How to generate a world map (a space view earth) with Thailand as the center?
2523
09-05-2017 12:32 AM
Pei_YingLoh
hi guys!
I'm new to ArcGIS, and I'm wondering is there anyway I can generate a round map, like the earth view from the space, with a specific location in the center, for example, Thailand?
Earth view from space with Thailand as center
I tried applying different coordinate systems, but it doesn't seems to be the correct way to do it?
Thank you!
DanPatterson_Retired
Did you try to alter some of the central longitude and latitude parameters from the 'world from space' (orthographic)?
https://blogs.esri.com/esri/arcgis/2009/09/21/globe-locator-map/
