadow:inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);opacity:.8;border:0 solid transparent}.slider-handle.round{-webkit-border-radius:20px;-moz-border-radius:20px;border-radius:20px}.slider-handle.triangle{background:transparent none}/*!
* Bootstrap v2.3.2
* Copyright 2013 Twitter, Inc
* Licensed under the Apache License v2.0
* http://www.apache.org/licenses/LICENSE-2.0
* Designed and built with all the love in the world @twitter by @mdo and @fat.
*/.clearfix{*zoom:1}.clearfix:before,.clearfix:after{display:table;content:"";line-height:0}.clearfix:after{clear:both}.hide-text{font:0/0 a;color:transparent;text-shadow:none;background-color:transparent;border:0}.input-block-level{display:block;width:100%;min-height:30px;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}code,pre{padding:0 3px 2px;font-family:Monaco,Menlo,Consolas,"Courier New",monospace;font-size:12px;color:#333;-webkit-border-radius:3px;-moz-border-radius:3px;border-radius:3px}code{padding:2px 4px;color:#d14;background-color:#f7f7f9;border:1px solid #e1e1e8;white-space:nowrap}pre{display:block;padding:9.5px;margin:0 0 10px;font-size:13px;line-height:20px;word-break:break-all;word-wrap:break-word;white-space:pre;white-space:pre-wrap;background-color:#f5f5f5;border:1px solid #ccc;border:1px solid rgba(0,0,0,.15);-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px}pre.prettyprint{margin-bottom:20px}pre code{padding:0;color:inherit;white-space:pre;white-space:pre-wrap;background-color:transparent;border:0}.pre-scrollable{max-height:340px;overflow-y:scroll}form{margin:0 0 20px}fieldset{padding:0;margin:0;border:0}legend{display:block;width:100%;padding:0;margin-bottom:20px;font-size:21px;line-height:40px;color:#333;border:0;border-bottom:1px solid #e5e5e5}legend small{font-size:15px;color:#999}label,input,button,select,textarea{font-size:14px;font-weight:400;line-height:20px}input,button,select,textarea{font-family:"Helvetica Neue",Helvetica,Arial,sans-serif}label{display:block;margin-bottom:5px}select,textarea,input[type=text],input[type=password],input[type=datetime],input[type=datetime-local],input[type=date],input[type=month],input[type=time],input[type=week],input[type=number],input[type=email],input[type=url],input[type=search],input[type=tel],input[type=color],.uneditable-input{display:inline-block;height:20px;padding:4px 6px;margin-bottom:10px;font-size:14px;line-height:20px;color:#555;-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px;vertical-align:middle}input,textarea,.uneditable-input{width:206px}textarea{height:auto}textarea,input[type=text],input[type=password],input[type=datetime],input[type=datetime-local],input[type=date],input[type=month],input[type=time],input[type=week],input[type=number],input[type=email],input[type=url],input[type=search],input[type=tel],input[type=color],.uneditable-input{background-color:#fff;border:1px solid #ccc;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);box-shadow:inset 0 1px 1px rgba(0,0,0,.075);-webkit-transition:border linear .2s,box-shadow linear .2s;-moz-transition:border linear .2s,box-shadow linear .2s;-o-transition:border linear .2s,box-shadow linear .2s;transition:border linear .2s,box-shadow linear .2s}textarea:focus,input[type=text]:focus,input[type=password]:focus,input[type=datetime]:focus,input[type=datetime-local]:focus,input[type=date]:focus,input[type=month]:focus,input[type=time]:focus,input[type=week]:focus,input[type=number]:focus,input[type=email]:focus,input[type=url]:focus,input[type=search]:focus,input[type=tel]:focus,input[type=color]:focus,.uneditable-input:focus{border-color:rgba(82,168,236,.8);outline:0;outline:thin dotted \9;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 8px rgba(82,168,236,.6);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 8px rgba(82,168,236,.6);box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 8px rgba(82,168,236,.6)}input[type=radio],input[type=checkbox]{margin:4px 0 0;*margin-top:0;margin-top:1px \9;line-height:normal}input[type=file],input[type=image],input[type=submit],input[type=reset],input[type=button],input[type=radio],input[type=checkbox]{width:auto}select,input[type=file]{height:30px;*margin-top:4px;line-height:30px}select{width:220px;border:1px solid #ccc;background-color:#fff}select[multiple],select[size]{height:auto}select:focus,input[type=file]:focus,input[type=radio]:focus,input[type=checkbox]:focus{outline:thin dotted #333;outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}.uneditable-input,.uneditable-textarea{color:#999;background-color:#fcfcfc;border-color:#ccc;-webkit-box-shadow:inset 0 1px 2px rgba(0,0,0,.025);-moz-box-shadow:inset 0 1px 2px rgba(0,0,0,.025);box-shadow:inset 0 1px 2px rgba(0,0,0,.025);cursor:not-allowed}.uneditable-input{overflow:hidden;white-space:nowrap}.uneditable-textarea{width:auto;height:auto}input:-moz-placeholder,textarea:-moz-placeholder{color:#999}input:-ms-input-placeholder,textarea:-ms-input-placeholder{color:#999}input::-webkit-input-placeholder,textarea::-webkit-input-placeholder{color:#999}.radio,.checkbox{min-height:20px;padding-left:20px}.radio input[type=radio],.checkbox input[type=checkbox]{float:left;margin-left:-20px}.controls>.radio:first-child,.controls>.checkbox:first-child{padding-top:5px}.radio.inline,.checkbox.inline{display:inline-block;padding-top:5px;margin-bottom:0;vertical-align:middle}.radio.inline+.radio.inline,.checkbox.inline+.checkbox.inline{margin-left:10px}.input-mini{width:60px}.input-small{width:90px}.input-medium{width:150px}.input-large{width:210px}.input-xlarge{width:270px}.input-xxlarge{width:530px}input[class*=span],select[class*=span],textarea[class*=span],.uneditable-input[class*=span],.row-fluid input[class*=span],.row-fluid select[class*=span],.row-fluid textarea[class*=span],.row-fluid .uneditable-input[class*=span]{float:none;margin-left:0}.input-append input[class*=span],.input-append .uneditable-input[class*=span],.input-prepend input[class*=span],.input-prepend .uneditable-input[class*=span],.row-fluid input[class*=span],.row-fluid select[class*=span],.row-fluid textarea[class*=span],.row-fluid .uneditable-input[class*=span],.row-fluid .input-prepend [class*=span],.row-fluid .input-append [class*=span]{display:inline-block}input,textarea,.uneditable-input{margin-left:0}.controls-row [class*=span]+[class*=span]{margin-left:20px}input.span12,textarea.span12,.uneditable-input.span12{width:926px}input.span11,textarea.span11,.uneditable-input.span11{width:846px}input.span10,textarea.span10,.uneditable-input.span10{width:766px}input.span9,textarea.span9,.uneditable-input.span9{width:686px}input.span8,textarea.span8,.uneditable-input.span8{width:606px}input.span7,textarea.span7,.uneditable-input.span7{width:526px}input.span6,textarea.span6,.uneditable-input.span6{width:446px}input.span5,textarea.span5,.uneditable-input.span5{width:366px}input.span4,textarea.span4,.uneditable-input.span4{width:286px}input.span3,textarea.span3,.uneditable-input.span3{width:206px}input.span2,textarea.span2,.uneditable-input.span2{width:126px}input.span1,textarea.span1,.uneditable-input.span1{width:46px}.controls-row{*zoom:1}.controls-row:before,.controls-row:after{display:table;content:"";line-height:0}.controls-row:after{clear:both}.controls-row [class*=span],.row-fluid .controls-row [class*=span]{float:left}.controls-row .checkbox[class*=span],.controls-row .radio[class*=span]{padding-top:5px}input[disabled],select[disabled],textarea[disabled],input[readonly],select[readonly],textarea[readonly]{cursor:not-allowed;background-color:#eee}input[type=radio][disabled],input[type=checkbox][disabled],input[type=radio][readonly],input[type=checkbox][readonly]{background-color:transparent}.control-group.warning .control-label,.control-group.warning .help-block,.control-group.warning .help-inline{color:#c09853}.control-group.warning .checkbox,.control-group.warning .radio,.control-group.warning input,.control-group.warning select,.control-group.warning textarea{color:#c09853}.control-group.warning input,.control-group.warning select,.control-group.warning textarea{border-color:#c09853;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);box-shadow:inset 0 1px 1px rgba(0,0,0,.075)}.control-group.warning input:focus,.control-group.warning select:focus,.control-group.warning textarea:focus{border-color:#a47e3c;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #dbc59e;-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #dbc59e;box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #dbc59e}.control-group.warning .input-prepend .add-on,.control-group.warning .input-append .add-on{color:#c09853;background-color:#fcf8e3;border-color:#c09853}.control-group.error .control-label,.control-group.error .help-block,.control-group.error .help-inline{color:#b94a48}.control-group.error .checkbox,.control-group.error .radio,.control-group.error input,.control-group.error select,.control-group.error textarea{color:#b94a48}.control-group.error input,.control-group.error select,.control-group.error textarea{border-color:#b94a48;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);box-shadow:inset 0 1px 1px rgba(0,0,0,.075)}.control-group.error input:focus,.control-group.error select:focus,.control-group.error textarea:focus{border-color:#953b39;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #d59392;-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #d59392;box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #d59392}.control-group.error .input-prepend .add-on,.control-group.error .input-append .add-on{color:#b94a48;background-color:#f2dede;border-color:#b94a48}.control-group.success .control-label,.control-group.success .help-block,.control-group.success .help-inline{color:#468847}.control-group.success .checkbox,.control-group.success .radio,.control-group.success input,.control-group.success select,.control-group.success textarea{color:#468847}.control-group.success input,.control-group.success select,.control-group.success textarea{border-color:#468847;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);box-shadow:inset 0 1px 1px rgba(0,0,0,.075)}.control-group.success input:focus,.control-group.success select:focus,.control-group.success textarea:focus{border-color:#356635;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #7aba7b;-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #7aba7b;box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #7aba7b}.control-group.success .input-prepend .add-on,.control-group.success .input-append .add-on{color:#468847;background-color:#dff0d8;border-color:#468847}.control-group.info .control-label,.control-group.info .help-block,.control-group.info .help-inline{color:#3a87ad}.control-group.info .checkbox,.control-group.info .radio,.control-group.info input,.control-group.info select,.control-group.info textarea{color:#3a87ad}.control-group.info input,.control-group.info select,.control-group.info textarea{border-color:#3a87ad;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);box-shadow:inset 0 1px 1px rgba(0,0,0,.075)}.control-group.info input:focus,.control-group.info select:focus,.control-group.info textarea:focus{border-color:#2d6987;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #7ab5d3;-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #7ab5d3;box-shadow:inset 0 1px 1px rgba(0,0,0,.075),0 0 6px #7ab5d3}.control-group.info .input-prepend .add-on,.control-group.info .input-append .add-on{color:#3a87ad;background-color:#d9edf7;border-color:#3a87ad}input:focus:invalid,textarea:focus:invalid,select:focus:invalid{color:#b94a48;border-color:#ee5f5b}input:focus:invalid:focus,textarea:focus:invalid:focus,select:focus:invalid:focus{border-color:#e9322d;-webkit-box-shadow:0 0 6px #f8b9b7;-moz-box-shadow:0 0 6px #f8b9b7;box-shadow:0 0 6px #f8b9b7}.form-actions{padding:19px 20px 20px;margin-top:20px;margin-bottom:20px;background-color:#f5f5f5;border-top:1px solid #e5e5e5;*zoom:1}.form-actions:before,.form-actions:after{display:table;content:"";line-height:0}.form-actions:after{clear:both}.help-block,.help-inline{color:#595959}.help-block{display:block;margin-bottom:10px}.help-inline{display:inline-block;*display:inline;*zoom:1;vertical-align:middle;padding-left:5px}.input-append,.input-prepend{display:inline-block;margin-bottom:10px;vertical-align:middle;font-size:0;white-space:nowrap}.input-append input,.input-prepend input,.input-append select,.input-prepend select,.input-append .uneditable-input,.input-prepend .uneditable-input,.input-append .dropdown-menu,.input-prepend .dropdown-menu,.input-append .popover,.input-prepend .popover{font-size:14px}.input-append input,.input-prepend input,.input-append select,.input-prepend select,.input-append .uneditable-input,.input-prepend .uneditable-input{position:relative;margin-bottom:0;*margin-left:0;vertical-align:top;-webkit-border-radius:0 4px 4px 0;-moz-border-radius:0 4px 4px 0;border-radius:0 4px 4px 0}.input-append input:focus,.input-prepend input:focus,.input-append select:focus,.input-prepend select:focus,.input-append .uneditable-input:focus,.input-prepend .uneditable-input:focus{z-index:2}.input-append .add-on,.input-prepend .add-on{display:inline-block;width:auto;height:20px;min-width:16px;padding:4px 5px;font-size:14px;font-weight:400;line-height:20px;text-align:center;text-shadow:0 1px 0 #fff;background-color:#eee;border:1px solid #ccc}.input-append .add-on,.input-prepend .add-on,.input-append .btn,.input-prepend .btn,.input-append .btn-group>.dropdown-toggle,.input-prepend .btn-group>.dropdown-toggle{vertical-align:top;-webkit-border-radius:0;-moz-border-radius:0;border-radius:0}.input-append .active,.input-prepend .active{background-color:#a9dba9;border-color:#46a546}.input-prepend .add-on,.input-prepend .btn{margin-right:-1px}.input-prepend .add-on:first-child,.input-prepend .btn:first-child{-webkit-border-radius:4px 0 0 4px;-moz-border-radius:4px 0 0 4px;border-radius:4px 0 0 4px}.input-append input,.input-append select,.input-append .uneditable-input{-webkit-border-radius:4px 0 0 4px;-moz-border-radius:4px 0 0 4px;border-radius:4px 0 0 4px}.input-append input+.btn-group .btn:last-child,.input-append select+.btn-group .btn:last-child,.input-append .uneditable-input+.btn-group .btn:last-child{-webkit-border-radius:0 4px 4px 0;-moz-border-radius:0 4px 4px 0;border-radius:0 4px 4px 0}.input-append .add-on,.input-append .btn,.input-append .btn-group{margin-left:-1px}.input-append .add-on:last-child,.input-append .btn:last-child,.input-append .btn-group:last-child>.dropdown-toggle{-webkit-border-radius:0 4px 4px 0;-moz-border-radius:0 4px 4px 0;border-radius:0 4px 4px 0}.input-prepend.input-append input,.input-prepend.input-append select,.input-prepend.input-append .uneditable-input{-webkit-border-radius:0;-moz-border-radius:0;border-radius:0}.input-prepend.input-append input+.btn-group .btn,.input-prepend.input-append select+.btn-group .btn,.input-prepend.input-append .uneditable-input+.btn-group .btn{-webkit-border-radius:0 4px 4px 0;-moz-border-radius:0 4px 4px 0;border-radius:0 4px 4px 0}.input-prepend.input-append .add-on:first-child,.input-prepend.input-append .btn:first-child{margin-right:-1px;-webkit-border-radius:4px 0 0 4px;-moz-border-radius:4px 0 0 4px;border-radius:4px 0 0 4px}.input-prepend.input-append .add-on:last-child,.input-prepend.input-append .btn:last-child{margin-left:-1px;-webkit-border-radius:0 4px 4px 0;-moz-border-radius:0 4px 4px 0;border-radius:0 4px 4px 0}.input-prepend.input-append .btn-group:first-child{margin-left:0}input.search-query{padding-right:14px;padding-right:4px \9;padding-left:14px;padding-left:4px \9;margin-bottom:0;-webkit-border-radius:15px;-moz-border-radius:15px;border-radius:15px}.form-search .input-append .search-query,.form-search .input-prepend .search-query{-webkit-border-radius:0;-moz-border-radius:0;border-radius:0}.form-search .input-append .search-query{-webkit-border-radius:14px 0 0 14px;-moz-border-radius:14px 0 0 14px;border-radius:14px 0 0 14px}.form-search .input-append .btn{-webkit-border-radius:0 14px 14px 0;-moz-border-radius:0 14px 14px 0;border-radius:0 14px 14px 0}.form-search .input-prepend .search-query{-webkit-border-radius:0 14px 14px 0;-moz-border-radius:0 14px 14px 0;border-radius:0 14px 14px 0}.form-search .input-prepend .btn{-webkit-border-radius:14px 0 0 14px;-moz-border-radius:14px 0 0 14px;border-radius:14px 0 0 14px}.form-search input,.form-inline input,.form-horizontal input,.form-search textarea,.form-inline textarea,.form-horizontal textarea,.form-search select,.form-inline select,.form-horizontal select,.form-search .help-inline,.form-inline .help-inline,.form-horizontal .help-inline,.form-search .uneditable-input,.form-inline .uneditable-input,.form-horizontal .uneditable-input,.form-search .input-prepend,.form-inline .input-prepend,.form-horizontal .input-prepend,.form-search .input-append,.form-inline .input-append,.form-horizontal .input-append{display:inline-block;*display:inline;*zoom:1;margin-bottom:0;vertical-align:middle}.form-search .hide,.form-inline .hide,.form-horizontal .hide{display:none}.form-search label,.form-inline label,.form-search .btn-group,.form-inline .btn-group{display:inline-block}.form-search .input-append,.form-inline .input-append,.form-search .input-prepend,.form-inline .input-prepend{margin-bottom:0}.form-search .radio,.form-search .checkbox,.form-inline .radio,.form-inline .checkbox{padding-left:0;margin-bottom:0;vertical-align:middle}.form-search .radio input[type=radio],.form-search .checkbox input[type=checkbox],.form-inline .radio input[type=radio],.form-inline .checkbox input[type=checkbox]{float:left;margin-right:3px;margin-left:0}.control-group{margin-bottom:10px}legend+.control-group{margin-top:20px;-webkit-margin-top-collapse:separate}.form-horizontal .control-group{margin-bottom:20px;*zoom:1}.form-horizontal .control-group:before,.form-horizontal .control-group:after{display:table;content:"";line-height:0}.form-horizontal .control-group:after{clear:both}.form-horizontal .control-label{float:left;width:160px;padding-top:5px;text-align:right}.form-horizontal .controls{*display:inline-block;*padding-left:20px;margin-left:180px;*margin-left:0}.form-horizontal .controls:first-child{*padding-left:180px}.form-horizontal .help-block{margin-bottom:0}.form-horizontal input+.help-block,.form-horizontal select+.help-block,.form-horizontal textarea+.help-block,.form-horizontal .uneditable-input+.help-block,.form-horizontal .input-prepend+.help-block,.form-horizontal .input-append+.help-block{margin-top:10px}.form-horizontal .form-actions{padding-left:180px}.btn{display:inline-block;*display:inline;*zoom:1;padding:4px 12px;margin-bottom:0;font-size:14px;line-height:20px;text-align:center;vertical-align:middle;cursor:pointer;color:#333;text-shadow:0 1px 1px rgba(255,255,255,.75);background-color:#f5f5f5;background-image:-moz-linear-gradient(top,#fff,#e6e6e6);background-image:-webkit-gradient(linear,0 0,0 100%,from(#fff),to(#e6e6e6));background-image:-webkit-linear-gradient(top,#fff,#e6e6e6);background-image:-o-linear-gradient(top,#fff,#e6e6e6);background-image:linear-gradient(to bottom,#fff,#e6e6e6);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffffffff', endColorstr='#ffe6e6e6', GradientType=0);border-color:#e6e6e6 #e6e6e6 #bfbfbf;border-color:rgba(0,0,0,.1) rgba(0,0,0,.1) rgba(0,0,0,.25);*background-color:#e6e6e6;filter:progid:DXImageTransform.Microsoft.gradient(enabled=false);border:1px solid #ccc;*border:0;border-bottom-color:#b3b3b3;-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px;*margin-left:.3em;-webkit-box-shadow:inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);-moz-box-shadow:inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);box-shadow:inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05)}.btn:hover,.btn:focus,.btn:active,.btn.active,.btn.disabled,.btn[disabled]{color:#333;background-color:#e6e6e6;*background-color:#d9d9d9}.btn:active,.btn.active{background-color:#ccc \9}.btn:first-child{*margin-left:0}.btn:hover,.btn:focus{color:#333;text-decoration:none;background-position:0 -15px;-webkit-transition:background-position .1s linear;-moz-transition:background-position .1s linear;-o-transition:background-position .1s linear;transition:background-position .1s linear}.btn:focus{outline:thin dotted #333;outline:5px auto -webkit-focus-ring-color;outline-offset:-2px}.btn.active,.btn:active{background-image:none;outline:0;-webkit-box-shadow:inset 0 2px 4px rgba(0,0,0,.15),0 1px 2px rgba(0,0,0,.05);-moz-box-shadow:inset 0 2px 4px rgba(0,0,0,.15),0 1px 2px rgba(0,0,0,.05);box-shadow:inset 0 2px 4px rgba(0,0,0,.15),0 1px 2px rgba(0,0,0,.05)}.btn.disabled,.btn[disabled]{cursor:default;background-image:none;opacity:.65;filter:alpha(opacity=65);-webkit-box-shadow:none;-moz-box-shadow:none;box-shadow:none}.btn-large{padding:11px 19px;font-size:17.5px;-webkit-border-radius:6px;-moz-border-radius:6px;border-radius:6px}.btn-large [class^=icon-],.btn-large [class*=" icon-"]{margin-top:4px}.btn-small{padding:2px 10px;font-size:11.9px;-webkit-border-radius:3px;-moz-border-radius:3px;border-radius:3px}.btn-small [class^=icon-],.btn-small [class*=" icon-"]{margin-top:0}.btn-mini [class^=icon-],.btn-mini [class*=" icon-"]{margin-top:-1px}.btn-mini{padding:0 6px;font-size:10.5px;-webkit-border-radius:3px;-moz-border-radius:3px;border-radius:3px}.btn-block{display:block;width:100%;padding-left:0;padding-right:0;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;box-sizing:border-box}.btn-block+.btn-block{margin-top:5px}input[type=submit].btn-block,input[type=reset].btn-block,input[type=button].btn-block{width:100%}.btn-primary.active,.btn-warning.active,.btn-danger.active,.btn-success.active,.btn-info.active,.btn-inverse.active{color:rgba(255,255,255,.75)}.btn-primary{color:#fff;text-shadow:0 -1px 0 rgba(0,0,0,.25);background-color:#006dcc;background-image:-moz-linear-gradient(top,#08c,#04c);background-image:-webkit-gradient(linear,0 0,0 100%,from(#08c),to(#04c));background-image:-webkit-linear-gradient(top,#08c,#04c);background-image:-o-linear-gradient(top,#08c,#04c);background-image:linear-gradient(to bottom,#08c,#04c);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff0088cc', endColorstr='#ff0044cc', GradientType=0);border-color:#04c #04c #002a80;border-color:rgba(0,0,0,.1) rgba(0,0,0,.1) rgba(0,0,0,.25);*background-color:#04c;filter:progid:DXImageTransform.Microsoft.gradient(enabled=false)}.btn-primary:hover,.btn-primary:focus,.btn-primary:active,.btn-primary.active,.btn-primary.disabled,.btn-primary[disabled]{color:#fff;background-color:#04c;*background-color:#003bb3}.btn-primary:active,.btn-primary.active{background-color:#039 \9}.btn-warning{color:#fff;text-shadow:0 -1px 0 rgba(0,0,0,.25);background-color:#faa732;background-image:-moz-linear-gradient(top,#fbb450,#f89406);background-image:-webkit-gradient(linear,0 0,0 100%,from(#fbb450),to(#f89406));background-image:-webkit-linear-gradient(top,#fbb450,#f89406);background-image:-o-linear-gradient(top,#fbb450,#f89406);background-image:linear-gradient(to bottom,#fbb450,#f89406);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#fffbb450', endColorstr='#fff89406', GradientType=0);border-color:#f89406 #f89406 #ad6704;border-color:rgba(0,0,0,.1) rgba(0,0,0,.1) rgba(0,0,0,.25);*background-color:#f89406;filter:progid:DXImageTransform.Microsoft.gradient(enabled=false)}.btn-warning:hover,.btn-warning:focus,.btn-warning:active,.btn-warning.active,.btn-warning.disabled,.btn-warning[disabled]{color:#fff;background-color:#f89406;*background-color:#df8505}.btn-warning:active,.btn-warning.active{background-color:#c67605 \9}.btn-danger{color:#fff;text-shadow:0 -1px 0 rgba(0,0,0,.25);background-color:#da4f49;background-image:-moz-linear-gradient(top,#ee5f5b,#bd362f);background-image:-webkit-gradient(linear,0 0,0 100%,from(#ee5f5b),to(#bd362f));background-image:-webkit-linear-gradient(top,#ee5f5b,#bd362f);background-image:-o-linear-gradient(top,#ee5f5b,#bd362f);background-image:linear-gradient(to bottom,#ee5f5b,#bd362f);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffee5f5b', endColorstr='#ffbd362f', GradientType=0);border-color:#bd362f #bd362f #802420;border-color:rgba(0,0,0,.1) rgba(0,0,0,.1) rgba(0,0,0,.25);*background-color:#bd362f;filter:progid:DXImageTransform.Microsoft.gradient(enabled=false)}.btn-danger:hover,.btn-danger:focus,.btn-danger:active,.btn-danger.active,.btn-danger.disabled,.btn-danger[disabled]{color:#fff;background-color:#bd362f;*background-color:#a9302a}.btn-danger:active,.btn-danger.active{background-color:#942a25 \9}.btn-success{color:#fff;text-shadow:0 -1px 0 rgba(0,0,0,.25);background-color:#5bb75b;background-image:-moz-linear-gradient(top,#62c462,#51a351);background-image:-webkit-gradient(linear,0 0,0 100%,from(#62c462),to(#51a351));background-image:-webkit-linear-gradient(top,#62c462,#51a351);background-image:-o-linear-gradient(top,#62c462,#51a351);background-image:linear-gradient(to bottom,#62c462,#51a351);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff62c462', endColorstr='#ff51a351', GradientType=0);border-color:#51a351 #51a351 #387038;border-color:rgba(0,0,0,.1) rgba(0,0,0,.1) rgba(0,0,0,.25);*background-color:#51a351;filter:progid:DXImageTransform.Microsoft.gradient(enabled=false)}.btn-success:hover,.btn-success:focus,.btn-success:active,.btn-success.active,.btn-success.disabled,.btn-success[disabled]{color:#fff;background-color:#51a351;*background-color:#499249}.btn-success:active,.btn-success.active{background-color:#408140 \9}.btn-info{color:#fff;text-shadow:0 -1px 0 rgba(0,0,0,.25);background-color:#49afcd;background-image:-moz-linear-gradient(top,#5bc0de,#2f96b4);background-image:-webkit-gradient(linear,0 0,0 100%,from(#5bc0de),to(#2f96b4));background-image:-webkit-linear-gradient(top,#5bc0de,#2f96b4);background-image:-o-linear-gradient(top,#5bc0de,#2f96b4);background-image:linear-gradient(to bottom,#5bc0de,#2f96b4);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff5bc0de', endColorstr='#ff2f96b4', GradientType=0);border-color:#2f96b4 #2f96b4 #1f6377;border-color:rgba(0,0,0,.1) rgba(0,0,0,.1) rgba(0,0,0,.25);*background-color:#2f96b4;filter:progid:DXImageTransform.Microsoft.gradient(enabled=false)}.btn-info:hover,.btn-info:focus,.btn-info:active,.btn-info.active,.btn-info.disabled,.btn-info[disabled]{color:#fff;background-color:#2f96b4;*background-color:#2a85a0}.btn-info:active,.btn-info.active{background-color:#24748c \9}.btn-inverse{color:#fff;text-shadow:0 -1px 0 rgba(0,0,0,.25);background-color:#363636;background-image:-moz-linear-gradient(top,#444,#222);background-image:-webkit-gradient(linear,0 0,0 100%,from(#444),to(#222));background-image:-webkit-linear-gradient(top,#444,#222);background-image:-o-linear-gradient(top,#444,#222);background-image:linear-gradient(to bottom,#444,#222);background-repeat:repeat-x;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff444444', endColorstr='#ff222222', GradientType=0);border-color:#222 #222 #000;border-color:rgba(0,0,0,.1) rgba(0,0,0,.1) rgba(0,0,0,.25);*background-color:#222;filter:progid:DXImageTransform.Microsoft.gradient(enabled=false)}.btn-inverse:hover,.btn-inverse:focus,.btn-inverse:active,.btn-inverse.active,.btn-inverse.disabled,.btn-inverse[disabled]{color:#fff;background-color:#222;*background-color:#151515}.btn-inverse:active,.btn-inverse.active{background-color:#080808 \9}button.btn,input[type=submit].btn{*padding-top:3px;*padding-bottom:3px}button.btn::-moz-focus-inner,input[type=submit].btn::-moz-focus-inner{padding:0;border:0}button.btn.btn-large,input[type=submit].btn.btn-large{*padding-top:7px;*padding-bottom:7px}button.btn.btn-small,input[type=submit].btn.btn-small{*padding-top:3px;*padding-bottom:3px}button.btn.btn-mini,input[type=submit].btn.btn-mini{*padding-top:1px;*padding-bottom:1px}.btn-link,.btn-link:active,.btn-link[disabled]{background-color:transparent;background-image:none;-webkit-box-shadow:none;-moz-box-shadow:none;box-shadow:none}.btn-link{border-color:transparent;cursor:pointer;color:#08c;-webkit-border-radius:0;-moz-border-radius:0;border-radius:0}.btn-link:hover,.btn-link:focus{color:#005580;text-decoration:underline;background-color:transparent}.btn-link[disabled]:hover,.btn-link[disabled]:focus{color:#333;text-decoration:none}[class^=icon-],[class*=" icon-"]{display:inline-block;width:14px;height:14px;*margin-right:.3em;line-height:14px;vertical-align:text-top;background-image:url(../resources/bootstrap/glyphicons-halflings.png);background-position:14px 