clip producing empty layer
1192
11-08-2017 04:28 PM
HusamAlqamy
I am running a model where i use CLIP analysis. When I run it through the model builder it returns an empty feature class while running the clip  as arcmap tool using the same input and clip layer succeeds and returns the right output. The model run gives an error code 000117 the help says that this error can be fixed by specifying the processing extent. I did this as union of the inputs but still getting the same error. Could anybody help on that.
DanPatterson_Retired
same comment as for union,  are both coordinate systems known and specified? (if not, there will unlikely be any overlap)  Clip doesn't specify whether a projection-on-the-fly will be done
Clip help (same in arcmap)
