Issues loading Main Stage map
3979
06-08-2015 09:55 AM
MarisaBayer
I used the Story Maps application to create a map journal. A few sections have an ArcGIS Online map displayed in the main stage, however, it occasionally will not load or loads very slowly (have to toggle between a few sections before it shows up).
Is this a common issue? All maps used are publicly shared, so it's not a sharing issue. This issue has been experienced by a few people in my company in both Firefox and Chrome.
Tags (1)
OwenGeo
Esri Notable Contributor
Hi Marisa,
Sorry for your issue. Can you share a link to your journal so we can take a look? You can send me a private GeoNet message if you'd rather not post the link here.
Owen
Owen Evans
MarisaBayer
Hi Owen - thanks for the response. Here's the story map: http://arcg.is/1PuU9tj . The maps are on Slides 4 & 5 (Cook County...).
This is a sporadic issue - it doesn't happen all the time, but has happened enough that people within my company have commented.
OwenGeo
Hi Marisa,
I tested your map journal on my office and home networks as well as on my phone over the cell network and it loaded fine each time. I also looked at the network traffic using the browser dev tools and didn't notice any errors or anything else that looked like it would cause a problem.
It may be a network issue on your side or a cache issue. If you hear anyone else complain about this please ask them to clear their browser cache and try again, and let me know if it continues to be an issue.
Owen
Owen Evans
