Failing to copy date in Address Data Management Solution's Split Intersecting Road attribute rule
1262
03-13-2025 12:57 PM
John_S
In the Address Data Management solution, Road Centerlines feature class, Split Intersecting Roads attribute rule (I'm using version 2.1 of the solution, before you could use the Split tool on RCL features), when you draw in a new road, it splits intersecting road features and re-ranges them, copying all relevant attributes into the new segment created by the split.  This works with the schema provided.
However, I added a new date field called "Test" to the Road Centerline feature class and then add that same field into the rule, so it's value should be copied into new features upon splitting.  When this new date field is empty, the attribute rule still runs just fine as expected.  However, if I populate that field with a date and then try splitting the feature by drawing in a new intersecting road, the attribute rule fails with an error "Return type is not compatible with field type."
I know there are a lot of peculiarities in working with dates in many languages but I can't figure out what exactly may be the issue or how to fix it in Arcade... So, if anyone has thoughts on how to get this rule to copy over the date field value in the split, I'd love to hear it.
The full rule is:
// This rule will split intersecting roads at their intersection and the address ranges will be updated to reflect where the split occured
// Define the Road Centerline fields
var centerlineid_field = "centerlineid";
var precenterlineid_field = "precenterlineid"
var fromleft_field = "fromleft";
var fromright_field = "fromright";
var toleft_field = "toleft";
var toright_field = "toright";
//Define any fields to be copied from the centerline when split (lower case)
var centerline_field_names = ["rclnguid", "discrpagid", "rangeprefixleft", "fromleft", "toleft", "parityleft", "rangeprefixright", "fromright", "toright", "parityright", "fullname", "fedroute", "fedrtetype", "afedrte", "afedrtetype", "stroute", "strtetype", "astrte", "astrtetype", "ctyroute", "onewaydir", "roadlevel", "inwater", "roadclass", "countryleft", "countryright", "stateleft", "stateright", "countyleft", "countyright","munileft", "muniright", "zipleft", "zipright", "msagleft", "msagright", "esnleft", "esnright","test"]
// Check if the line feature is used to manual split the intersecting road and not be added to the layer
// Otherwsie don't run the rule if the road was added by this rule from a previous insert
var manualSplit = false;
if (!HasKey($feature, precenterlineid_field)) return;
if ($feature[precenterlineid_field] == "Manual Split") {
    manualSplit = true;
else if (!IsEmpty($feature[precenterlineid_field]))
    return;
// Get the global id and geometry from the road
var globalid = $feature.globalid;
var geom = Geometry($feature);
var adds = [];
var updates = [];
var deletes = [];
var segments = [];
// This function calculates a new from and to address based on the percentage along the line the split occurs
function newToFrom(from, to, percent) {
    if (from == null || to == null) return [null, null];
    var range = Abs(to - from);
    if (range < 2) return [from, to];
    var val = percent * range;
    var newVal = 0;
    if ((Floor(val) % 2) == 0) newVal = Floor(val);
    else if ((Ceil(val) % 2) == 0) newVal = Ceil(val);
    else newVal = Floor(val) - 1;
    if (newVal == range) newVal -= 2;
    if (from > to) return [from - newVal, from - newVal - 2];
    else return [from + newVal, from + newVal + 2];
// This function splits a road using another road and returns an array of 2 geometries
// If a valid split does not occur it returns null
function splitRoad(road, splitRoad) {
    // Cut the intersecting road and return if the result of the cut is less than 2 features
    var newRoads = Cut(road, splitRoad);
    if (Count(newRoads) < 2) return;
    var validCut = true;
    var geometries = []
    // Loop through collection of lines and check that it was a valid cut in the middle of a segment
    for (var i in newRoads) {
        if (newRoads[i] == null || Length(newRoads[i]) == 0) {
            validCut = false;
            continue;
        // Handle multipart geometries
        var allParts = MultiPartToSinglePart(newRoads[i]);
        for (var p in allParts) {
