Add audio tracks to a map tour storymap
5478
01-28-2014 03:01 AM
MathildeGouret1
I saw some story maps with audio tracks instead of videos, so I know it is possible.
How may I add audio to a map tour template ?
Thanks for your answers
StephenSylvia
The easiest way to add audio to a map tour is to upload your audio track to a web service that allows you to host and embed an audio player in an external website (something like SoundClound). Then, when you add a new tour point, choose "video" then "other" (see this blog post for help: http://blogs.esri.com/esri/arcgis/2014/01/21/adding-websites-to-your-story-map-map-tours/). Instead of using the website's url, you should use the embed code source URL.
For Example, on Sound Cloud, if you click a audio track and click share, then click "Embed" you will be given this code:
<iframe width="100%" height="450" scrolling="no" frameborder="no" src="https://w.soundcloud.com/player/?url=https%3A//api.soundcloud.com/tracks/131830246&auto_play=false&h..."></iframe>
Only use the URL highlighted in red.
If you would like to do anything beyond this embed capability, you will need to download and modify the source code.
StephenSylvia
RupertEssinger
Esri Alum
