Generate Unique Sequence Number
958
08-09-2024 05:39 AM
vijaybadugu
I would like to write an Arcade expression to generate a unique next sequence number in a feature class. which needs to compare two feature classes and generate unique number which is not included in either of feature classes.
MikeMillerGIS
Esri Frequent Contributor
You can use Max on a featureset, this would get you the highest number in each class, and then increment by one
https://developers.arcgis.com/arcade/function-reference/featureset_functions/#max
vijaybadugu
Is there way to list all field values, display in console and pass them to array ?
