I have a combobox under a calcite-tab that has a long list of entries. The issue is that I cannot see the last few entries. I tried with no results the heightScale="l" and css height.
<calcite-shell-panel slot="contextual-panel" position="end" detached>
<calcite-block open heading="Testing">
<calcite-tabs>
<calcite-tab-nav slot="tab-nav" id="thetabs">
<calcite-tab-title id="tab1" class="tab1" tab="Tab1">Tab1
</calcite-tab-title>
<calcite-tab-title id="tab2" class="tab2" tab="Tab2" active>Tab2
</calcite-tab-nav>
<calcite-tab tab="Tab2">
</calcite-tab>
<calcite-tab tab="Tab1" style="height: 900px;">
<calcite-combobox value="county" label="county" placeholder="County" id="beg_county"
style="padding-bottom: 10px; padding-left:30px; width: 100px;" selection-mode="single">
</calcite-combobox>
</calcite-tab>
</calcite-tabs>
</calcite-block>
</calcite-shell-panel>
I suggest setting the "max-items" attribute, which will limit how many items are displayed at a time. That way the combobox menu won't be so long.
<calcite-combobox max-items="10">
What is the suggested solution to this issue, when the Combobox is being invoked via `@arcgis/core/form/elements/inputs/ComboBoxInput`, where there is next to no configuration available?
