Any way to allow users to toggle layer visibility?
5656
11
01-23-2014 01:09 AM
AliceJarvis
I'm using the Storytelling Text and Legend template. I'd like to show several map layers on a tab and allow the user to turn them on and off - is there any way to do this? e.g. is it possible to use this kind of code: https://developers.arcgis.com/en/javascript/jssamples/map_explicitlayerlist.html
AliceJarvis
Hi Sherwin,
There's a few bits of code in several files. I've written up some notes (attached) which may help you see how I got things working. My coding is probably not the best or most efficient, but it does work on my site. Good luck...
FlorianHruby2
Hi Alice,
I found your notes quite helpful - thank you for sharing!
kind regards,
Flo
