How to pin a map at the top of a Story Map
488
07-19-2017 11:57 AM
GregKresslein
I found the following Story Map (The World's 10 Largest Refugee Camps ) and it's almost exactly what I want to do, which is to pin a map so users can always click a point on the map, and then it would take you to a detailed section. How can I pint a map at the top such as this? I can't find any settings to do it.
AdrianWelsh
MVP Honored Contributor
Greg,
That map is a custom creation. There is no template for making a map like that. It is similar to the Abandon Islands map which someone else had a question about. See ressinger-esristaff's answer here:
https://community.esri.com/message/697304-re-i-am-not-sure-if-this-is-the-right-place-to-ask-this-qu...
