getUser function Error Failed to query url
2006
07-28-2022 11:46 AM
Jake_S
by Esri Contributor
Has anyone worked with the getUser Arcade Function to return the current user name and Control Editing Access?
When using the Arcade Portal() function I get the following error.
I can copy and paste that URL into the browser of the environment and access the Portal.
Any thoughts? Below is the code, it's a very basic constraint rule copied from the video here the URL and group name are the only things switched out.
//if the edit is on defualt we need to check the suer group
var p =  Portal("https://[[portal name]].com/portal");
//get the user full object
var u = getUser(p);
//get the user groups
var groups = u.groups
//if the user is in the SuperEditor group allow the edit
if (Find("Default Editors",groups) > 0) {
     return true //allow edit
return false //fail edit
Tags (1)
2 Solutions
Jake_S
by Esri Contributor
UPDATE:
This is a known bug introduced in 10.9.1 and is scheduled to be fixed in a future patch.
HusseinNasser2
Bug can be tracked here BUG-000151193
Jake_S
by Esri Contributor
UPDATE:
HusseinNasser2
Jake_S
by Esri Contributor
Thank you sir!
