Best way to export an AutoCAD map into ArcGIS?
1437
10-29-2020 06:28 PM
WilliamMcConihe
Looking for the best way to export an AutoCAD map with 20+ layers into ArcGIS 10.7.
KarenHodge
Hi William.  The answer depends on what you want to do.  ArcGIS 10.7 can read your AutoCAD drawing natively.  There is also a tool, Cad to Geodatabase that will populate a geodatabase from all the supported content in your drawing.  Hope this helps.