14px;background-repeat:no-repeat;margin-top:1px}.icon-white,.nav-pills>.active>a>[class^=icon-],.nav-pills>.active>a>[class*=" icon-"],.nav-list>.active>a>[class^=icon-],.nav-list>.active>a>[class*=" icon-"],.navbar-inverse .nav>.active>a>[class^=icon-],.navbar-inverse .nav>.active>a>[class*=" icon-"],.dropdown-menu>li>a:hover>[class^=icon-],.dropdown-menu>li>a:focus>[class^=icon-],.dropdown-menu>li>a:hover>[class*=" icon-"],.dropdown-menu>li>a:focus>[class*=" icon-"],.dropdown-menu>.active>a>[class^=icon-],.dropdown-menu>.active>a>[class*=" icon-"],.dropdown-submenu:hover>a>[class^=icon-],.dropdown-submenu:focus>a>[class^=icon-],.dropdown-submenu:hover>a>[class*=" icon-"],.dropdown-submenu:focus>a>[class*=" icon-"]{background-image:url(../resources/bootstrap/glyphicons-halflings-white.png)}.icon-glass{background-position:0 0}.icon-music{background-position:-24px 0}.icon-search{background-position:-48px 0}.icon-envelope{background-position:-72px 0}.icon-heart{background-position:-96px 0}.icon-star{background-position:-120px 0}.icon-star-empty{background-position:-144px 0}.icon-user{background-position:-168px 0}.icon-film{background-position:-192px 0}.icon-th-large{background-position:-216px 0}.icon-th{background-position:-240px 0}.icon-th-list{background-position:-264px 0}.icon-ok{background-position:-288px 0}.icon-remove{background-position:-312px 0}.icon-zoom-in{background-position:-336px 0}.icon-zoom-out{background-position:-360px 0}.icon-off{background-position:-384px 0}.icon-signal{background-position:-408px 0}.icon-cog{background-position:-432px 0}.icon-trash{background-position:-456px 0}.icon-home{background-position:0 -24px}.icon-file{background-position:-24px -24px}.icon-time{background-position:-48px -24px}.icon-road{background-position:-72px -24px}.icon-download-alt{background-position:-96px -24px}.icon-download{background-position:-120px -24px}.icon-upload{background-position:-144px -24px}.icon-inbox{background-position:-168px -24px}.icon-play-circle{background-position:-192px -24px}.icon-repeat{background-position:-216px -24px}.icon-refresh{background-position:-240px -24px}.icon-list-alt{background-position:-264px -24px}.icon-lock{background-position:-287px -24px}.icon-flag{background-position:-312px -24px}.icon-headphones{background-position:-336px -24px}.icon-volume-off{background-position:-360px -24px}.icon-volume-down{background-position:-384px -24px}.icon-volume-up{background-position:-408px -24px}.icon-qrcode{background-position:-432px -24px}.icon-barcode{background-position:-456px -24px}.icon-tag{background-position:0 -48px}.icon-tags{background-position:-25px -48px}.icon-book{background-position:-48px -48px}.icon-bookmark{background-position:-72px -48px}.icon-print{background-position:-96px -48px}.icon-camera{background-position:-120px -48px}.icon-font{background-position:-144px -48px}.icon-bold{background-position:-167px -48px}.icon-italic{background-position:-192px -48px}.icon-text-height{background-position:-216px -48px}.icon-text-width{background-position:-240px -48px}.icon-align-left{background-position:-264px -48px}.icon-align-center{background-position:-288px -48px}.icon-align-right{background-position:-312px -48px}.icon-align-justify{background-position:-336px -48px}.icon-list{background-position:-360px -48px}.icon-indent-left{background-position:-384px -48px}.icon-indent-right{background-position:-408px -48px}.icon-facetime-video{background-position:-432px -48px}.icon-picture{background-position:-456px -48px}.icon-pencil{background-position:0 -72px}.icon-map-marker{background-position:-24px -72px}.icon-adjust{background-position:-48px -72px}.icon-tint{background-position:-72px -72px}.icon-edit{background-position:-96px -72px}.icon-share{background-position:-120px -72px}.icon-check{background-position:-144px -72px}.icon-move{background-position:-168px -72px}.icon-step-backward{background-position:-192px -72px}.icon-fast-backward{background-position:-216px -72px}.icon-backward{background-position:-240px -72px}.icon-play{background-position:-264px -72px}.icon-pause{background-position:-288px -72px}.icon-stop{background-position:-312px -72px}.icon-forward{background-position:-336px -72px}.icon-fast-forward{background-position:-360px -72px}.icon-step-forward{background-position:-384px -72px}.icon-eject{background-position:-408px -72px}.icon-chevron-left{background-position:-432px -72px}.icon-chevron-right{background-position:-456px -72px}.icon-plus-sign{background-position:0 -96px}.icon-minus-sign{background-position:-24px -96px}.icon-remove-sign{background-position:-48px -96px}.icon-ok-sign{background-position:-72px -96px}.icon-question-sign{background-position:-96px -96px}.icon-info-sign{background-position:-120px -96px}.icon-screenshot{background-position:-144px -96px}.icon-remove-circle{background-position:-168px -96px}.icon-ok-circle{background-position:-192px -96px}.icon-ban-circle{background-position:-216px -96px}.icon-arrow-left{background-position:-240px -96px}.icon-arrow-right{background-position:-264px -96px}.icon-arrow-up{background-position:-289px -96px}.icon-arrow-down{background-position:-312px -96px}.icon-share-alt{background-position:-336px -96px}.icon-resize-full{background-position:-360px -96px}.icon-resize-small{background-position:-384px -96px}.icon-plus{background-position:-408px -96px}.icon-minus{background-position:-433px -96px}.icon-asterisk{background-position:-456px -96px}.icon-exclamation-sign{background-position:0 -120px}.icon-gift{background-position:-24px -120px}.icon-leaf{background-position:-48px -120px}.icon-fire{background-position:-72px -120px}.icon-eye-open{background-position:-96px -120px}.icon-eye-close{background-position:-120px -120px}.icon-warning-sign{background-position:-144px -120px}.icon-plane{background-position:-168px -120px}.icon-calendar{background-position:-192px -120px}.icon-random{background-position:-216px -120px;width:16px}.icon-comment{background-position:-240px -120px}.icon-magnet{background-position:-264px -120px}.icon-chevron-up{background-position:-288px -120px}.icon-chevron-down{background-position:-313px -119px}.icon-retweet{background-position:-336px -120px}.icon-shopping-cart{background-position:-360px -120px}.icon-folder-close{background-position:-384px -120px;width:16px}.icon-folder-open{background-position:-408px -120px;width:16px}.icon-resize-vertical{background-position:-432px -119px}.icon-resize-horizontal{background-position:-456px -118px}.icon-hdd{background-position:0 -144px}.icon-bullhorn{background-position:-24px -144px}.icon-bell{background-position:-48px -144px}.icon-certificate{background-position:-72px -144px}.icon-thumbs-up{background-position:-96px -144px}.icon-thumbs-down{background-position:-120px -144px}.icon-hand-right{background-position:-144px -144px}.icon-hand-left{background-position:-168px -144px}.icon-hand-up{background-position:-192px -144px}.icon-hand-down{background-position:-216px -144px}.icon-circle-arrow-right{background-position:-240px -144px}.icon-circle-arrow-left{background-position:-264px -144px}.icon-circle-arrow-up{background-position:-288px -144px}.icon-circle-arrow-down{background-position:-312px -144px}.icon-globe{background-position:-336px -144px}.icon-wrench{background-position:-360px -144px}.icon-tasks{background-position:-384px -144px}.icon-filter{background-position:-408px -144px}.icon-briefcase{background-position:-432px -144px}.icon-fullscreen{background-position:-456px -144px}.btn-group{position:relative;display:inline-block;*display:inline;*zoom:1;font-size:0;vertical-align:middle;white-space:nowrap;*margin-left:.3em}.btn-group:first-child{*margin-left:0}.btn-group+.btn-group{margin-left:5px}.btn-toolbar{font-size:0;margin-top:10px;margin-bottom:10px}.btn-toolbar>.btn+.btn,.btn-toolbar>.btn-group+.btn,.btn-toolbar>.btn+.btn-group{margin-left:5px}.btn-group>.btn{position:relative;-webkit-border-radius:0;-moz-border-radius:0;border-radius:0}.btn-group>.btn+.btn{margin-left:-1px}.btn-group>.btn,.btn-group>.dropdown-menu,.btn-group>.popover{font-size:14px}.btn-group>.btn-mini{font-size:10.5px}.btn-group>.btn-small{font-size:11.9px}.btn-group>.btn-large{font-size:17.5px}.btn-group>.btn:first-child{margin-left:0;-webkit-border-top-left-radius:4px;-moz-border-radius-topleft:4px;border-top-left-radius:4px;-webkit-border-bottom-left-radius:4px;-moz-border-radius-bottomleft:4px;border-bottom-left-radius:4px}.btn-group>.btn:last-child,.btn-group>.dropdown-toggle{-webkit-border-top-right-radius:4px;-moz-border-radius-topright:4px;border-top-right-radius:4px;-webkit-border-bottom-right-radius:4px;-moz-border-radius-bottomright:4px;border-bottom-right-radius:4px}.btn-group>.btn.large:first-child{margin-left:0;-webkit-border-top-left-radius:6px;-moz-border-radius-topleft:6px;border-top-left-radius:6px;-webkit-border-bottom-left-radius:6px;-moz-border-radius-bottomleft:6px;border-bottom-left-radius:6px}.btn-group>.btn.large:last-child,.btn-group>.large.dropdown-toggle{-webkit-border-top-right-radius:6px;-moz-border-radius-topright:6px;border-top-right-radius:6px;-webkit-border-bottom-right-radius:6px;-moz-border-radius-bottomright:6px;border-bottom-right-radius:6px}.btn-group>.btn:hover,.btn-group>.btn:focus,.btn-group>.btn:active,.btn-group>.btn.active{z-index:2}.btn-group .dropdown-toggle:active,.btn-group.open .dropdown-toggle{outline:0}.btn-group>.btn+.dropdown-toggle{padding-left:8px;padding-right:8px;-webkit-box-shadow:inset 1px 0 0 rgba(255,255,255,.125),inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);-moz-box-shadow:inset 1px 0 0 rgba(255,255,255,.125),inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);box-shadow:inset 1px 0 0 rgba(255,255,255,.125),inset 0 1px 0 rgba(255,255,255,.2),0 1px 2px rgba(0,0,0,.05);*padding-top:5px;*padding-bottom:5px}.btn-group>.btn-mini+.dropdown-toggle{padding-left:5px;padding-right:5px;*padding-top:2px;*padding-bottom:2px}.btn-group>.btn-small+.dropdown-toggle{*padding-top:5px;*padding-bottom:4px}.btn-group>.btn-large+.dropdown-toggle{padding-left:12px;padding-right:12px;*padding-top:7px;*padding-bottom:7px}.btn-group.open .dropdown-toggle{background-image:none;-webkit-box-shadow:inset 0 2px 4px rgba(0,0,0,.15),0 1px 2px rgba(0,0,0,.05);-moz-box-shadow:inset 0 2px 4px rgba(0,0,0,.15),0 1px 2px rgba(0,0,0,.05);box-shadow:inset 0 2px 4px rgba(0,0,0,.15),0 1px 2px rgba(0,0,0,.05)}.btn-group.open .btn.dropdown-toggle{background-color:#e6e6e6}.btn-group.open .btn-primary.dropdown-toggle{background-color:#04c}.btn-group.open .btn-warning.dropdown-toggle{background-color:#f89406}.btn-group.open .btn-danger.dropdown-toggle{background-color:#bd362f}.btn-group.open .btn-success.dropdown-toggle{background-color:#51a351}.btn-group.open .btn-info.dropdown-toggle{background-color:#2f96b4}.btn-group.open .btn-inverse.dropdown-toggle{background-color:#222}.btn .caret{margin-top:8px;margin-left:0}.btn-large .caret{margin-top:6px}.btn-large .caret{border-left-width:5px;border-right-width:5px;border-top-width:5px}.btn-mini .caret,.btn-small .caret{margin-top:8px}.dropup .btn-large .caret{border-bottom-width:5px}.btn-primary .caret,.btn-warning .caret,.btn-danger .caret,.btn-info .caret,.btn-success .caret,.btn-inverse .caret{border-top-color:#fff;border-bottom-color:#fff}.btn-group-vertical{display:inline-block;*display:inline;*zoom:1}.btn-group-vertical>.btn{display:block;float:none;max-width:100%;-webkit-border-radius:0;-moz-border-radius:0;border-radius:0}.btn-group-vertical>.btn+.btn{margin-left:0;margin-top:-1px}.btn-group-vertical>.btn:first-child{-webkit-border-radius:4px 4px 0 0;-moz-border-radius:4px 4px 0 0;border-radius:4px 4px 0 0}.btn-group-vertical>.btn:last-child{-webkit-border-radius:0 0 4px 4px;-moz-border-radius:0 0 4px 4px;border-radius:0 0 4px 4px}.btn-group-vertical>.btn-large:first-child{-webkit-border-radius:6px 6px 0 0;-moz-border-radius:6px 6px 0 0;border-radius:6px 6px 0 0}.btn-group-vertical>.btn-large:last-child{-webkit-border-radius:0 0 6px 6px;-moz-border-radius:0 0 6px 6px;border-radius:0 0 6px 6px}.nav{margin-left:0;margin-bottom:20px;list-style:none}.nav>li>a{display:block}.nav>li>a:hover,.nav>li>a:focus{text-decoration:none;background-color:#eee}.nav>li>a>img{max-width:none}.nav>.pull-right{float:right}.nav-header{display:block;padding:3px 15px;font-size:11px;font-weight:700;line-height:20px;color:#999;text-shadow:0 1px 0 rgba(255,255,255,.5);text-transform:uppercase}.nav li+.nav-header{margin-top:9px}.nav-list{padding-left:15px;padding-right:15px;margin-bottom:0}.nav-list>li>a,.nav-list .nav-header{margin-left:-15px;margin-right:-15px;text-shadow:0 1px 0 rgba(255,255,255,.5)}.nav-list>li>a{padding:3px 15px}.nav-list>.active>a,.nav-list>.active>a:hover,.nav-list>.active>a:focus{color:#fff;text-shadow:0 -1px 0 rgba(0,0,0,.2);background-color:#08c}.nav-list [class^=icon-],.nav-list [class*=" icon-"]{margin-right:2px}.nav-list .divider{*width:100%;height:1px;margin:9px 1px;*margin:-5px 0 5px;overflow:hidden;background-color:#e5e5e5;border-bottom:1px solid #fff}.nav-tabs,.nav-pills{*zoom:1}.nav-tabs:before,.nav-pills:before,.nav-tabs:after,.nav-pills:after{display:table;content:"";line-height:0}.nav-tabs:after,.nav-pills:after{clear:both}.nav-tabs>li,.nav-pills>li{float:left}.nav-tabs>li>a,.nav-pills>li>a{padding-right:12px;padding-left:12px;margin-right:2px;line-height:14px}.nav-tabs{border-bottom:1px solid #ddd}.nav-tabs>li{margin-bottom:-1px}.nav-tabs>li>a{padding-top:8px;padding-bottom:8px;line-height:20px;border:1px solid transparent;-webkit-border-radius:4px 4px 0 0;-moz-border-radius:4px 4px 0 0;border-radius:4px 4px 0 0}.nav-tabs>li>a:hover,.nav-tabs>li>a:focus{border-color:#eee #eee #ddd}.nav-tabs>.active>a,.nav-tabs>.active>a:hover,.nav-tabs>.active>a:focus{color:#555;background-color:#fff;border:1px solid #ddd;border-bottom-color:transparent;cursor:default}.nav-pills>li>a{padding-top:8px;padding-bottom:8px;margin-top:2px;margin-bottom:2px;-webkit-border-radius:5px;-moz-border-radius:5px;border-radius:5px}.nav-pills>.active>a,.nav-pills>.active>a:hover,.nav-pills>.active>a:focus{color:#fff;background-color:#08c}.nav-stacked>li{float:none}.nav-stacked>li>a{margin-right:0}.nav-tabs.nav-stacked{border-bottom:0}.nav-tabs.nav-stacked>li>a{border:1px