rounded data frame
3966
10
08-25-2017 02:27 PM
AlexM
New Contributor III
Hello,
I'm trying to create an inset as a rounded data frame within my main map.
I used 100% rounding for both my background and border to create a circular frame.
When I export the output map, there a square white border around my frame (attached image).
Is there any way to remove that?
Thanks
AbdullahAnter
Occasional Contributor III
What is your software that you use?
AlexM
New Contributor III
ArcMap 10.3.1
AbdullahAnter
Did you make the background of data frame none color?
AlexM
New Contributor III
Yes, I've tried that but the square is still there when I export.
DanPatterson_Retired
with no border? or transparent with no border?
AlexM
New Contributor III
Just without border. Only circular frame
AbdullahAnter
So , What is the format that you export to?
AlexM
New Contributor III
It's PDF at 300 dpi
AbdullahAnter
It is old problem , and there are many question asked about that.
that problem cause if the inset data frame has a raster data.
so you can find some ways but it is not the solution, just workaround .
please read the following threads:
Data frame with no background prints with white background with rasters
How do you make white background of new data frame transparent
Feature transparency causes white data frame background when printed
Overlapping Data Frames Not Transparent on Export
Clip data frame: why is original shape still appearing
