I have created a Web app using the Countdown Story Map template. I want to decrease the font size in the table of contents. Any ideas?
thanks.
I'm not sure if you want to change all of the text font size (including the intro) or just the info popup text. I am going to presume just the popup text
You will want to edit the style.css file, or you can create a custom css file. The advantage to creating a custom css file is that you can easily transfer the changes to other countdown storymaps that you create.
#info{
font-size:12px;
<link rel="stylesheet" type="text/css" href="css/custom.css">
Save the file.
You should now be able to refresh the web page and you will see the change you made to the font size. You may need to clear your cache to see the changes.
You can find out more about css files here: W3Schools
Christian,
Thanks very much!
Stew
