Exporting Story Map Tour table with long/lat data?
1372
05-20-2017 10:51 AM
MarkFleming
Greets:
Is it possible to export the data from a Story Map Tour in a way that includes long/lat data?
I know I can export the table in ArcGIS desktop, but the long/lat data does not come with it.
Reason for asking; I want a way to sequentially renumber the points in a rather complicated web map application: https://asdm.maps.arcgis.com/apps/MapTour/index.html?appid=54b063f3cba845fb881c1f2d306e0664
Also, I think this would make a good back system for a story map.
Thank you,
Mark
AdrianWelsh
MVP Honored Contributor
Mark,
Have you brought the data into ArcGIS and added XY coordinates to it?
Adding x,y coordinate data as a layer—Help | ArcGIS for Desktop
(and if using Pro - Add XY Coordinates—Data Management toolbox | ArcGIS Desktop )
MarkFleming
Adrian;
No, we are just placing points using the builder mode.
DarrenWiens2
Maybe this will get you started. Your feature data can be accessed through the JavaScript function app.data.getAllFeatures(). It looks like your data are in Esri Web Mercator - if you need true lat/long, you'll have to do a little more work. Open the debugger tool in your browser and use a quick JS like:
var mylist = [];
var features = app.data.getAllFeatures();
for (var i=0;i<features.length;i++){
 mylist.push([features[i].attributes.getName(),features[i].geometry.x, features[i].geometry.y]);
document.write(mylist.join("<br>"));‍‍‍‍‍‍
Results in:
MarkFleming
Thank you, Darren;
I'll give this a try
Mark
