Calcite Input display character count
1003
10-09-2024 11:07 AM
AudreyWatson
I've looked around and could only information related to the text area component regarding character count. Is there not a way to show character count for normal text input components?
Mac_And_Cheese
The character count visual affordance is built into Text Area as the component provides additional UI surface around the input area for display.
While this isn't built-in to Input components, it is simple to determine the character count using events.
In the case of Input Text, you can listen for either the `calciteInputTextInput` or `calciteInputTextChange` event to fire, and use the resultant value to populate your UI as needed:
Calcite Input Text Event Count
Mac_And_Cheese
