draw smaller polygons over larger polygons
3575
08-17-2017 09:42 AM
RyanPaquette1
Want to set up ArcMap to draw all smaller polygons in a feature on top of larger polygons within the same feature.
Someone asked about this on GIS Stack Exchange and it was marked as answered yet it was not really answered; ArcGIS - possible to set the drawing order of polygon features - Geographic Information Systems Stac...  (While the title was interpreted as duplicate, the question itself was unique)
I have the total area set up as an attribute, but Symbol Levels don't seem to cut it as I cannot use natural breaks / classes due to the symbolization being on a descriptive field...
     1) The symbology is on separate / descriptive field.
      2) So, went with Unique values, many fields in order to leverage Symbol Levels on the Area attribute.
      3a) Because its unique values I cannot feasibly add all the AREA attributes (all unique / 20,000+ records).
      3b) The Symbol Levels concatenates both fields so I cannot even have it sort by area, due to the Area attribs being grouped by the descriptive attribute.
DanPatterson_Retired
The answer is reasonable... sort the Area field (Shape_Area) in descending order... which suggests that you don't have an advanced license.  There are workarounds, but they would require so programming
RyanPaquette1
Borrowed an advanced license, ran the tool, generated a new file. Worked . Just couldn't do it on the source data itself. No worries. Thanks
LarkinPhil
