Avatar as icon for Action
1143
01-11-2024 11:33 AM
BjornKuiper
Is there a way to set the icon property of an Calcite Action to be an Calcite Avatar?
If not, how do you center/position it similar as the Calcite Actions and make the Calcite Avatar clickable in a CalciteActionBar / CalciteActionGroup?
This is what i have now, but the Calcite Avatar is not behaving similar as an Calcite Action and not aligned correctly:
Thanks!
KittyHurley
@BjornKuiper At this time this is not a supported feature.
There are some potential approaches to consider as part of the workflow, such as:
  1. Using the "user" icon in an Action's "action-end" slot, also containing a tooltip with Avatar: https://codepen.io/geospatialem/pen/wvOpbrr
  2.  Using CSS styling to adjust the "actions-end" slot containing the Avatar when the Action Bar is collapsed/expanded: https://codepen.io/geospatialem/pen/dyrdBwV
  3. Consider using the Navigation "user" slot with Navigation User for Avatar: https://codepen.io/geospatialem/pen/KKEQOMd
BjornKuiper
Thank you for your time responding. I moved forward with a CalciteAction:
<CalciteAction data-action-id="user" text="User" compact alignment='center'>
<span>
  <CalciteAvatar slot='image' fullName='Lorem Ipsum' scale='m'></CalciteAvatar>
</span>
</CalciteAction>
