Get tab name onclick
3963
8
03-31-2022 05:39 PM
LefterisKoumis
Using the tabs and wondering of how to capture the title of the tab when it's clicked on.
Tried:
 document.querySelector("calcite-tab-title").addEventListener("click", handleActionBarClick1);
BenElan
Esri Alum
BenElan
Esri Alum
Calcite Components have custom events which you can find on their doc page. For example, here is the event for `calcite-tab-title`:
https://developers.arcgis.com/calcite-design-system/components/tab-title/#component-api-events
calcite-tab-nav also has an event:
https://developers.arcgis.com/calcite-design-system/components/tab-nav/#component-api-events-calcite...
LefterisKoumis
Thanks.
I setup id:
<calcite-tab-nav slot="tab-nav" id="thetabs">
//then wanted to capture the event:
const controlTabs = document.getElementById("thetabs")
  controlTabs.addEventListener("calciteTabChange", async (event) => { console.log(event.target.value) });
When you click the first tab it works. but when you click the other tabs it return undefined.
BenElan
Esri Alum
The event's callback function doesn't need to be async in your code snippet. Also, the tab info is event.detail.tab. Here is the code:
document.addEventListener("calciteTabChange", (event) => console.log(event.detail.tab));
BenElan
Esri Alum
Wittawat
@BenElan could you please share the code with calcite v1.0.7? It seems like the event.detail.tab did not work with new version.
LefterisKoumis
Since version 1.0.3 the event.detail.tab is depreciated.
See:
https://github.com/Esri/calcite-components/blob/master/CHANGELOG.md
use instead:
event.target.selectedTitle
Wittawat
Thank you for your reply. I've tried the event.target.selectedTitle but I have received an incorrect tab name.
Please kindly see the example herehttps://codepen.io/aonwittawat/pen/vYzZozd
LefterisKoumis
There are current issues with the selectedTitle as acknowledged by ESRI.
Please use this instead.
https://codepen.io/lkoumis1/pen/GRXEwyN?editors=1111
