Angular and Calcite elements
3478
06-22-2023 07:18 AM
Robert_van_Gilst
I love the simplicity of Angular, where it is possible to seperate the logic from the UI. But at the moment I am struggeling to find a good way to implement some of Calcites elements into my Angular solution. For instance the combobox element.
// Simplified example
export class MyComponent {
   allLayers: string[] = ['a', 'b', 'c', 'd', 'e', 'f']
   selectedLayers: string[] = ['a', 'f']
<!-- Component -->
<calcite-combobox placeholder="Select a field" [value]="selectedLayers">
  <calcite-combobox-item *ngFor="let item of allLayers" [value]="item" [textLabel]="item"></calcite-combobox-item>
</calcite-combobox>
I can populate the items in the component but not the selected layers.
I can respond to the change in selection responding like [calciteComboboxChange)="CalciteComboboxChange($event)and update the selectedLayers variable. But I would love to have a possibility to use two-way binding like this [(value)]="selectedLayers".
I know I can use [selected]="true" on the elements, but then it does not keep the order in which the elments were selected.
BTW.: It is also annoying when selecting one element, it sends just the element and more than one an array.
KittyHurley
Hi @Robert_van_Gilst This is inherit to web components, where the Combobox attributes don't automatically get mapped until the element is defined.
To set the elements you can either check the attribute, or wait for the element to be defined and the component is loaded.
For instance:
  1. Codepen sample
  2. Codesandbox sample with @angular and @ionic/pwa-elements:
KittyHurley
For instance:
  1. Codepen sample
Robert_van_Gilst
Thank you @KittyHurley this helped. 😊
But unfortunately it breaks the angular way of working of separating the UI and code complete. I rather have no references to components in my code. So I probably have create some wrapper components in my solution, to get me past this inconvenience.
Or is your team also working on a Angular Components implementation 🙏
KittyHurley
Good to hear the above resources were helpful!
Calcite is working towards an Angular wrapper in the near future, so there will be additional support coming soon.
ForrestLin
When will Angular wrapper be ready to use? I'm working on a project using Angular with Calcite components right now.
Robert_van_Gilst
Hi @KittyHurley that sounds great with an Angular wrapper. What means "in the near future"? I hope weeks, but that is probably wishful thinking 😄
