Update Line Z Values
1637
07-12-2024 05:40 AM
Justin_CLT
I am using the Utility Network and need a rule to change the Z value of each vertex in a line depending on the lifecycle status. I already wrote a rule for devices and it is working, but nothing I've tried for the lines is working. I am including the expression used for point features (devices). Could someone help with how to adapt this for line features?
// This rule updates the Z value of features based on the lifecycle status
var lcs = $feature["lifecyclestatus"];
// Create a copy of the feature's geometry
var newGeom = Geometry($feature);
var newZ;
// Update the Z value based on lifecycle status
// Domain values: proposed = 1, in service = 8, out of service = 256, abandoned = 32
if (lcs == 1) {
    newZ = 1;
} else if (lcs == 8 {
    newZ = 0;
} else if (lcs == 256) {
    newZ = -1;
} else if (lcs == 32) {
    newZ = -2;
} else {
    newZ = 0;
// Create a new geometry with updated Z value
var updatedGeom = Point({
    "x": newGeom.x,
    "y": newGeom.y,
    "z": newZ,
    "spatialReference": newGeom.spatialReference
// Return the updated geometry
return updatedGeom;
Justin_CLT
I got it to work for lines using the following expression:
// This rule updates the Z value of linear features based on the lifecycle status
var newPaths = [];
var newZ;
if (lcs == 1) {
newZ = 5;
newZ = 0;
newZ = -5;
newZ = -10;
} else {
newZ = 0;
// Iterate through each part of the polyline
for (var i = 0; i < Count(newGeom.paths); i++) {
var path = newGeom.paths[i];
var newPath = [];
// Iterate through each vertex in the part
for (var v = 0; v < Count(path); v++) {
var point = path[v];
// Create a new point with updated Z value and original X and Y coordinates
var newPoint = [point.x, point.y, newZ];
// Add the new point to the new path
Push(newPath, newPoint);
// Add the new path to the new paths array
Push(newPaths, newPath);
// Create a new polyline with updated Z values
var updatedGeom = Polyline({
"paths": newPaths,
return updatedGeom;
MikeMillerGIS
Esri Frequent Contributor
Geometry is immutable, so convert to dictionary
var p = Polyline(
    paths: [
        [-97.06138, 32.837, 0],
        [-97.06133, 32.836, 0],
        [-97.06124, 32.834, 0],
        [-97.06127, 32.832, 0]
    hasZ: true,
    spatialReference: { wkid: 3857 }
console(p);
var p_z = Dictionary(p)
for(var i in p_z['paths']){
  for(var j in p_z['paths'][i]){
    p_z['paths'][i][j][2] = 50
return Polyline(p_z)
Justin_CLT
var newPaths = [];
var newZ;
if (lcs == 1) {
newZ = 5;
newZ = 0;
newZ = -5;
newZ = -10;
} else {
newZ = 0;
var newPath = [];
"paths": newPaths,
return updatedGeom;
Bud
Legendary Contributor