solid #ddd;-webkit-border-radius:0;-moz-border-radius:0;border-radius:0}.nav-tabs.nav-stacked>li:first-child>a{-webkit-border-top-right-radius:4px;-moz-border-radius-topright:4px;border-top-right-radius:4px;-webkit-border-top-left-radius:4px;-moz-border-radius-topleft:4px;border-top-left-radius:4px}.nav-tabs.nav-stacked>li:last-child>a{-webkit-border-bottom-right-radius:4px;-moz-border-radius-bottomright:4px;border-bottom-right-radius:4px;-webkit-border-bottom-left-radius:4px;-moz-border-radius-bottomleft:4px;border-bottom-left-radius:4px}.nav-tabs.nav-stacked>li>a:hover,.nav-tabs.nav-stacked>li>a:focus{border-color:#ddd;z-index:2}.nav-pills.nav-stacked>li>a{margin-bottom:3px}.nav-pills.nav-stacked>li:last-child>a{margin-bottom:1px}.nav-tabs .dropdown-menu{-webkit-border-radius:0 0 6px 6px;-moz-border-radius:0 0 6px 6px;border-radius:0 0 6px 6px}.nav-pills .dropdown-menu{-webkit-border-radius:6px;-moz-border-radius:6px;border-radius:6px}.nav .dropdown-toggle .caret{border-top-color:#08c;border-bottom-color:#08c;margin-top:6px}.nav .dropdown-toggle:hover .caret,.nav .dropdown-toggle:focus .caret{border-top-color:#005580;border-bottom-color:#005580}.nav-tabs .dropdown-toggle .caret{margin-top:8px}.nav .active .dropdown-toggle .caret{border-top-color:#fff;border-bottom-color:#fff}.nav-tabs .active .dropdown-toggle .caret{border-top-color:#555;border-bottom-color:#555}.nav>.dropdown.active>a:hover,.nav>.dropdown.active>a:focus{cursor:pointer}.nav-tabs .open .dropdown-toggle,.nav-pills .open .dropdown-toggle,.nav>li.dropdown.open.active>a:hover,.nav>li.dropdown.open.active>a:focus{color:#fff;background-color:#999;border-color:#999}.nav li.dropdown.open .caret,.nav li.dropdown.open.active .caret,.nav li.dropdown.open a:hover .caret,.nav li.dropdown.open a:focus .caret{border-top-color:#fff;border-bottom-color:#fff;opacity:1;filter:alpha(opacity=100)}.tabs-stacked .open>a:hover,.tabs-stacked .open>a:focus{border-color:#999}.tabbable{*zoom:1}.tabbable:before,.tabbable:after{display:table;content:"";line-height:0}.tabbable:after{clear:both}.tab-content{overflow:auto}.tabs-below>.nav-tabs,.tabs-right>.nav-tabs,.tabs-left>.nav-tabs{border-bottom:0}.tab-content>.tab-pane,.pill-content>.pill-pane{display:none}.tab-content>.active,.pill-content>.active{display:block}.tabs-below>.nav-tabs{border-top:1px solid #ddd}.tabs-below>.nav-tabs>li{margin-top:-1px;margin-bottom:0}.tabs-below>.nav-tabs>li>a{-webkit-border-radius:0 0 4px 4px;-moz-border-radius:0 0 4px 4px;border-radius:0 0 4px 4px}.tabs-below>.nav-tabs>li>a:hover,.tabs-below>.nav-tabs>li>a:focus{border-bottom-color:transparent;border-top-color:#ddd}.tabs-below>.nav-tabs>.active>a,.tabs-below>.nav-tabs>.active>a:hover,.tabs-below>.nav-tabs>.active>a:focus{border-color:transparent #ddd #ddd}.tabs-left>.nav-tabs>li,.tabs-right>.nav-tabs>li{float:none}.tabs-left>.nav-tabs>li>a,.tabs-right>.nav-tabs>li>a{min-width:74px;margin-right:0;margin-bottom:3px}.tabs-left>.nav-tabs{float:left;margin-right:19px;border-right:1px solid #ddd}.tabs-left>.nav-tabs>li>a{margin-right:-1px;-webkit-border-radius:4px 0 0 4px;-moz-border-radius:4px 0 0 4px;border-radius:4px 0 0 4px}.tabs-left>.nav-tabs>li>a:hover,.tabs-left>.nav-tabs>li>a:focus{border-color:#eee #ddd #eee #eee}.tabs-left>.nav-tabs .active>a,.tabs-left>.nav-tabs .active>a:hover,.tabs-left>.nav-tabs .active>a:focus{border-color:#ddd transparent #ddd #ddd;*border-right-color:#fff}.tabs-right>.nav-tabs{float:right;margin-left:19px;border-left:1px solid #ddd}.tabs-right>.nav-tabs>li>a{margin-left:-1px;-webkit-border-radius:0 4px 4px 0;-moz-border-radius:0 4px 4px 0;border-radius:0 4px 4px 0}.tabs-right>.nav-tabs>li>a:hover,.tabs-right>.nav-tabs>li>a:focus{border-color:#eee #eee #eee #ddd}.tabs-right>.nav-tabs .active>a,.tabs-right>.nav-tabs .active>a:hover,.tabs-right>.nav-tabs .active>a:focus{border-color:#ddd #ddd #ddd transparent;*border-left-color:#fff}.nav>.disabled>a{color:#999}.nav>.disabled>a:hover,.nav>.disabled>a:focus{text-decoration:none;background-color:transparent;cursor:default}.tooltip{position:absolute;z-index:1030;display:block;visibility:visible;font-size:11px;line-height:1.4;opacity:0;filter:alpha(opacity=0)}.tooltip.in{opacity:.8;filter:alpha(opacity=80)}.tooltip.top{margin-top:-3px;padding:5px 0}.tooltip.right{margin-left:3px;padding:0 5px}.tooltip.bottom{margin-top:3px;padding:5px 0}.tooltip.left{margin-left:-3px;padding:0 5px}.tooltip-inner{max-width:200px;padding:8px;color:#fff;text-align:center;text-decoration:none;background-color:#000;-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px}.tooltip-arrow{position:absolute;width:0;height:0;border-color:transparent;border-style:solid}.tooltip.top .tooltip-arrow{bottom:0;left:50%;margin-left:-5px;border-width:5px 5px 0;border-top-color:#000}.tooltip.right .tooltip-arrow{top:50%;left:0;margin-top:-5px;border-width:5px 5px 5px 0;border-right-color:#000}.tooltip.left .tooltip-arrow{top:50%;right:0;margin-top:-5px;border-width:5px 0 5px 5px;border-left-color:#000}.tooltip.bottom .tooltip-arrow{top:0;left:50%;margin-left:-5px;border-width:0 5px 5px;border-bottom-color:#000}.popover{position:absolute;top:0;left:0;z-index:1010;display:none;max-width:276px;padding:1px;text-align:left;background-color:#fff;-webkit-background-clip:padding-box;-moz-background-clip:padding;background-clip:padding-box;border:1px solid #ccc;border:1px solid rgba(0,0,0,.2);-webkit-border-radius:6px;-moz-border-radius:6px;border-radius:6px;-webkit-box-shadow:0 5px 10px rgba(0,0,0,.2);-moz-box-shadow:0 5px 10px rgba(0,0,0,.2);box-shadow:0 5px 10px rgba(0,0,0,.2);white-space:normal}.popover.top{margin-top:-10px}.popover.right{margin-left:10px}.popover.bottom{margin-top:10px}.popover.left{margin-left:-10px}.popover-title{margin:0;padding:8px 14px;font-size:14px;font-weight:400;line-height:18px;background-color:#f7f7f7;border-bottom:1px solid #ebebeb;-webkit-border-radius:5px 5px 0 0;-moz-border-radius:5px 5px 0 0;border-radius:5px 5px 0 0}.popover-title:empty{display:none}.popover-content{padding:9px 14px}.popover .arrow,.popover .arrow:after{position:absolute;display:block;width:0;height:0;border-color:transparent;border-style:solid}.popover .arrow{border-width:11px}.popover .arrow:after{border-width:10px;content:""}.popover.top .arrow{left:50%;margin-left:-11px;border-bottom-width:0;border-top-color:#999;border-top-color:rgba(0,0,0,.25);bottom:-11px}.popover.top .arrow:after{bottom:1px;margin-left:-10px;border-bottom-width:0;border-top-color:#fff}.popover.right .arrow{top:50%;left:-11px;margin-top:-11px;border-left-width:0;border-right-color:#999;border-right-color:rgba(0,0,0,.25)}.popover.right .arrow:after{left:1px;bottom:-10px;border-left-width:0;border-right-color:#fff}.popover.bottom .arrow{left:50%;margin-left:-11px;border-top-width:0;border-bottom-color:#999;border-bottom-color:rgba(0,0,0,.25);top:-11px}.popover.bottom .arrow:after{top:1px;margin-left:-10px;border-top-width:0;border-bottom-color:#fff}.popover.left .arrow{top:50%;right:-11px;margin-top:-11px;border-right-width:0;border-left-color:#999;border-left-color:rgba(0,0,0,.25)}.popover.left .arrow:after{right:1px;border-right-width:0;border-left-color:#fff;bottom:-10px}.modal-backdrop{position:fixed;top:0;right:0;bottom:0;left:0;z-index:1040;background-color:#000}.modal-backdrop.fade{opacity:0}.modal-backdrop,.modal-backdrop.fade.in{opacity:.8;filter:alpha(opacity=80)}.modal{position:fixed;top:10%;left:50%;z-index:1050;width:560px;margin-left:-280px;background-color:#fff;border:1px solid #999;border:1px solid rgba(0,0,0,.3);*border:1px solid #999;-webkit-border-radius:6px;-moz-border-radius:6px;border-radius:6px;-webkit-box-shadow:0 3px 7px rgba(0,0,0,.3);-moz-box-shadow:0 3px 7px rgba(0,0,0,.3);box-shadow:0 3px 7px rgba(0,0,0,.3);-webkit-background-clip:padding-box;-moz-background-clip:padding-box;background-clip:padding-box;outline:0}.modal.fade{-webkit-transition:opacity .3s linear,top .3s ease-out;-moz-transition:opacity .3s linear,top .3s ease-out;-o-transition:opacity .3s linear,top .3s ease-out;transition:opacity .3s linear,top .3s ease-out;top:-25%}.modal.fade.in{top:10%}.modal-header{padding:9px 15px;border-bottom:1px solid #eee}.modal-header .close{margin-top:2px}.modal-header h3{margin:0;line-height:30px}.modal-body{position:relative;overflow-y:auto;max-height:400px;padding:15px}.modal-form{margin-bottom:0}.modal-footer{padding:14px 15px 15px;margin-bottom:0;text-align:right;background-color:#f5f5f5;border-top:1px solid #ddd;-webkit-border-radius:0 0 6px 6px;-moz-border-radius:0 0 6px 6px;border-radius:0 0 6px 6px;-webkit-box-shadow:inset 0 1px 0 #fff;-moz-box-shadow:inset 0 1px 0 #fff;box-shadow:inset 0 1px 0 #fff;*zoom:1}.modal-footer:before,.modal-footer:after{display:table;content:"";line-height:0}.modal-footer:after{clear:both}.modal-footer .btn+.btn{margin-left:5px;margin-bottom:0}.modal-footer .btn-group .btn+.btn{margin-left:-1px}.modal-footer .btn-block+.btn-block{margin-left:0}.accordion{margin-bottom:20px}.accordion-group{margin-bottom:2px;border:1px solid #e5e5e5;-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px}.accordion-heading{border-bottom:0}.accordion-heading .accordion-toggle{display:block;padding:8px 15px}.accordion-toggle{cursor:pointer}.accordion-inner{padding:9px 15px;border-top:1px solid #e5e5e5}.well{min-height:20px;padding:19px;margin-bottom:20px;background-color:#f5f5f5;border:1px solid #e3e3e3;-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.05);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.05);box-shadow:inset 0 1px 1px rgba(0,0,0,.05)}.well blockquote{border-color:#ddd;border-color:rgba(0,0,0,.15)}.well-large{padding:24px;-webkit-border-radius:6px;-moz-border-radius:6px;border-radius:6px}.well-small{padding:9px;-webkit-border-radius:3px;-moz-border-radius:3px;border-radius:3px}.close{float:right;font-size:20px;font-weight:700;line-height:20px;color:#000;text-shadow:0 1px 0 #fff;opacity:.2;filter:alpha(opacity=20)}.close:hover,.close:focus{color:#000;text-decoration:none;cursor:pointer;opacity:.4;filter:alpha(opacity=40)}button.close{padding:0;cursor:pointer;background:transparent;border:0;-webkit-appearance:none}.fade{opacity:0;-webkit-transition:opacity .15s linear;-moz-transition:opacity .15s linear;-o-transition:opacity .15s linear;transition:opacity .15s linear}.fade.in{opacity:1}.collapse{position:relative;height:0;overflow:hidden;-webkit-transition:height .35s ease;-moz-transition:height .35s ease;-o-transition:height .35s ease;transition:height .35s ease}.collapse.in{height:auto}#colorbox,#cboxOverlay,#cboxWrapper{position:absolute;top:0;left:0;z-index:9999;overflow:hidden}#cboxWrapper{max-width:none}#cboxOverlay{position:fixed;width:100%;height:100%}#cboxMiddleLeft,#cboxBottomLeft{clear:left}#cboxContent{position:relative}#cboxLoadedContent{overflow:auto;-webkit-overflow-scrolling:touch}#cboxTitle{margin:0}#cboxLoadingOverlay,#cboxLoadingGraphic{position:absolute;top:0;left:0;width:100%;height:100%}#cboxPrevious,#cboxNext,#cboxClose,#cboxSlideshow{cursor:pointer}.cboxPhoto{float:left;margin:auto;border:0;display:block;max-width:none;-ms-interpolation-mode:bicubic}.cboxIframe{width:100%;height:100%;display:block;border:0}#colorbox,#cboxContent,#cboxLoadedContent{box-sizing:content-box;-moz-box-sizing:content-box;-webkit-box-sizing:content-box}#cboxOverlay{background:url(../resources/colorbox/overlay.png) repeat 0 0}#colorbox{outline:0}#cboxTopLeft{width:25px;height:25px;background:url(../resources/colorbox/border1.png) no-repeat 0 0}#cboxTopCenter{height:25px;background:url(../resources/colorbox/border1.png) repeat-x 0 -50px}#cboxTopRight{width:25px;height:25px;background:url(../resources/colorbox/border1.png) no-repeat -25px 0}#cboxBottomLeft{width:25px;height:25px;background:url(../resources/colorbox/border1.png) no-repeat 0 -25px}#cboxBottomCenter{height:25px;background:url(../resources/colorbox/border1.png) repeat-x 0 -75px}#cboxBottomRight{width:25px;height:25px;background:url(../resources/colorbox/border1.png) no-repeat -25px -25px}#cboxMiddleLeft{width:25px;background:url(../resources/colorbox/border2.png) repeat-y 0 0}#cboxMiddleRight{width:25px;background:url(../resources/colorbox/border2.png) repeat-y -25px 0}#cboxContent{background:#fff;overflow:hidden}.cboxIframe{background:#fff}#cboxError{padding:50px;border:1px solid #ccc}#cboxLoadedContent{margin-bottom:20px}#cboxTitle{position:absolute;bottom:0;left:0;text-align:center;width:100%;color:#999}#cboxCurrent{position:absolute;bottom:0;left:100px;color:#999}#cboxLoadingOverlay{background:#fff url(../resources/colorbox/loading.gif) no-repeat 5px 5px}#cboxPrevious,#cboxNext,#cboxSlideshow,#cboxClose{border:0;padding:0;margin:0;overflow:visible;width:auto;background:0 0}#cboxPrevious:active,#cboxNext:active,#cboxSlideshow:active,#cboxClose:active{outline:0}#cboxSlideshow{position:absolute;bottom:0;right:42px;color:#444}#cboxPrevious{position:absolute;bottom:0;left:0;color:#444}#cboxNext{position:absolute;bottom:0;left:63px;color:#444}#cboxClose{position:absolute;bottom:0;right:0;display:block;color:#444}.cboxIE #cboxTopLeft,.cboxIE #cboxTopCenter,.cboxIE #cboxTopRight,.cboxIE #cboxBottomLeft,.cboxIE #cboxBottomCenter,.cboxIE #cboxBottomRight,.cboxIE #cboxMiddleLeft,.cboxIE #cboxMiddleRight{filter:progid:DXImageTransform.Microsoft.gradient(startColorstr=#00FFFFFF, endColorstr=#00FFFFFF)}#cboxCurrent,#cboxPrevious,#cboxNext{display:none}#cboxTitle{height:15px;font:12px/1.2 Verdana,sans-serif}#cboxClose{position:absolute;bottom:0;right:0;background:url(../resources/colorbox/controls.png) no-repeat 2px 0;width:16px;height:14px;text-indent:-9999px}#cboxClose:hover{background-position:2px -25px}#cboxLoadedContent{overflow:hidden!important}#cboxLoadedContent>iframe{width:100%;height:100%;border:0}.sp-container{position:absolute;top:0;left:0;display:inline-block;*display:inline;*zoom:1;z-index:2147483647;overflow:hidden}.sp-container.sp-flat{position:relative}.sp-top{position:relative;width:100%;display:inline-block}.sp-top-inner{position:absolute;top:0;left:0;bottom:0;right:0}.sp-color{position:absolute;top:0;left:0;bottom:0;right:20%}.sp-hue{position:absolute;top:0;right:0;bottom:0;left:84%;height:100%}.sp-fill{padding-top:80%}.sp-sat,.sp-val{position:absolute;top:0;left:0;right:0;bottom:0}.sp-alpha-enabled .sp-top{margin-bottom:18px}.sp-alpha-enabled .sp-alpha{display:block}.sp-alpha-handle{position:absolute;top:-4px;bottom:-4px;width:6px;left:50%;cursor:pointer;border:1px solid #000;background:#fff;opacity:.8}.sp-alpha{display:none;position:absolute;bottom:-14px;right:0;left:0;height:8px}.sp-alpha-inner{border:solid 1px #333}.sp-container,.sp-replacer,.sp-preview,.sp-dragger,.sp-slider,.sp-alpha,.sp-alpha-handle,.sp-container.sp-dragging .sp-input,.sp-container button{-webkit-user-select:none;-moz-user-select:-moz-none;-o-user-select:none;user-select:none}.sp-container.sp-input-disabled .sp-input-container{display:none}.sp-container.sp-buttons-disabled .sp-button-container{display:none}.sp-palette-only .sp-picker-container{display:none}.sp-palette-disabled .sp-palette-container{display:none}.sp-initial-disabled .sp-initial{display:none}.sp-sat{background-image:-webkit-gradient(linear,0 0,100% 0,from(#FFF),to(rgba(204,154,129,0)));background-image:-webkit-linear-gradient(left,#FFF,rgba(204,154,129,0));background-image:-moz-linear-gradient(left,#fff,rgba(204,154,129,0));background-image:-o-linear-gradient(left,#fff,rgba(204,154,129,0));background-image:-ms-linear-gradient(left,#fff,rgba(204,154,129,0));background-image:linear-gradient(to right,#fff,rgba(204,154,129,0));-ms-filter:"progid:DXImageTransform.Microsoft.gradient(GradientType = 1, startColorstr=#FFFFFFFF, endColorstr=#00CC9A81)";filter:progid:DXImageTransform.Microsoft.gradient(GradientType=1, startColorstr='#FFFFFFFF', endColorstr='#00CC9A81')}.sp-val{background-image:-webkit-gradient(linear,0 100%,0 0,from(#000),to(rgba(204,154,129,0)));background-image:-webkit-linear-gradient(bottom,#000,rgba(204,154,129,0));background-image:-moz-linear-gradient(bottom,#000,rgba(204,154,129,0));background-image:-o-linear-gradient(bottom,#000,rgba(204,154,129,0));background-image:-ms-linear-gradient(bottom,#000,rgba(204,154,129,0));background-image:linear-gradient(to top,#000,rgba(204,154,129,0));-ms-filter:"progid:DXImageTransform.Microsoft.gradient(startColorstr=#00CC9A81, endColorstr=#FF000000)";filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#00CC9A81', endColorstr='#FF000000')}.sp-hue{background:-moz-linear-gradient(top,red 0,#ff0 17%,#0f0 33%,#0ff 50%,#00f 67%,#f0f 83%,red 100%);background:-ms-linear-gradient(top,red 0,#ff0 17%,#0f0 33%,#0ff 50%,#00f 67%,#f0f 83%,red 100%);background:-o-linear-gradient(top,red 0,#ff0 17%,#0f0 33%,#0ff 50%,#00f 67%,#f0f 83%,red 100%);background:-webkit-gradient(linear,left top,left bottom,from(red),color-stop(0.17,#ff0),color-stop(0.33,#0f0),color-stop(0.5,#0ff),color-stop(0.67,#00f),color-stop(0.83,#f0f),to(red));background:-webkit-linear-gradient(top,red 0,#ff0 17%,#0f0 33%,#0ff 50%,#00f 67%,#f0f 83%,red 100%)}.sp-1{height:17%;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff0000', endColorstr='#ffff00')}.sp-2{height:16%;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffff00', endColorstr='#00ff00')}.sp-3{height:17%;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#00ff00', endColorstr='#00ffff')}.sp-4{height:17%;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#00ffff', endColorstr='#0000ff')}.sp-5{height:16%;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#0000ff', endColorstr='#ff00ff')}.sp-6{height:17%;filter:progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff00ff', endColorstr='#ff0000')}.sp-cf:before,.sp-cf:after{content:"";display:table}.sp-cf:after{clear:both}.sp-cf{*zoom:1}@media (max-device-width:480px){.sp-color{right:40%}.sp-hue{left:63%}.sp-fill{padding-top:60%}}.sp-dragger{border-radius:5px;height:5px;width:5px;border:1px solid #fff;background:#000;cursor:pointer;position:absolute;top:0;left:0}.sp-slider{position:absolute;top:0;cursor:pointer;height:3px;left:-1px;right:-1px;border:1px solid #000;background:#fff;opacity:.8}.sp-container{border-radius:0;background-color:#ECECEC;border:solid 1px #f0c49B;padding:0}.sp-container,.sp-container button,.sp-container input,.sp-color,.sp-hue{font:400 12px "Lucida Grande","Lucida Sans Unicode","Lucida Sans",Geneva,Verdana,sans-serif;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;-ms-box-sizing:border-box;box-sizing:border-box}.sp-top{margin-bottom:3px}.sp-color,.sp-hue{border:solid 1px #666}.sp-input-container{float:right;width:100px;margin-bottom:4px}.sp-initial-disabled .sp-input-container{width:100%}.sp-input{font-size:12px!important;border:1px inset;padding:4px 5px;margin:0;width:100%;background:transparent;border-radius:3px;color:#222}.sp-input:focus{border:1px solid orange}.sp-input.sp-validation-error{border:1px solid red;background:#fdd}.sp-picker-container,.sp-palette-container{float:left;position:relative;padding:10px;padding-bottom:300px;margin-bottom:-290px}.sp-picker-container{width:172px;border-left:solid 1px #fff}.sp-palette-container{border-right:solid 1px #ccc}.sp-palette .sp-thumb-el{display:block;position:relative;float:left;width:24px;height:15px;margin:3px;cursor:pointer;border:solid 2px transparent}.sp-palette .sp-thumb-el:hover,.sp-palette .sp-thumb-el.sp-thumb-active{border-color:orange}.sp-thumb-el{position:relative}.sp-initial{float:left;border:solid 1px #333}.sp-initial span{width:30px;height:25px;border:0;display:block;float:left;margin:0}.sp-button-container{float:right}.sp-replacer{margin:0;overflow:hidden;cursor:pointer;padding:4px;display:inline-block;*zoom:1;*display:inline;border:solid 1px #91765d;background:#eee;color:#333;vertical-align:middle}.sp-replacer:hover,.sp-replacer.sp-active{border-color:#F0C49B;color:#111}.sp-replacer.sp-disabled{cursor:default;border-color:silver;color:silver}.sp-dd{padding:2px 0;height:16px;line-height:16px;float:left;font-size:10px}.sp-preview{position:relative;width:25px;height:20px;border:solid 1px #222;margin-right:5px;float:left;z-index:0}.sp-palette{*width:220px;max-width:220px}.sp-palette .sp-thumb-el{width:16px;height:16px;margin:2px 1px;border:solid 1px #d0d0d0}.sp-container{padding-bottom:0}.sp-container button{background-color:#eee;background-image:-webkit-linear-gradient(top,#eee,#ccc);background-image:-moz-linear-gradient(top,#eee,#ccc);background-image:-ms-linear-gradient(top,#eee,#ccc);background-image:-o-linear-gradient(top,#eee,#ccc);background-image:-ms-linear-gradient(top,#eee,#ccc);background-image:linear-gradient(to bottom,#eee,#ccc);border:1px solid #ccc;border-bottom:1px solid #bbb;border-radius:3px;color:#333;font-size:14px;line-height:1;padding:5px 4px;text-align:center;text-shadow:0 1px 0 #eee;vertical-align:middle}.sp-container button:hover{background-color:#ddd;background-image:-webkit-linear-gradient(top,#ddd,#bbb);background-image:-moz-linear-gradient(top,#ddd,#bbb);background-image:-ms-linear-gradient(top,#ddd,#bbb);background-image:-o-linear-gradient(top,#ddd,#bbb);background-image:-ms-linear-gradient(top,#ddd,#bbb);background-image:linear-gradient(to bottom,#ddd,#bbb);border:1px solid #bbb;border-bottom:1px solid #999;cursor:pointer;text-shadow:0 1px 0 #ddd}.sp-container button:active{border:1px solid #aaa;border-bottom:1px solid #888;-webkit-box-shadow:inset 0 0 5px 2px #aaa,0 1px 0 0 #eee;-moz-box-shadow:inset 0 0 5px 2px #aaa,0 1px 0 0 #eee;-ms-box-shadow:inset 0 0 5px 2px #aaa,0 1px 0 0 #eee;-o-box-shadow:inset 0 0 5px 2px #aaa,0 1px 0 0 #eee;box-shadow:inset 0 0 5px 2px #aaa,0 1px 0 0 #eee}.sp-cancel{font-size:11px;color:#d93f3f!important;margin:0;padding:2px;margin-right:5px;vertical-align:middle;text-decoration:none}.sp-cancel:hover{color:#d93f3f!important;text-decoration:underline}.sp-palette span:hover,.sp-palette span.sp-thumb-active{border-color:#000}.sp-preview,.sp-alpha,.sp-thumb-el{position:relative;background-image:url(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAwAAAAMCAIAAADZF8uwAAAAGUlEQVQYV2M4gwH+YwCGIasIUwhT25BVBADtzYNYrHvv4gAAAABJRU5ErkJggg==)}.sp-preview-inner,.sp-alpha-inner,.sp-thumb-inner{display:block;position:absolute;top:0;left:0;bottom:0;right:0}.sp-palette .sp-thumb-inner{background-position:50% 50%;background-repeat:no-repeat}.sp-palette .sp-thumb-light.sp-thumb-active .sp-thumb-inner{background-image:url(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABIAAAASCAYAAABWzo5XAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAIVJREFUeNpiYBhsgJFMffxAXABlN5JruT4Q3wfi/0DsT64h8UD8HmpIPCWG/KemIfOJCUB+Aoacx6EGBZyHBqI+WsDCwuQ9mhxeg2A210Ntfo8klk9sOMijaURm7yc1UP2RNCMbKE9ODK1HM6iegYLkfx8pligC9lCD7KmRof0ZhjQACDAAceovrtpVBRkAAAAASUVORK5CYII=)}.sp-palette .sp-thumb-dark.sp-thumb-active .sp-thumb-inner{background-image:url(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABIAAAASCAYAAABWzo5XAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAAadEVYdFNvZnR3YXJlAFBhaW50Lk5FVCB2My41LjEwMPRyoQAAAMdJREFUOE+tkgsNwzAMRMugEAahEAahEAZhEAqlEAZhEAohEAYh81X2dIm8fKpEspLGvudPOsUYpxE2BIJCroJmEW9qJ+MKaBFhEMNabSy9oIcIPwrB+afvAUFoK4H0tMaQ3XtlrggDhOVVMuT4E5MMG0FBbCEYzjYT7OxLEvIHQLY2zWwQ3D+9luyOQTfKDiFD3iUIfPk8VqrKjgAiSfGFPecrg6HN6m/iBcwiDAo7WiBeawa+Kwh7tZoSCGLMqwlSAzVDhoK+6vH4G0P5wdkAAAAASUVORK5CYII=)};.modal-backdrop{opacity:.6;filter:alpha(opacity=60)}.popover{color:#000;-ms-user-select:none}#init-import-views{display:none}.modal-footer .error,.modal-footer .success,.modal-footer .addSpinner{display:none;float:left;vertical-align:-4px;margin-top:6px;font-size:14px;color:#c43d40;font-weight:700}.builderMobile{display:none}.modal-footer .success{color:#30750a}.modal-footer .addSpinner{margin-left:8px}#builderPanel{position:absolute;top:0;display:none;z-index:500;text-align:center;word-wrap:break-word;height:100px;padding:15px 20px 0}#builderPanel>div>button{margin:0}#builderPanel>div>button:nth-child(1){min-width:83px}#builderPanel button.small{padding-left:4px;padding-right:4px}#builderPanel .leftPanel{width:132px;text-align:left}#builderPanel h4{color:#fff;margin:1px 0 2px 4px;line-height:22px;font-weight:400}#status-bar{display:inline-block;margin-top:6px;margin-left:1px;font-size:12px;color:#999}#builderPanel .popover-content{padding:6px 10px}#builderPanel .builder-item i.icon-file{width:20px;background-position:-21px -23px;opacity:.7;height:18px}.save-popover{width:170px;z-index:5555;color:#30750A;font-weight:700;font-size:14px}.builder-save{margin-left:12px}.builder-settings{margin-left:11px}.save-popover-2{text-align:center;min-height:40px;min-width:280px!important;max-width:360px!important;color:#30750A;font-weight:700;font-size:14px}.save-popover-2 .popover-title{display:none}.datawarning-popover{max-width:420px!important;width:420px}.datawarning-popover .btn{vertical-align:1px}.datawarning-popover .popover-title{display:none}.hide{display:none}.sp-input-container{height:16px!important}.saveErrorPopupSocial .modal-body{overflow-y:visible}.saveErrorPopupSocial .tooltip.in{opacity:1}.saveErrorPopupSocial .panel1 .tooltip-inner{max-width:266px!important;width:266px;padding-bottom:8px}.saveErrorPopupSocial .panel2{margin-top:10px}.saveErrorPopupSocial .panel3{margin-top:25px}.saveErrorPopupSocial .panel2 .form-group{margin-left:10px}.saveErrorPopupSocial .stop-asking{float:left;margin-top:5px;margin-left:10px}.saveErrorPopupSocial .stop-asking label.disabled{color:#CCC;cursor:not-allowed}#settingsPopup{overflow:hidden}@media only screen and (max-height :708px){#settingsPopup{top:50%;margin-top:-315px}}@media only screen and (max-height :630px){#settingsPopup{top:0;margin-top:0}}#settingsPopup,#settingsPopup .modal-body{max-height:none}.settingsPopupHeader{width:100%;margin-top:-3px}#settingsPopup .tab{width:auto;min-width:inherit;padding:5px 12px 5px 10px}#settingsPopup .tab.disabled{opacity:.5;cursor:default}.settingsPopupHeader button{border-radius:0!important;width:34%}#settings-colors p{margin-bottom:20px}#settings-colors input[type=radio]{cursor:pointer}#settings-colors .radio{cursor:pointer}#settings-colors .swatch{width:25px;height:17px;border:solid;border-width:thin;border-color:#CCC;margin-left:4px}#settings-colors .caption{font-size:12px}#settings-colors td{padding-right:4px;padding-bottom:4px}#settings-extent p{margin-bottom:20px}#settings-extent #extentMap{width:100%!important;height:337px!important}#settings-extent #extentMap .logo-sm{display:none}#settings-extent .extentMapControl{margin-bottom:4px}#settings-extent .explain2{margin-top:10px}#settings-extent .dateLineError{display:none;font-weight:700;font-size:14px;color:#c43d40;padding-top:8px}#settings-header p{margin-bottom:20px}#settings-header img{float:right;max-width:250px;max-height:50px}#settings-header .form1 .controls{float:left;margin-left:65px;width:290px}#settings-header .form2 .control-label{width:50px}#settings-header .form2 .control-group{margin-bottom:10px}#settings-header .form2 .control-group:nth-child(2){margin-bottom:0}#settings-header .form2 .controls{margin-left:65px}#settings-header .form2 .socialConfig{position:absolute;left:370px;margin-top:-2px}#settings-header .form2 .socialConfig label.disabled{opacity:.5}#settings-header #headerSimulator{padding:5px 5px 0 0;float:left;width:140px;height:55px;background-color:#666}#settings-header .optionsLogoCustom{margin-left:25px}#settings-header #logoTargetInput{margin-top:10px;display:block}#settings-colors .sp-input-container{height:16px!important}html,body{height:100%;width:100%;margin:auto}@font-face{font-family:open_sansregular;src:url(../resources/font/OpenSans-Regular-webfont.eot);src:url(../resources/font/OpenSans-Regular-webfont.eot?#iefix) format('embedded-opentype'),url(../resources/font/OpenSans-Regular-webfont.woff) format('woff'),url(../resources/font/OpenSans-Regular-webfont.ttf) format('truetype'),url(../resources/font/OpenSans-Regular-webfont.svg#open_sansregular) format('svg');font-weight:400;font-style:normal}@font-face{font-family:open_sanssemibold;src:url(../resources/font/OpenSans-Semibold-webfont.eot);src:url(../resources/font/OpenSans-Semibold-webfont.eot?