How can I increasing the size of map popup in map journal?
1278
09-08-2017 06:18 AM
MilaAlvarez
I am creating a map journal story and I want the map popups to show all info without having to scroll down. The graph at the popup bottom is cut by the popup window size and the viewer needs to scroll down. Is there a way to increase the length of the map popup window so it shows all the info without scrolling down?
Thank you!
See image to see what I mean
RupertEssinger
Esri Alum
Hi, the popup size can't be changed for web maps. They have fixed dimensions. It is a request that comes up quite a lot.
In the ArcGIS Ideas section of Geonet (see link in the header above or click: https://community.esri.com/community/arcgis-ideas ), feel free to vote for that idea, or any other ideas you like, or submit an idea if you don't find one. I found this one: Better Popup Configuration in AGOL
Rupert
RupertEssinger
Esri Alum
Rupert
MilaAlvarez
Thank you Rupert for your response!
Mila
