Using Validation Rules to Ensure Proper Association of Assets in Utility Network
2059
05-17-2023 05:57 AM
StefanAngerer
Hi everyone,
I'm currently working with a utility network in ArcGIS Pro (Enterprise GDB), and I'm wondering if anyone has experience using validation rules to validate newly created assets and ensure they are properly associated with different assets.
For example, I'd like to validate whether an asset is contained in a structure or connected to line assets. I'm interested in hearing from anyone who has attempted this type of validation using validation rules, and any tips or resources you might be able to share.
Thank's in advance for all the help you can offer!
Stefan
TedHoward2
There are some validation rules in Utility Network Foundation Solutions that are similar. For example we have a rule named "Validate Network Distance" used to detect associated features that are too far apart (a Device should not be contained in an Assembly that is two miles away).
Electric Utility Network Foundation
Communications Utility Network Foundation
Here is a sample that may give you a starting point.
// Assigned To: ElectricDevice
// Type: Validation
// Name: Validate Network Distance-ED
// Description: Validate $feature is within allowable distance from associated features
// Subtypes: All
// Exclude From Client: True
// *************       User Variables       *************
// This section has the functions and variables that need to be adjusted based on your implementation
Expects($feature, 'assetgroup');
// The allowable distance value a feature can be from container
// ** Implementation Note: Adjust this value based on the distance
var distance_check = 100;
// The unit of the distance value in distance_check
// ** Implementation Note: Options for Unit of Measure: https://developers.arcgis.com/arcade/function-reference/geometry_functions/#units-reference
var unit_of_measure = "feet";
// Optionally limit rule to specific asset groups.
// ** Implementation Note: Add to list to limit rule to specific asset types. If not specified, will be ignored.
var asset_group = $feature.assetgroup;
var valid_asset_groups = [];
// Association type to check.
// ** Implementation Note: Associated features will only be considered if association type is listed here.
var assoc_types = ["content", "container", "attached", "structure"];
// ************* End User Variables Section *************
// *************       Functions            *************
// monikerize FeatureSetByName function
var get_features_switch_yard = FeatureSetByName;
function get_container_feature_ids(feature, assoc, spatial_only) {
    // Function to get UN associated container feature id
    // feature(Feature): A feature object used to lookup associations
    var associated_ids = {};
    // Query to get all the content associations
    var associations = FeatureSetByAssociation(feature, assoc);
    // loop over all associated records to get a list of the associated classes and the IDs of the features
    for (var row in associations) {
        // Skip Non Spatial features
        if (spatial_only && (Right(Lower(row.className), 6) == 'object'))
            continue;
        if (!HasKey(associated_ids, row.className)) {
            associated_ids[row.className] = [];
        push(associated_ids[row.className], row.globalId);
    //return a dict by class name with GlobalIDs of features, if empty, return empty dict
    return associated_ids;
// ************* End Functions Section ******************
// Limit the rule to valid asset groups
if (Count(valid_asset_groups) > 0) {
    if (!Includes(valid_asset_groups, asset_group)) {
        return true;
// Get global IDs of any associated features outside allowable distance from feature
var distance_errors = {};
for (var idx in assoc_types) {
    // Get objectids of associated features
    var associated_ids = get_container_feature_ids($feature, assoc_types[idx], true);
    for (var class_name in associated_ids) {
        var feature_set = get_features_switch_yard($datastore, class_name, ['globalID'], true);
        var global_ids = associated_ids[class_name];
        var features = Filter(feature_set, "globalid in @global_ids");
        for (var feat in features) {
            // Distance measures shortest distance between two geometries, including edges
            if (Distance($feature, feat, unit_of_measure) > distance_check) {
                if (!HasKey(distance_errors, assoc_types[idx])) {
                    distance_errors[assoc_types[idx]] = [];
                push(distance_errors[assoc_types[idx]], feat.globalid);
// build error message and return
var mess = '';
for (var assoc_t in distance_errors) {
    mess += `Feature is outside allowable distance from ${assoc_t}(s): ${Concatenate(distance_errors[assoc_t], ", ")} `
if (mess != '') {
    return {"errorMessage": mess}
return true;
TedHoward2
// Type: Validation
// Subtypes: All
            continue;
        return true;
var mess = '';
if (mess != '') {
return true;
StefanAngerer
@TedHoward2
Thanks for the help! I think this is a good starting point for my work.
