Can you add popups for pictures in story map
3324
07-11-2016 09:40 PM
JessNewton
I have added a picture in a story map chapter, Can I add pop ups or something like that so if someone clicks a certain place in the picture a window with text or something popups...without changing chapters.
Thanks in advance
OwenGeo
Esri Notable Contributor
Hi Jess,
Unfortunately, it's not possible to configure pop-ups on images from within the Builder -- that's only a feature of web maps.
A developer could create a custom web page that behaves as you describe, and you could add that web page to a section of your map journal.
Owen
Owen Evans
AdrianWelsh
MVP Honored Contributor
Hi Jess,
What story map template are you using? Can you share the story map here?
If your map is just referencing a web map, you can configure popups in your web map:
Configure pop-ups—ArcGIS Online Help | ArcGIS
JessNewton
Hi Adrian...we are using the map journal template...and no sorry we cant share the story map work for a government agency so no sharing outside. So we are fine with creating popups if it was a map but this actually an image eg. say a picture of a puppy (its not just an example) and we want to be able to click on its nose and a popup appear with information, and then click on its eyes and a different popup appear.....does that make sense??
OwenGeo
Hi Jess,
Owen
Owen Evans
