Attribute Rule to auto-populate a field based on another field in the same feature class
2359
06-12-2024 06:02 AM
SuzyFer
I am attempting to auto-populate a field with a calculation (?) attribute rule, based on another field in the same feature class, could someone help me figure this out please? Being fairly new to arcade.
I have 4 different fields containing habitat information and a main habitat field, for example:
level 1, level 2, level 3, level 4, & habitat.
Not all levels will be populated necessarily, so I would like the habitat field to auto-populate with the value based on which one of these levels is populated. So for example, if level 4 is empty - I want to check if level 3 has a value. If so, auto-populate with that. If level 3 is empty, check level 2 for a value and use that, but again if empty, use the value from level 1.
Thanks!
Jake_S
by Esri Contributor
Hey @SuzyFer !
There are other ways you can do this but this is the most simplistic.
var level4 = $feature.level4;
var level3 = $feature.level3;
var level2 = $feature.level2;
var level1 = $feature.level1;
var result;
if (!IsEmpty(level4)) {
  result = level4;
} else if (!IsEmpty(level3)) {
  result = level3;
} else if (!IsEmpty(level2)) {
  result = level2;
} else if (!IsEmpty(level1)) {
  result = level1;
return result;
(view in My Videos)
Hope this helps.
~Jake
Jake_S
by Esri Contributor
Hey @SuzyFer !
var result;
  result = level4;
  result = level3;
  result = level2;
  result = level1;
return result;
(view in My Videos)
Hope this helps.
~Jake
SuzyFer
This is great, thank you! 🙂 Works perfectly.
