Have pushpin on primary map cause sidebar to jump to coinciding item?
1003
10-14-2016 12:27 PM
LarryPortzline
Is there a way to make clicking a pushpin on my primary map cause the sidebar to jump to the coinciding item? I can't believe I can't find a way to do that. What am I missing?
https://www.arcgis.com/apps/MapJournal/index.html?appid=1d3b6ec681384f7282d652a72a9e3d23
Thanks!!!
OwenGeo
Esri Notable Contributor
Hi Larry,
You can do that, but it requires you to download, customize, and host the application on your own server. The customization is documented on the Map Journal GitHub repository where you can download the code for this app:
GitHub - Esri/map-journal-storytelling-template-js: The Story Map Journal is ideal when you want to ...
Owen
Owen Evans
