extract info from nearest point
4392
03-14-2016 10:59 AM
IanIrmischer
I am using ArcMap 10.3.  I have a point file with 100 features. I would like to extract an attribute (elevation) from the nearest point in the same file.
Any suggestions?
Ian
DarrenWiens2
You should be able to use Spatial Join with Closest relationship.
Spatial Join—Help | ArcGIS for Desktop
IanIrmischer
Darren, Thanks. I must be doing something wrong. I try using the spatial
join and "closest" and it just gives joins the attributes of the original
point... Not the nearest. So I get the same elevation value. I found a work
around where I use the near tool and then a join but I thought there might
be a more elegant solution.
Ian
DarrenWiens2
Here's an example. I used spatial join with the original points as both the target and join fature classes. The points are labeled by "Id". For example, the highlighted point ("Id" = 2) has an elevation of 5795, and it is closest to point 3 ("Id_1" = 3) which has an elevation of 2896.
WesMiller
If you have an advanced license you could use Generate Near Table—Help | ArcGIS for Desktop
IanIrmischer
This worked very well.
Ian