#iefix) format('embedded-opentype'),url(../resources/font/OpenSans-Semibold-webfont.woff) format('woff'),url(../resources/font/OpenSans-Semibold-webfont.ttf) format('truetype'),url(../resources/font/OpenSans-Semibold-webfont.svg#open_sanssemibold) format('svg');font-weight:700;font-style:normal}body{position:fixed;bottom:0;background-color:#E5E5E5;color:#333;overflow:hidden;font-family:open_sansregular,sans-serif}body.mobile-view{position:initial;bottom:initial}html,body,h1,h2,h3,h4,h5,h6,p,ul,form{margin:0;padding:0}img{border:0;outline:0}textarea{resize:none}#contentPanel{width:100%;height:60%}.bingLogo-lg{display:none}a{color:#555;font-weight:700;text-decoration:none;cursor:pointer}a:hover{text-decoration:underline}::-webkit-scrollbar{width:8px}::-webkit-scrollbar-thumb{background:#888;-webkit-box-shadow:inset 0 0 6px rgba(0,0,0,.5)}::-webkit-scrollbar-track{-webkit-box-shadow:inset 0 0 6px rgba(0,0,0,.3)}.modal-header{border-bottom:0;-webkit-border-top-left-radius:4px;-webkit-border-top-right-radius:4px;-moz-border-radius-topleft:4px;-moz-border-radius-topright:4px;border-top-left-radius:4px;border-top-right-radius:4px}.modal-header h3{color:#fff;font-weight:400;margin-bottom:5px}.modal-tabs,.modal-header{background-color:#848484}.modal-tabs .tab:nth-child(1){margin-left:15px}.tab{display:inline-block;min-width:120px;background-color:#bababa;color:#444;padding:5px;font:12px;-webkit-border-radius:5px 5px 0 0;border-radius:5px 5px 0 0;cursor:pointer;height:21px}.tab.active{background-color:#fff;cursor:default}#fatalError{position:absolute;display:none;z-index:999;top:50%;left:0;width:100%}#fatalError>table{margin-top:-100px;margin-left:-247px;max-width:490px;min-height:85px;background-color:#fff;border:2px solid #333;padding:0;margin-left:auto;margin-right:auto}#fatalError .error-title{margin-right:12px}#fatalError .error-msg{margin-top:8px;padding-bottom:8px;margin-right:8px}#fatalError-icon{background:url(../resources/icons/errorbox-close.png) 0 0;width:75px;height:75px;background-repeat:no-repeat}#addPopup{overflow:visible}@media only screen and (max-height :708px){#addPopup{top:50%;margin-top:-284px}}@media only screen and (max-height :567px){#addPopup{top:0;margin-top:0}}.modal .modal-body{max-height:none}#addPopup .modal-body{overflow:visible}.addPopupHeader{width:100%;margin-top:-3px}.addPopupHeader button{border-radius:0!important;width:34%}#addPopup label{font-weight:700;display:block}#addPopup input{display:block;margin-bottom:10px}#addPopup .locationForm input{border:1px solid #ccc;color:#555;-webkit-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);-moz-box-shadow:inset 0 1px 1px rgba(0,0,0,.075);box-shadow:inset 0 1px 1px rgba(0,0,0,.075)}.tab-icon{float:right;margin-left:5px}.errorList{font-weight:700;font-size:14px;color:#c43d40;list-style:none;padding-left:0}.maxPictureReached{display:none}#addPopup .imageUploadWrapper{color:#FFF;height:380px;border:4px dashed #848484}#addImageUploadFormPicture{text-align:center}.addNoteVideo{position:absolute;bottom:25px;left:0;font-size:14px;font-style:italic;width:100%;color:#000}.addNoteVideo>div{padding-left:20px;padding-right:20px}.pictureSize{margin-top:4px;font-size:13px;font-weight:700;text-align:left}.pictureSize input{display:inline-block!important;vertical-align:-5px!important;margin:0 4px 2px 10px!important}.imageUploadWrapper a{margin-top:160px}.leftPanel{display:table-cell;width:320px;text-align:center;vertical-align:middle;float:left}.imagePreview{max-width:100%;max-height:300px}.imagePreviewName{font-size:18px;font-weight:700;padding-bottom:5px;border-bottom:1px #ccc solid;word-wrap:break-word}.rightPanel{float:right;max-height:400px;width:200px}.rightPanel .thumbnail .thumbnailFile{display:none}.rightPanel .thumbnail canvas{background-color:grey}.rightPanel .thumbnail .thumbnailForm{display:none}.cameraSettings{margin-top:5px;font-size:14px}.settingHeading{font-size:12px;font-weight:700;margin-top:15px;margin-bottom:5px;color:#888}.exifMinor{position:relative}.cameraSmallSettings{display:inline;background-color:#dadada;padding:3px;margin-right:5px;font-size:11px;color:#777;line-height:2.5em;border:1px solid #999;-webkit-border-radius:3px;border-radius:3px;white-space:nowrap}.changeThumbnail{color:#444;font-size:10px;cursor:pointer}#addImageAttributesTypeChooser{margin-bottom:13px}.addImageAttributes .video{display:none}.addImageAttributes td:nth-child(2){padding-left:20px}.addImageAttributes tr.fade{opacity:.5}.addImageAttributes img.click{cursor:pointer;width:17px;vertical-align:1px}.addImageAttributes img{margin-left:3px}.addImageAttributes a img{margin-left:2px}.addImageAttributes i{vertical-align:4px;margin-left:3px;display:inline-block}.addImageAttributes i.icon-exclamation-sign{vertical-align:3px}.addImageAttributes .video input{display:inline-block!important}.addImageAttributes .video input[type=radio]{margin-right:5px}.addImageAttributes .video input[type=text]{width:250px!important}.addImageAttributes .video input[type=text].type{width:310px!important}.addImageAttributes .video input[type=text].tourPointThumbUrl2{width:465px!important}.addImageAttributes input[type=text]{width:97%}.video1-popover{min-width:410px;width:410px;max-width:410px!important}.video2-popover{min-width:350px}.addText input,.addText textarea{position:relative;left:0;top:0;width:97%}.addLocation label,.addLocation input{display:inline!important}.addLocation label:not(:first-child){margin-left:8px}.addLocation input{width:80px;font-size:12px;height:14px;vertical-align:2px;width:54px}.pinSelector{width:22px;padding:3px;-webkit-border-radius:3px;border-radius:3px;cursor:pointer;vertical-align:-3px}.pinSelector.selected{border:2px solid #666;padding-left:5px}#locateMap{position:relative;width:100%;height:337px}#geocoder{display:block;position:absolute;z-index:30;bottom:20px;left:20px}#geocoder input{box-shadow:none;-moz-box-shadow:none;-webkit-box-shadow:none}#geocoder .esriGeocoderActive{border-bottom:2px solid #666}#builderPanel2{position:absolute;display:none;z-index:500;min-width:180px;bottom:150px;text-align:center;background-color:#E5E5E5;-webkit-border-top-left-radius:4px;-webkit-border-top-right-radius:4px;-moz-border-radius-topleft:4px;-moz-border-radius-topright:4px;border-top-left-radius:4px;border-top-right-radius:4px;padding:8px 11px 4px 3px;height:30px}#builderPanel2 .text_edit_icon{vertical-align:-4px}#organizeSlidesButton,#addPopupButton,#importPopupButton{min-width:85px;margin-left:7px}#builderPanel3{position:absolute;display:none;z-index:499;min-width:58px;bottom:150px;left:30px;text-align:center;background-color:#E5E5E5;-webkit-border-top-left-radius:4px;-webkit-border-top-right-radius:4px;-moz-border-radius-topleft:4px;-moz-border-radius-topright:4px;border-top-left-radius:4px;border-top-right-radius:4px;padding:8px 10px 4px;height:30px}.colorSelectorPin{height:27px;padding:6px;margin-top:3px;cursor:pointer}.selectedColor{border-radius:4px;background-color:#777;cursor:default}#browserPopup{top:27%!important}#browserPopup .browserExplain2{margin-top:15px}#basemapChooser{position:absolute;right:5px;top:5px;z-index:401;display:none}body.mobile-view #basemapChooser{display:none!important}#basemapChooser .esriBasemapGalleryLabelContainer{font-size:14px}textarea{resize:none}.modal-footer .error,.modal-footer .success,.modal-footer .addSpinner{display:none;float:left;vertical-align:-4px;margin-top:6px;font-size:14px;color:#c43d40;font-weight:700}.modal-footer .success{color:#30750a}.modal-footer .addSpinner{margin-left:8px}@media only screen and (max-height :708px){#helpPopup{top:50%!important;margin-top:-304px}}@media only screen and (max-height :607px){#helpPopup{top:0!important;margin-top:0}}#helpPopup .modal-body{height:359px}@media only screen and (min-device-width :768px) and (max-device-width :1024px) and (orientation :landscape){#helpPopup .modal-body{height:370px}}#helpPopup .tab{min-width:0}#helpPopup a{font-weight:400;text-decoration:underline}#helpPopup ul{margin-left:30px}@media only screen and (max-height :708px){#importPopup{top:50%;margin-top:-304px}}@media only screen and (max-height :608px){#importPopup{top:0;margin-top:0}}#importPopup .modal-body{overflow:visible}#importPopupViewHome .header{text-align:center;margin-bottom:12px}#importPopupViewHome table{width:100%;text-align:center;margin-left:-5px}#importPopupViewHome td{font-weight:400;width:20%;border:1px solid rgba(0,0,0,0);padding:18px;vertical-align:top}#importPopupViewHome td.disabled{opacity:.4;cursor:default!important}#importPopupViewHome td.disabled a{cursor:default!important}#importPopupViewHome td div{margin-top:2px}#importPopupViewHome td:hover{background-color:#C7C4C4;cursor:pointer;border:1px solid #757575;border-radius:10px}#importPopupViewHome .footer{margin-top:15px}#importPopupViewHome a{margin-top:4px;font-weight:400;text-decoration:underline}@media only screen and (max-height :708px){#initPopup{top:50%!important;margin-top:-304px}}@media only screen and (max-height :608px){#initPopup{top:0!important;margin-top:0}}#initPopup .modal-footer{min-height:32px}#initPopup .modal-body{overflow:visible}#initPopup .popover{font-size:14px;font-weight:initial;line-height:initial}#initPopupViewAdvanced .header{margin-bottom:15px;text-align:center;font-size:24px;font-weight:700}#initPopupViewAdvanced .options{width:100%;text-align:center}#initPopupViewAdvanced .btn-adv{width:310px}#initPopupViewAdvanced .csv-note{margin-top:5px;margin-bottom:10px}#initPopupViewAdvanced .csv-note a{text-decoration:underline;font-size:14px}#initPopupViewHome .header{margin-bottom:25px;text-align:center;font-size:24px;font-weight:700}#initPopupViewHome .sideContainer{display:inline-block;text-align:center;padding-top:10px;padding-bottom:15px;vertical-align:top}#initPopupViewHome .sideContainer:nth-child(2){width:50%;border-right:1px solid #000}#initPopupViewHome .sideContainer:nth-child(3){width:49%}#initPopupViewHome .sideTitle{font-weight:700;margin-bottom:25px}#initPopupViewHome table{width:100%;text-align:center}#initPopupViewHome td{font-weight:400;width:33%;border:1px solid rgba(0,0,0,0);padding:4px}#initPopupViewHome td.disabled{opacity:.4;cursor:default!important}#initPopupViewHome td.disabled a{cursor:default!important}#initPopupViewHome td div{margin-top:2px}#initPopupViewHome td:not(.disabled):hover{background-color:#C7C4C4;cursor:pointer;border:1px solid #757575;border-radius:10px}#initPopupViewHome .leftTable{margin-left:-5px}#initPopupViewHome .scratchLbl{margin-top:5px}#initPopupViewHome .disabled{opacity:.3}#initPopupViewHome .btn-select-hostedFS.disabled{opacity:1}#initPopupViewHome .btn-select-hostedFS.disabled img{opacity:.3}#initPopupViewHome .btn-select-hostedFS.disabled .hostedFsNote{color:grey}#initPopupViewHome .btn-select-hostedFS.disabled .hostedFsNote a{cursor:pointer!important}#initPopupViewHome .notAvailable{display:none;margin-top:10px;font-size:12px;font-weight:700}#initPopupViewHome .popover-init{margin-top:8px}#initPopupViewHome .popover-init .popover{max-width:245px}#initPopupViewHome .footer{margin-top:15px;text-align:center;text-decoration:underline}#initPopupViewHome a{display:block}.dataExplain{margin-bottom:20px;line-height:19px}.dataNameLbl,.dataFolderListLbl{width:290px}.dataError{font-weight:700;font-size:14px;color:#C43D40;list-style:none;padding-left:0}.dataFooterText{display:none;float:left;margin-top:6px;font-size:14px;color:#30750a;font-weight:700;padding-top:2px}.dataFooterText .error{color:red}.dataFooterText img{vertical-align:-2px}@media only screen and (max-height :708px){#organizePopup{top:50%;margin-top:-290px}}@media only screen and (max-height :577px){#organizePopup{top:0;margin-top:0}}#organizePopup .modal-body{overflow:hidden;max-height:500px}#organizePopup .gridContainer{width:490px;height:350px;overflow:auto;margin-top:10px;margin-left:15px;-webkit-overflow-scrolling:touch;-ms-touch-action:none}#organizePopup .organizeHeader .generalCaption{margin-left:40px;padding-top:8px}#organizePopup .organizeHeader .buttonBar{float:right;margin-right:40px}#organizePopup .picturesGrid{margin-left:10px;margin-top:10px}#organizePopup .picturesGrid li{text-align:center;list-style:none;float:left;width:130px;height:90px;overflow:hidden;background-color:#999;margin-left:15px;margin-right:5px;margin-bottom:10px;position:relative;cursor:pointer}#organizePopup .picturesGrid img{cursor:pointer;max-width:120px;max-height:80px;margin-top:5px}#organizePopup .numberLabel{background-color:red;width:20px;height:20px;position:absolute;top:5px;left:5px;text-align:center;color:#fff}#organizePopup .number-blue{background-color:#1880f3}#organizePopup .number-red{background-color:red}#organizePopup .number-green{background-color:#369A22}#organizePopup .number-purple{background-color:#8A26FD}#organizePopup .number-orange{background-color:#E67E22}#organizePopup .veil{position:absolute;width:100%;height:100%;background-color:#000;top:0;opacity:.7;display:none;cursor:pointer}#organizePopup .halo{position:absolute;top:0;left:0;border:solid;border-width:3px;border-color:red;cursor:pointer;display:none}#organizePopup #btnHide,#btnDelete{min-width:85px}#organizePopup .savePopover{width:260px}#organizePopup .organizeFooter{margin-top:6px}#organizePopup .organizeIntro{margin-left:5px}#organizePopup .btnReset{float:right}.popupViewCSV .csvUploadWrapper{color:#FFF;height:380px;width:100%;border:4px dashed #848484;margin-left:-4px;text-align:center}.popupViewCSV .csvUploadWrapper a{margin-top:160px}.popupViewCSV .csvResultMap{width:350px!important}.popupViewCSV .csvResultFields{float:right;width:170px;text-align:left}.popupViewCSV .csvResultFields ul{margin-left:25px}.popupViewCSV .csvResultHeader{margin-bottom:10px}.popupViewCSV .csvResultHeader ul{margin-left:30px}.popupViewCSV .csvResultHeader.error{font-weight:400;color:#c43d40}.popupViewFlickr .headerContainer{margin-bottom:15px}.popupViewFlickr .btn-userLogin{vertical-align:4px;margin-bottom:15px}.popupViewFlickr .signInMsg{font-size:14px;color:#30750a;font-weight:700;vertical-align:2px}.popupViewFlickr .signInMsg.error{color:#c43d40}.popupViewFlickr .signInMsg img{vertical-align:-2px}.popupViewFlickr .selectContainer{width:49%;display:inline-block;text-align:center;padding-top:10px;padding-bottom:15px}.popupViewFlickr .selectContainer:nth-child(1){border-right:1px solid #000}.popupViewGeoTag .header{margin-bottom:15px}.popupViewGeoTag .header a{font-weight:400;text-decoration:underline}.popupViewGeoTag .leftPanel{width:220px;height:400px}.popupViewGeoTag .nav-tabs{font-size:12px;margin-bottom:0}.popupViewGeoTag .tab-content>div{display:none;width:210px;height:362px;overflow-x:hidden;padding-right:5px}.popupViewGeoTag .tab-content li{margin-bottom:10px;font-size:10px;text-align:center}.popupViewGeoTag .tab-content img{max-width:100%}.popupViewGeoTag .tobelocated li{display:table;text-align:center;width:202px;border:2px solid transparent;cursor:pointer}.popupViewGeoTag .tobelocated li.clicked{border:2px dashed #52a552}.popupViewGeoTag .tobelocated li>div{display:table-cell;vertical-align:middle;text-align:center}.popupViewGeoTag .tobelocated .geotagPicName{width:202px}.popupViewGeoTag .tobelocated button{display:none}.popupViewGeoTag .located li>div{position:relative}.popupViewGeoTag .located button{display:none;font-size:80px;position:absolute;top:50%;opacity:1;left:50%;margin-top:-60px;line-height:inherit;margin-left:-24px}.popupViewGeoTag .located li:hover button{display:block}.popupViewGeoTag .clearLocation{margin-bottom:4px;font-weight:400}.popupViewGeoTag .geotagMap{width:300px;height:400px}.popupViewGeoTag .geotagMap{border:4px dashed transparent}.popupViewGeoTag .geotagMap .logo-med{display:none}.popupViewGeoTag .clickOrTapInfo{display:none;opacity:0;position:absolute;top:235px;left:305px;z-index:9999;background-color:#FFF;border:2px dashed #52a552;padding:4px;font-weight:700;width:160px;text-align:center}.popupViewGeoTag .clickOrTapInfo.stickTop{top:80px}.popupViewGeoTag .waitContainer{position:absolute;display:none;top:250px;left:0;width:100%;text-align:center}.popupViewGeoTag .wait{width:210px;text-align:center;border:2px dashed #52a552;background-color:#FFF;display:inline-block;padding-top:16px;padding-bottom:16px;font-weight:700}.popupViewGeoTag .wait.error{color:red;width:300px;border:2px dashed red;font-weight:400}.popupViewGeoTag .waitSpinner{margin-left:6px;vertical-align:-2px}.popupViewPicasa .headerContainer{margin-bottom:15px}.popupViewPicasa .btn-userLogin{vertical-align:4px;margin-bottom:15px}.popupViewPicasa .signInMsg{font-size:14px;color:#30750a;font-weight:700;vertical-align:2px}.popupViewPicasa .signInMsg.error{color:#c43d40}.popupViewPicasa .signInMsg img{vertical-align:-2px}.popupViewPicasa .contentContainer{margin-top:20px}.popupViewPicasa .howToFind{display:block;margin-top:20px}.popupViewPicasa .howToFind a{text-decoration:underline;font-weight:400}.popupViewPicasa .howToFind-popover{left:10px!important;min-width:380px}.popupViewYoutube .modal-body{padding-bottom:5px}.popupViewYoutube .headerContainer{margin-bottom:28px}.popupViewYoutube .youtubeContainer{margin-bottom:-5px}.popupViewYoutube .youtubeLookup{vertical-align:4px}.popupViewYoutube .lookingUpMsg{height:16px;font-size:14px;color:#30750a;font-weight:700;vertical-align:2px}.popupViewYoutube .lookingUpMsg.error{color:#c43d40}.popupViewYoutube .howToFind{display:block;margin-top:20px}.popupViewYoutube .howToFind a{text-decoration:underline;font-weight:400}.popupViewYoutube .howToFind-popover{left:10px!important;width:310px;max-width:310px}#settings-fields p{margin-bottom:20px}#settings-fields .error-msg{display:none;background:url(../resources/icons/errorbox-close.png) 0 0;height:75px;background-repeat:no-repeat;padding-top:13px;padding-left:85px;color:red}#settings-fields .error-msg2{display:none;margin-top:10px;color:red;font-weight:700}#settings-fields .fieldResetContainer{width:100%;text-align:center;margin-top:15px}#settings-layout .layout-box{display:inline-block;width:259px;vertical-align:top;text-align:center;padding-top:10px;margin-top:15px}#settings-layout .layout-box:nth-child(2){padding-right:5px}#settings-layout .layout-box>img{padding-top:17px;padding-bottom:10px}#settings-layout .layout-box:nth-child(3)>img{padding-bottom:36px}#settings-layout .layout-box{min-height:250px}#settings-layout .layout-box .layoutOption{margin-bottom:8px;font-size:14px}#settings-layout .layout-box .layoutOption input:checkbox{height:12px}#settings-layout .layout-box .layoutFooter{position:absolute;bottom:50px;width:258px}#settings-layout .layout-box button{display:inline-block}#settings-layout .layout-box .selectedLayout{font-weight:700;line-height:28px;display:none}#settings-layout span:nth-child(2){border-right:1px solid #000}#settings-layout .layout-box.selected .selectedLayout{display:block;margin-bottom:2px}#settings-layout .layout-box.selected button{display:none}#settings-layout .layoutOption{text-align:center;font-size:90%;margin-top:10px}#settings-layout .layoutOption .popover{max-width:245px}#settings-layout .useLocBtn{width:12px;vertical-align:-2px}#settings-zoom p{margin-bottom:20px}#sharePopup .modal-body{overflow:visible}#sharePopup .hide{display:none}#sharePopup .header{margin-bottom:15px}#sharePopup .question{margin-top:15px;font-weight:700}#sharePopup .answer{margin-top:4px}#sharePopup .question strong{border-bottom:1px dotted grey;cursor:pointer}#sharePopup .collapse{}#sharePopup .imgContainer{width:100%;text-align:center;margin-top:10px}#sharePopup a:not(.btn){color:#20C;font-weight:400;text-decoration:underline}#sharePopup .share-link ::-ms-clear{display:none}#sharePopup .share-link>div{text-align:center;margin-bottom:15px;font-weight:700;font-size:18px}#sharePopup .not-shared{text-align:center}#sharePopup .not-shared .header{font-weight:700;margin-bottom:20px}#sharePopup .share-warning{display:none;margin-top:20px;font-weight:700!important;font-size:14px;color:#c43d40!important}#sharePopup .share-warning a{color:#C43D40;font-weight:700}#sharePopup .footer{margin-top:30px}#sharePopup .footer .popover{max-width:400px!important}#sharePopup .sharing-status.error a{font-weight:700!important;font-size:14px;color:#c43d40!important;margin-top:8px}#sharePopup .modal-footer .error{max-width:460px;text-align:left;margin-top:-5px}#mapPanel{height:100%;float:right;background-color:#EEE;position:relative}#mainMap{border:0;padding:0;height:100%;width:100%!important;overflow:hidden}.modern-layout #mapPanel{width:100%!important;float:inherit}.modern-layout .logo-med{display:none!important}.modern-layout:not(.mobile-view) .esriAttribution{display:none!important}#footer{position:absolute;bottom:0;left:0;right:0;width:100%;background-color:#E5E5E5}.builderMobile a{font-size:24px;padding-top:2px;padding-bottom:6px}.modern-layout.mobile-view #footer{width:100%;bottom:0;left:0;right:0}.modern-layout #footer{width:auto;position:absolute;bottom:10px;left:10px;right:10px}#mainMap svg>g{}#mainMap svg g#mainMap_graphics_layer{}#hoverInfo{font-size:10px;position:absolute;padding:5px;max-width:200px;background-color:#FFC;border:#848484 solid 1px;-webkit-border-radius:4px;-moz-border-radius:4px;border-radius:4px;-moz-box-shadow:2px 2px 10px #333;-webkit-box-shadow:2px 2px 10px #333;box-shadow:2px 2px 10px #333;filter:progid:DXImageTransform.Microsoft.Shadow(strength=2, direction=135, color='#333333');-ms-filter:"progid: DXImageTransform.Microsoft.Shadow(strength = 2, Direction = 135, Color = '#333333')";overflow:hidden;display:none;z-index:100;word-wrap:break-word}.multiTip a{color:#FFF}audio{max-width:100%}#autoplay{display:none;position:absolute;bottom:10px;z-index:31;left:50%}#footerDesktop{position:relative;height:150px;padding-top:10px}.modern-layout #footerDesktop{height:140px;padding-top:0}#footerDesktop .carousel{position:absolute;bottom:0;left:37px;right:36px;height:150px}.modern-layout #footerDesktop .carousel{bottom:1px;height:145px}.carouselWrapper{position:absolute;z-index:1;top:12px;bottom:0;left:0;right:0;width:100%;height:135px;overflow:auto;-ms-touch-action:none}.modern-layout .carouselWrapper>div:nth-child(2){bottom:1px!important}.carouselWrapper>div:nth-child(2){bottom:0!important}.carouselScroller{height:100%;float:left;padding:0;cursor:pointer}.carouselScroller ul{list-style:none;display:block;float:left;width:100%;height:100%;padding:0;margin:0;text-align:left;counter-reset:item}.carouselScroller li{display:block;text-align:center;vertical-align:middle;float:left;padding:0 8px;width:145px;height:100%;font-size:10px}.modern-layout .carouselScroller li{width:140px}.carouselScroller li:first-child{padding-left:0}.carouselScroller .carousel-item-div{display:table-cell;width:140px;height:120px;text-align:center;vertical-align:middle;padding:4px 4px 2px}.carouselScroller .carousel-item-div div{max-height:24px;overflow:hidden;height:24px;line-height:12px;word-wrap:break-word;width:140px;overflow:hidden;font-family:open_sanssemibold,sans-serif}.carouselScroller.no-touch .carousel-item-div:not(.selected):hover{background-color:#7D7D7D}.carouselScroller .carousel-item-div.selected{background-color:#FFF}.carousel-item-div img{max-width:140px;max-height:93px}.carousel-item-div sup{line-height:6px}.carouselScroller span{display:inline-block}.carouselScroller .carousel-item-div>span:before{position:absolute;display:inline-block;content:counter(item);counter-increment:item;width:20px;height:15px;text-align:center;font-size:12px;color:#FFF;padding-right:1px;padding-bottom:1px}.carouselScroller span.number-blue:before{background-color:#1880f3}.carouselScroller span.number-red:before{background-color:red}.carouselScroller span.number-green:before{background-color:#369A22}.carouselScroller span.number-purple:before{background-color:#8A26FD}body.notNumbered .carouselScroller span:before{display:none}.arrowLeft{position:absolute;top:52px;left:-28px;cursor:pointer}.arrowRight{position:absolute;top:52px;right:-29px;cursor:pointer}.arrowLeft.disabled,.arrowRight.disabled{cursor:default;display:none}#picturePanel{height:100%;float:left;position:relative;background-color:#B4B4B4}.modern-layout #picturePanel{position:absolute;right:4px;width:400px;height:400px;background-color:transparent}.arrow{cursor:pointer}#arrowPrev{position:absolute;top:0;left:8px;z-index:100}#arrowNext{position:absolute;top:0;right:8px;z-index:101}#arrowPrev.disabled,#arrowNext.disabled{cursor:default;display:none}.modern-layout-control{position:absolute;cursor:default;opacity:0;z-index:402}.modern-layout-control.click-btn{width:32px;height:53px;background-repeat:no-repeat}.modern-layout-control.click-btn.left{background:url(../resources/icons/picturepanel-left2.png)}.modern-layout-control.click-btn.right{background:url(../resources/icons/picturepanel-right2.png)}.modern-layout-control.click-bg{width:70px;height:72px;margin-top:-35px}.modern-layout-control.click-bg.left{margin-left:-4px}.modern-layout-control.click-bg.right{margin-right:-4px}.modern-layout-control.disabled{display:none!important}.modern-layout-control.hover{opacity:.5;filter:alpha(opacity=50);cursor:pointer}.modern-layout-control:hover{color:#FFF;text-decoration:none;opacity:.9;filter:alpha(opacity=90)}body.hasTouch .modern-layout-control:not(.disabled){display:block!important;opacity:1!important}#cfader{width:100%;height:100%;position:relative}.editPictureButtons{display:none;position:absolute;top:76px;text-align:center;height:30px}.editPictureButtons>div{display:inline-block}.modernBrowserWay,.oldBrowserWay,.attributesWay{display:none}.editPictureButtons a{font-weight:400;margin-top:2px}.editPictureButtons .oldBrowserWay .btn-upload{vertical-align:-1px}.editPictureButtons .oldBrowserWay form{display:inline}.picturePanelPicturePopoverFR{max-width:315px;width:315px}.picturePanelPicturePopoverOLD{max-width:335px}.picturePanelThumbnailPopover{width:280px;max-width:280px}.edit-attr-popover{max-width:378px;width:378px}.edit-attr-popover input[type=text]{vertical-align:-2px;margin-bottom:0;margin-right:8px}.attributesWay .error{display:none;font-weight:700;font-size:14px;color:#c43d40;margin-top:4px}#footerMobile{display:none;height:100px;border-top:1px solid #999}#footerMobile .carousel{height:100%;-ms-touch-action:none}#footerMobile .carousel .tpPreview{height:100px;cursor:pointer}@media screen and (max-width:767px){#footerMobile .carousel .tpPreview{cursor:default}}#footerMobile .carousel>div>div{overflow:hidden}#footerMobile .builderMobileContainer{display:none;position:absolute;width:100%;text-align:right;margin-top:-20px;height:22px;right:60px;margin-top:-33px;height:22px;right:5px;z-index:499}#footerMobile.hasDesktopBtn .carousel{margin:0 53px}#footerMobile .embed-btn-container{display:none}#footerMobile.hasDesktopBtn .embed-btn-container{position:absolute;top:14px;display:block;width:51px;height:100%;z-index:1;opacity:.8;padding-top:14px}#footerMobile .embed-btn-container.disabled{opacity:.2;cursor:default}.embed-btn{width:42px;height:42px;background:url(../resources/icons/embed-arrows.png)}.embed-btn-container:not(.disabled):hover{opacity:1;cursor:pointer}.embed-btn-left{left:0;padding-left:9px}.embed-btn-left.disabled .embed-btn{background-position:42px 0}.embed-btn-right{right:0}.embed-btn-right .embed-btn{background-position:0 -42px}.embed-btn-right.disabled .embed-btn{background-position:42px -42px}#footerMobile,#listPanel,#infoPanel,#introPanel,#headerMobile,#openHeaderMobile{-webkit-touch-callout:none;-webkit-user-select:none;-khtml-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}.tpImgPane{position:absolute;border:3px #fff solid;height:70px;width:70px;top:12px;left:12px;-webkit-box-shadow:2px 2px 3px 0 #444;box-shadow:2px 2px 3px 0 #444;overflow:hidden}.tpImgContainer{height:74px;vertical-align:middle;display:table-cell;text-align:center;width:70px}.tpImgPane img{max-width:70px;max-height:70px}.tpTextPane{margin-left:104px;padding-right:6px}.tpIcon{position:absolute}body.notNumbered .tpIcon{display:none}.tpName{padding-top:9px;font-size:18px;overflow:hidden;text-overflow:ellipsis;display:-webkit-box;-webkit-line-clamp:1;-webkit-box-orient:vertical;word-break:break-all;word-wrap:break-word;max-height:24px}.tpDescription{font-size:14px;overflow:hidden;text-overflow:ellipsis;display:-webkit-box;-webkit-line-clamp:3;-webkit-box-orient:vertical;max-height:52px;word-wrap:break-word;line-height:18px;margin-top:2px}.tourPointName{font-size:24px;margin-left:68px;margin-top:12px;margin-right:90px;text-align:left;word-wrap:break-word;min-height:30px}.tourPointDescription{font-size:14px;margin:15px 5% 0;text-align:left;word-wrap:break-word}.tourPointImg{margin-top:10px;max-width:90%;border:5px #fff solid;-webkit-box-shadow:2px 2px 3px 0 #444;box-shadow:2px 2px 3px 0 #444}body.notNumbered .tourPointIcon{display:none}body.notNumbered .tourPointName{margin-left:40px}.tourPointIframe{margin-top:10px;width:90%;height:500px;border:5px #fff solid;-webkit-box-shadow:2px 2px 3px 0 #444;box-shadow:2px 2px 3px 0 #444}#infoPanel{display:none;height:100%;min-height:100%}#infoCarousel{text-align:center;overflow:auto;height:100%;min-height:100%;-ms-touch-action:none}#infoCarousel>div>div{overflow:hidden}.iconHolder{position:absolute;left:32px;top:0;text-align:left}.iconHolder img{height:40px;width:32px;margin:10px 5% 5px}#infoPanel .embed-btn-container{display:none;position:absolute;bottom:0;margin:20px}#infoPanel.hasDesktopBtn .embed-btn-container{display:block}#infoPanel .embed-btn-container.disabled{opacity:.2;cursor:default}#introPanel{display:none;position:absolute;left:0;top:41px;text-align:center;overflow:auto;min-height:100%;background-color:grey;z-index:2000;width:100%;max-width:100%;height:100%}#introPanel .tourPointName{margin-left:0;padding:0 5%}#introPanel button{margin-bottom:45px}#listPanel{display:none;z-index:500;height:100%;-webkit-overflow-scrolling:touch;-ms-touch-action:none}.listWrapper{width:100%;height:100%;overflow:auto;-ms-touch-action:none}.listScroller{padding:0;cursor:pointer;padding-bottom:41px}body.hasTouch .listWrapper>div:nth-child(2){display:none}.listWrapper>div:nth-child(2){z-index:1!important}.listItem{position:relative;height:100px;border-bottom:#444 1px solid}body.mobile-view .autoplay{display:none!important}.autoplay{-webkit-transition:opacity .5s linear;-moz-transition:opacity .5s linear;-ms-transition:opacity .5s linear;-o-transition:opacity .5s linear;transition:opacity .5s linear}.autoplay .autoplay-container{position:relative;width:180px;margin:0 -100px;text-align:center;padding:10px 10px 0;background-color:#AAA;border-radius:4px;border:1px solid #FFF}.autoplay .backdrop{display:none;position:absolute;top:0;left:0;right:0;bottom:0;opacity:.8;border-radius:4px}.autoplay .btn-play-container{display:inline-block;width:40px;height:42px;font-size:30px;cursor:pointer;vertical-align:middle;color:#FFF;margin-top:-5px}.autoplay.theme-white2 .btn-play-container{color:#000}.autoplay .slider-container{display:inline-block;width:125px;height:42px;margin-left:9px;vertical-align:middle;padding-top:8px}.autoplay .slider{width:120px!important}.autoplay .slider input{display:none!important}#pictureLoadingIndicator{position:absolute;top:0;left:0;margin:auto;display:block;height:100px;width:100px}#pictureLoadingIndicator .spinner{z-index:400!important;margin-left:50px;margin-top:48px}.member-image{position:absolute;left:0;top:0;width:100%;height:auto;display:none;border:solid;border-collapse:collapse}.member-image img{image-rendering:optimizeQuality;width:100%;height:auto}.member-image iframe{width:100%;height:100%;border:0}.modern-layout .member-image{border:0}.modern-layout .member-image.current{border:1px solid #B4B4B4}.btn-fullscreen{display:inline-block;position:absolute;width:26px;height:26px;background:url(../resources/icons/media-fullscreen.png) 0 0;opacity:0;z-index:400;margin-top:1px}.btn-fullscreen.hover{opacity:1;cursor:pointer}.btn-fullscreen.hover{opacity:.8}.btn-fullscreen.hover:hover{opacity:1!important}.btn-fullscreen.disabled{display:none}body.modern-layout .btn-fullscreen{margin-right:2px;margin-top:-1px}body.hasTouch .btn-fullscreen{display:block!important;opacity:1!important}#placardContainer{position:absolute;width:100%;bottom:0;display:none;overflow:hidden}#placard{display:inline-table;background-image:url(../resources/icons/background_filler.png);position:relative;width:100%;color:#FFF;z-index:5;word-wrap:break-word}#placard a{color:#FFF;text-decoration:underline}#placard ul{padding-left:40px}#placard-bg{width:100%;margin-bottom:-5px}#placard .name{padding:10px 0 15px 10px;font-size:20px;width:35%;float:left;margin-top:0}#placard .description{padding-top:10px;padding-bottom:10px;position:relative;width:55%;float:right;margin-top:0;padding-right:10px;font-size:14px}#placard.one-line-layout .name{padding:10px 10px 0;width:auto;margin-right:0}.builder-mode #placard.one-line-layout .name{float:inherit}#placard.one-line-layout .description{padding:10px 10px 0;width:auto;margin-right:0;margin-bottom:5px}.builder-mode #placard.one-line-layout .description{float:inherit}#placard.one-line-layout .description .text_edit_icon{top:-26px}#placard.one-line-layout .description .text_edit_label{margin-bottom:4px}#placardContainer.no-description .name{width:97%}#placardContainer.no-description .description{display:none}#placardContainer.force-hidden{display:none!important}#toggle{width:36px;height:18px;margin-left:25px;background-image:url(../resources/icons/picturepanel-placard-toggle.png);cursor:pointer}body.modern-layout #toggle{margin-left:55px}#toggle.closed{background-position-y:18px}#placardContainer.placardUnder #toggle{display:none}#placardContainer.placardUnder{border:solid;border-collapse:collapse;margin-left:-3px;overflow-y:auto}#placardContainer.placardUnder #placard{display:table;height:100%}#placardContainer.placardUnder #placard-bg{height:100%!important;max-height:100%!important;margin-bottom:0}#placardContainer.placardUnder .description .text_edit_icon{top:1px;right:1px}#placardContainer.placardUnder .name .text_edit_icon{top:1px;left:37%}#placard .name .text_edit_input{margin-top:-2px;font-size:20px;line-height:24px;height:74px}#placard.one-line-layout .name .text_edit_input{height:25px;overflow-y:hidden;z-index:2000;width:98%}#placard .name .text_edit_icon{position:absolute;top:-16px;left:38%}#placard .description .text_edit_input{width:98%;margin-top:-2px;font-size:14px;line-height:16px}.builder-mode #placard.one-line-layout.isEditing .description .text_edit_icon{display:none!important}#placard .description .text_edit_icon{position:absolute;top:-16px;right:4px}#placard .name,#placard .description{overflow-x:hidden}.builder-mode #placard .name,.builder-mode #placard .description{overflow-x:initial}#header{height:115px;background:#444;color:#fff;margin:0;overflow:hidden;display:none}#header .title{font-family:open_sanssemibold,sans-serif}#header.hideDesktop{height:0}#header.hideDesktop #headerDesktop{display:none}.textArea{padding-top:0;padding-left:25px;width:70%}#headerDesktop .title{height:26px;margin-top:14px;padding-top:4px;font-size:20px;font-weight:400;text-align:left;overflow:hidden;white-space:nowrap}#header:not(.isBuilder) #headerDesktop .title{text-overflow:ellipsis;-o-text-overflow:ellipsis;display:-webkit-box;-webkit-line-clamp:1;-webkit-box-orient:vertical;word-wrap:break-word;white-space:pre}#headerDesktop .title.titleEmpty .text_edit_label{color:red}#headerDesktop .title.titleEmpty .text_edit_icon{background-color:red}#headerDesktop .subtitle{font-size:13px;margin-top:13px;overflow:hidden;overflow-y:auto;font-weight:400;line-height:18px;word-wrap:break-word;height:54px;color:#C5D5D5}.rightArea{position:absolute;right:0;top:0;padding-top:25px;padding-right:25px;text-align:right}.rightArea .social{margin-bottom:6px}.social .msLink,.social .msLink a{color:#C5D5D5;font-weight:400;font-size:13px}.rightArea .logo{position:relative;height:60px;border:0;outline:0}@-moz-document url-prefix(){.rightArea .logo a{position:relative;display:inline-block}.rightArea .logo a img{bottom:initial;top:initial;margin-top:-10px}}.rightArea .logo img{position:absolute;top:50%;bottom:50%;right:0;max-width:250px;max-height:50px;margin:auto 0}.switchBuilder{display:none;position:absolute;right:180px;top:30px;width:145px;padding-left:35px}.switchBuilder img{position:absolute;top:8px;left:7px;width:28px;height:28px}@font-face{font-family:storymaps-icons;src:url(../resources/font/sharing/storymaps-icons.eot?49500659);src:url(../resources/font/sharing/storymaps-icons.eot?49500659#iefix) format('embedded-opentype'),url(../resources/font/sharing/storymaps-icons.woff?49500659) format('woff'),url(../resources/font/sharing/storymaps-icons.ttf?49500659) format('truetype'),url(../resources/font/sharing/storymaps-icons.svg?49500659#storymaps-icons) format('svg');font-weight:400;font-style:normal}[class^=icon-]:before,[class*=" icon-"]:before,[class*=" autoplay-icon-"]:before{font-family:storymaps-icons;font-style:normal;font-weight:400;speak:none;display:inline-block;text-decoration:inherit;width:1em;margin-right:.2em;text-align:center;font-variant:normal;text-transform:none;line-height:1em;margin-left:.2em;-webkit-font-smoothing:antialiased;-moz-osx-font-smoothing:grayscale}.autoplay-icon-play:before{content:'\e800'}.icon-link:before{content:'\e801'}.icon-facebook-squared:before{content:'\e802'}.icon-twitter:before{content:'\e803'}.autoplay-icon-pause:before{content:'\e804'}.shareIcon{display:inline-block;cursor:pointer;margin-left:4px;color:#C5D5D5;vertical-align:0;background-image:none}.shareIcon:hover{color:#fff}.shareIcon.disabled{cursor:default;opacity:.5!important}.share_bitly{vertical-align:1px;margin-left:2px}.social .popover-title{display:none}#bitlyInput::-ms-clear{display:none}.autoplay-help+.popover{left:inherit!important}.autoplay-help+.popover .arrow{display:none}#headerDesktop .text_edit_input{position:relative;z-index:501}#headerDesktop .text_edit_label{max-width:94%;overflow:hidden}.title .text_edit_input{height:20px;margin-top:-6px;margin-bottom:0;font-size:20px;width:98%}.title .text_edit_icon{margin-top:-12px;margin-left:8px}.subtitle .text_edit_input{font-size:12px;line-height:17px;width:97%}.subtitle .text_edit_icon{position:absolute;margin-top:-9px;margin-left:8px}#headerMobile{display:none;background-color:#444;position:fixed;left:0;top:0;width:100%;z-index:100}#headerMobile .banner{display:none;cursor:pointer}#headerMobile .title{color:#fff;font-size:22px;padding:10px 10px 0;margin-bottom:10px;word-wrap:break-word;overflow:hidden;text-overflow:ellipsis;display:-webkit-box;-webkit-line-clamp:2;-webkit-box-orient:vertical;max-height:55px}#headerMobile .subtitle{color:#dadada;font-size:16px;padding:0 10px;font-weight:400;word-wrap:break-word;max-height:70px;overflow:hidden;text-overflow:ellipsis;display:-webkit-box;-webkit-line-clamp:3;-webkit-box-orient:vertical}#closeHeaderMobile,#openHeaderMobile{text-align:center;color:#fff;font-size:12px;font-weight:700;cursor:pointer}#closeHeaderMobile{border-bottom:1px solid #888;padding:10px}#openHeaderMobile{display:none;position:fixed;right:0;padding:7px;background-color:#666;-webkit-border-radius:0 0 0 7px;border-radius:0 0 0 7px;z-index:99}.navBar{color:#CFCFCF;padding:9px 0;text-align:center;font-weight:400}.navBar span{cursor:pointer;-ms-user-select:none}.rightLink,.leftLink{position:absolute}.leftLink{left:1em}.rightLink{right:1em}.navBar .current{color:#fff;font-weight:700}.text_edit_label{float:left;margin:0;word-wrap:break-word}.text_edit_input{display:none;width:100%;margin-bottom:0}.text_edit_icon{display:inline-block;width:25px;height:25px;background:url(../resources/icons/builder-edit-fields.png) 3px 2px;background-repeat:no-repeat;cursor:pointer;background-color:#ededed;border-radius:2px}#loadingMessage{width:100%;text-align:center;margin-top:14px;position:fixed;top:50%;z-index:700;font-size:16px;font-weight:700}.esriSimpleSlider{-webkit-tap-highlight-color:rgba(0,0,0,0)}.esriSimpleSlider.touch div{width:35px;height:35px;line-height:30px}.mapCommandHomeBtn{background:url(../resources/icons/mapcommand-home.png);background-repeat:no-repeat;background-position:5px 5px}.mapCommandHomeBtn.touch{background-position:7px 7px}body.mobile-view .mapCommandHomeBtn.loading{background:url(../resources/icons/mapcommand-loading.gif);background-repeat:no-repeat;background-size:24px 24px;background-position:3px 3px;cursor:default}body.mobile-view .mapCommandHomeBtn.loading.touch{background-position:5px 5px}.mapCommandHomeBtn.loading:hover{background-color:#FFF}.mapCommandLocation{top:130px;left:20px;z-index:30}.mapCommandLocation img{width:20px;margin-top:5px}.mapCommandLocation.touch{top:145px}.mapCommandLocation.touch img{margin-top:4px;width:28px}.mapCommandLocation.hidden{display:none!important}.mapCommandLocation.loading{background:url(../resources/icons/mapcommand-loading.gif);background-repeat:no-repeat;background-size:24px 24px;background-position:3px 3px;cursor:default}.mapCommandLocation.loading img{display:none}.mapCommandLocation.loading.touch{background-position:6px 6px}.mapCommandLocation.loading{background-color:#FFF}.mapLocationError{display:none;position:absolute;bottom:5px;left:0;right:0;text-align:center;z-index:999}.mapLocationMsg{display:inline-block;background-color:#000;color:#fff;z-index:999;padding:5px 8px;border-radius:10px}.multiTip{min-width:60px;max-width:200px;border:2px #444 solid;overflow:hidden;word-wrap:break-word;font-size:12px;text-align:center;border-radius:5px;-moz-box-shadow:2px 2px 10px #333;-webkit-box-shadow:2px 2px 10px #333;box-shadow:2px 2px 10px #333;filter:progid:DXImageTransform.Microsoft.Shadow(strength=2, direction=135, color='#333333');-ms-filter:"progid: DXImageTransform.Microsoft.Shadow(strength = 2, Direction = 135, Color = '#333333')"}@media screen and (min-width:768px) and (orientation:landscape){#listPanel,#infoPanel,#introPanel{display:none!important}#contentPanel{display:block!important}}@media only screen and (min-device-width :768px) and (max-device-width :1024px) and (orientation :landscape){#footer{height:160px}.modern-layout #footer{height:140px}}@media screen and (min-width:768px) and (orientation:portrait){#picturePanel{display:none!important}}@media screen and (max-width:767px),screen and (orientation:portrait){#headerDesktop{display:none}#header{height:41px!important;background-color:#E5E5E5}#picturePanel{display:none}#mapPanel{width:100%!important}#footerDesktop{display:none}#openHeaderMobile{display:block}#footerMobile{display:block}#headerMobile{display:block}#loadingOverlay{top:0}#builderPanel2,#builderPanel3{display:none!important}.modal,.modal-backdrop{display:none!important}}
good point Adrian, that the change must be made somewhere else in the script. I did a search of one of the colors and then based off of that looked for where a fifth colour was missing, copy and pasted a line to make a fifth one and substituted in the color code for orange. all good now!
Lindsay,
That is good to hear. I am glad that you got this resolved.
