Locate button in Map Tour embedded in Map Series
1059
03-10-2017 12:39 AM
StefanoToni
Locate button in https works well with my map tour:
https://sit-rimini.maps.arcgis.com/apps/MapTour/index.html?appid=0a35548e898b427d86844ec07f3fc9cb
but if I embed that same map tour in a map series, it does not appears
https://sit-rimini.maps.arcgis.com/apps/MapSeries/index.html?appid=863b7fc94fec48fd80ce05d1b8f03b6b
Thanks
OwenGeo
Esri Notable Contributor
Hi Stefano,
Due to browser security practices, the Locate button is blocked whenever an app is embedded in another app/page (even over https).
If you need your readers to be able to use the Locate button you'll need to provide a link to your Map Tour in the text of your Map Series so the Tour will open in another browser tab as opposed to embedding it in the Map Series.
Owen
Owen Evans
OwenGeo
Hi Stefano,
Owen
Owen Evans
