Can a Calcite panel slide open?
1455
09-12-2023 12:11 PM
Labels (2)
Trippetoe
Hello.
Is there an option/property that would cause a Calcite panel to slide open/closed more 'gracefully' rather than the more abrupt transition that it makes now? And is there a option/property that would cause the panel to slide over a map rather than pushing the map to the side when the panel opens?
Even in the Esri Map Viewer, for example the Properties Panel, the map is pushed to the left when the panel is opened (and back to the right when the panel is closed). Its a bit visually startling to be looking at one place on the map and then have the map get pushed over (and eye have to move and refocus) when opening / closing a panel.
Thank you.
Tags (3)
KittyHurley
Thanks for posting in Calcite's Community, a global community of Esri users where you can find solutions, share ideas, and collaborate with others.
This is a great topic to submit a case to Esri Support, where you can report bugs in released versions of Calcite and request enhancements. Submitted cases help you troubleshoot issues, provide tracking progress of bugs, and help build cases to help prioritize enhancements requests.
Learn more about submitting cases, including how to become an authorized caller to report an issue.
LefterisKoumis
I had the opposite issue. I was trying for the side panel to push over the map rather that overlay it.
https://community.esri.com/t5/calcite-design-system-questions/calcite-shell-needs-content-behind-to-...
