calcite-block disablePadding deprecated
1366
10-07-2022 11:24 AM
GregoryBologna
How do I use --calcite-block-padding to remove padding on block?
disablePaddingdisable-padding
deprecated
Use --calcite-block-padding CSS variable instead.
Here's my code
let block = document.createElement('calcite-block');
block.setAttribute('id', 'pao-accordion-block');
block.setAttribute('heading', 'Buffer Results');
block.setAttribute('description', ' '); // populated on table update
block.setAttribute('collapsible', '');
block.setAttribute('open', '');
block.addEventListener(
	'calciteBlockToggle',
	toggleAccordionBlockDescription
KittyHurley
Hi @GregoryBologna, you can set the CSS variable on the component:
calcite-block {
  --calcite-block-padding: 0rem;
For setting the CSS variable using JavaScript, can use properties:
block.style.setProperty("--calcite-block-padding", "0rem");
There is a new documentation page on web concepts that includes some guidance on CSS variables releasing this week. Will post an update when the page is available.
KittyHurley
calcite-block {
KittyHurley
Hi @GregoryBologna , we added a new page to the Calcite’s ArcGIS Developers Site around web concepts.
Since we've had a few conversations around a few web component concepts, wanted to share some more in-depth details – if interested in exploring some of the terms further.
