(Potential) Bug Report - Inconsistent Triggering of Update Processes
585
05-31-2023 04:02 AM
StefanAngerer
Hello Esri community,
I hope you are all doing well. I recently encountered a bug while working with an attribute rule on a point feature class, and I wanted to reach out to the forum to see if anyone else has experienced a similar issue or if I am potentially making a mistake that I haven't been able to identify yet.
The purpose of my script is to add vertexes to a line feature when it intersects with specific point features. To assist in debugging and determining if the script is triggered during update processes, I inserted an error message to check for its execution. To my surprise, I discovered that the script is not triggered when I attempt to move an existing point feature around.
Upon further investigation, I observed the following behavior, which might help in diagnosing the issue:
  1. Updates are triggered when attempting to move long-existing features.
  2. Updates are not triggered when inserting a new feature and subsequently moving it around. Strangely, after this process, I can freely move all other point features, which should not be possible.
I'm having difficulty pinpointing the exact cause of this behavior and determining if I have made a mistake in my script or if this really is an esri bug. I would greatly appreciate any assistance or insights that you can provide.
Thanks and kind regards,
Stefan
This was the script + return error i used:
// This was added to check if the rule is even triggerd, with this statement i found the potential bug.
return {"errorMessage": "triggered2"};
// get intersecting line features
var lines = FeaturesetByName($datastore, "PipelineLine", ["GlobalID"], true);
var i_lines = Intersects(lines, $feature);
if (isEmpty(i_lines)) {
    return {"errorMessage": "didnt find intersecting line"};
// create update variable
var updates = [];
// get distances from start and end point
for (var line in i_lines) {
    return {"errorMessage": "got line geo" + Text(Geometry(line))};
    var line_geo = Geometry(line);
    var point_geo = Geometry($feature);
    var d_start = Distance(point_geo, line_geo.paths[0][0]);
    var d_end = Distance(point_geo, line_geo.paths[-1][-1]);
    // get the new point coordinates: x/y from the closest line end point, z from the point
    var i = IIf(d_start < d_end, 0, -1);
    var v = [line_geo.paths[i][i].x, line_geo.paths[i][i].y, point_geo.z, null];
    for (var k = 0; k < Count(line_geo.paths[i]); k++) {
        if (line_geo.paths[i][k].x == v[0] && line_geo.paths[i][k].y == v[1] && line_geo.paths[i][k].z == v[2]) {
             return;
    // add vertex at start or end of line
    var new_line_geo = Dictionary(Text(line_geo));
    var j = IIf(i == 0, 0, Count(new_line_geo.paths[0]));
    Insert(new_line_geo.paths[0], j, v);
    var update = {
        "globalID": line.GlobalID,
        "geometry": Polyline(new_line_geo)
    Push(updates, update);
return {
    edit: [{
        "className": "PipelineLine",
        "updates": updates
