How to debug attribute rules that don't have errors (console messages not supported)
1268
03-31-2022 08:41 AM
Bud
Legendary Contributor
I have a calculation attribute rule that runs without errors, but doesn't work as expected:
Attribute rule works in Pro 2.9.2, but not in Pro 2.6.8
I want to debug the code, to see what part of it is failing to update the geometry's vertices.
  • The code doesn't produce any errors, so I can't use error messages to help me.
  • And ArcGIS Pro 2.6.8 doesn't support outputting console messages (unlike Pro 2.9.2 +/-).
Does anyone have any tips for debugging Arcade code in that scenario?
Tags (1)
Jake_S
by Esri Contributor
Bud,
I believe you can use the error message to your advantage. If the code has an expected return value you can use it to print the value as text.
return{
    "errorMessage": Text()
Although this may not work if the rule you have is doing something geometry-related.
~Jake
