icons desktop footer carousel
2967
02-28-2014 08:57 PM
HarmenKampinga
I've got an issue: when embedding my story map, my icons change from the standard numbered icons to my personalized icons.
How can I in the first place determine what icon should be used in my desktop footer?
Second: I also want to set the size of the icon that is placed in the desktop footer carousel. How to do that?
Attached an image that shows the other icon used and in the wrong size (standard size for the numbered icons...).
[ATTACH=CONFIG]31884[/ATTACH]
GregoryL_Azou
I'm not sure about the icon issue, I would need to take a look at your application. Please share it here or privately.
Changing the dimension of any Map Tour UI elements require development skills to override some CSS and/or Javascript. The desktop carousel isn't the most easy to customize and we don't have any sample to provide. We are thinking about providing more configuration options and developer documentation to customizing the UI in a further release.
