Can I put 2 or more pictures into a single point of a Story Map Tour Application?
2168
02-14-2016 06:04 PM
MatteoVommaro
I'm searching a way for putting not only one picture in my story map tour. If i set the point 1, i can put only a single picture in point 1. I'd like to know if there is a method that can help me to put in point 1  three different pictures.
I hope you all will help me rapidly.
Thank you!
AdrianWelsh
MVP Honored Contributor
The map tour application is not meant for more than one picture, from what I can tell.
In order to do more than one picture per point, I believe you would need to do some custom programming for this to happen.
However, this website has some ideas that might help:
Displaying multiple photos at a single location in a Map Tour | ArcGIS Blog
AdrianWelsh
DanPatterson_Retired
and maybe more, if you moved your post from the help about geonet place to Story Maps
the site  GeoNet Community Structure
the Place Story Maps
with the Move option on your post.... which I have done
