Loading a Story Map Shortlist in mobile mode?
1717
6
05-29-2017 03:33 PM
HelenCooper
I've put together a Story Map using the Shortlist Story builder beta (http://arcg.is/2orNdqc ) .  The map looks great, but there are a lot of images, and it takes a while to load.  Is there a way of forcing the map to load in mobile mode irrespective of the device used to view?
Here's the map embedded in a web page:
E17 Art Trail – 2017
Many thanks in advance for any help,
Helen
Tags (1)
DarrenWiens2
Actually, on second thought, the original line I referenced looks for any value passed in the url for 'forceMobile', so when you load the iframe, just add a url parameter:
https://mapitconsulting.maps.arcgis.com/apps/Shortlist/index.html?appid=5d8042b827c54cacb6805b44d11f...
DarrenWiens2
I don't know if there's a way to do this through the builder (I doubt it), but I believe you can kind of hack it by changing line 971 in src/app/storymaps/common/Core.js
from...
forceMobile = _urlParams.forceMobile !== undefined || app.indexCfg.forceMobile;
to...
forceMobile = true;
But if you're not building the web app from source, it's a pretty long way around to add this functionality.
HelenCooper
Hi Darren,
Thanks for that, I'm hosting it on AGOL (and have used the builder) so I don't think I can change this.  Thanks though.
Helen
DarrenWiens2
HelenCooper
Perfect, that URL parameter does exactly what I was hoping for.  Thank you.
Helen
NancyChurch
Check and make sure your photos are all sized under 400kb   ... that definitely slows down the story map
HelenCooper
Thanks Nancy.