            Push(geometries, allParts[p]);
    // Process the cut if valid
    if (validCut) {
        var firstGeometry = null;
        var secondGeomArray = [];
        var firstPoint = road.paths[0][0];
        // Loop through each geometry in the cut
        // Store the geometry including the first vertex of the orginal road as the first geometry
        // Collect all other geometries in an array
        for (var i in geometries) {
            if (Equals(firstPoint, geometries[i].paths[0][0])) {
                firstGeometry = geometries[i];
            } else {
                Push(secondGeomArray, geometries[i]);
        // Merge all other geometries as the second geometry
        var secondGeometry = Union(secondGeomArray);
        return [firstGeometry, secondGeometry];
    return;
// This function breaks the feature at all intersections with other roads in the dataset and populates an array of geometries
function breakRoadAtIntersections(geom, intersectingRoads) {
    // Test if a split occured
    var splitOccured = false;
    for (var i in intersectingRoads) {
        var geometries = splitRoad(geom, intersectingRoads[i]);
        if (IsEmpty(geometries)) continue;
        // If the two geometries are returned from the split process each to see if the can be split again
        splitOccured = true;
        breakRoadAtIntersections(geometries[0], intersectingRoads);
        breakRoadAtIntersections(geometries[1], intersectingRoads);
        break;
    // If no split occured add the geometry to the segments array
    if (!splitOccured) {
        Push(segments, geom);
var intersectingRoads = []
for (var road in Intersects(FeatureSetByName($datastore, "RoadCenterline"), geom)) {
    if (globalid == road.globalid || Equals(geom, Geometry(road))) continue;
    Push(intersectingRoads, road);
if (manualSplit) {
    Push(deletes, {'globalID': globalid})
else {
    breakRoadAtIntersections(geom, intersectingRoads);
for (var i in segments) {
    // Update the geometry of the original feature to be the first segment from the array
    if (i == 0) {
        geom = segments[i];
    else {
        // Store an add for a new road for each additional segment and copy the attributes from the original feature
        var featureAttributes = Dictionary(Text($feature))['attributes'];
        var newAttributes = {};
        for (var k in featureAttributes) {
            if (IndexOf(centerline_field_names, Lower(k)) > -1 && featureAttributes[k] != null) {
                newAttributes[k] = featureAttributes[k];
            } else {
                continue;
        // Update the precenterlineid field attribute so this rule is not re-run for this new segment
        newAttributes[precenterlineid_field] = "New";
        Push(adds, {
            'attributes': newAttributes,
            'geometry': segments[i]
// Split the roads using the new feature segments
for (var r in intersectingRoads) {
    var road = intersectingRoads[r];
        var geometries = splitRoad(Geometry(road), segments[i]);
        var firstGeometry = geometries[0];
        var secondGeometry = geometries[1];
        // Get the address range of the intersecting road
        var fromRight = road[fromright_field];
        var toRight = road[toright_field];
        var fromLeft = road[fromleft_field];
        var toLeft = road[toleft_field];
        // Calculate the new address ranges based on the intersection location along the line
        var geometryPercent = Length(firstGeometry, 'feet') / (Length(firstGeometry, 'feet') + Length(secondGeometry, 'feet'));
        var newToFromLeft = newToFrom(fromLeft, toLeft, geometryPercent)
        var newToFromRight = newToFrom(fromRight, toRight, geometryPercent)
        // Store an update for the intersecting road with the first geometry from the cut and the new right to and left to value
        var attributes = {}
        if (newToFromRight[0] != null) attributes[toright_field] = newToFromRight[0];
        if (newToFromLeft[0] != null) attributes[toleft_field] = newToFromLeft[0];
        Push(updates, {
            'globalID': road.globalid,
            'attributes': attributes,
            'geometry': firstGeometry
        // Store an add for a new road with the second geometry from the cut and the new right from and left from value
        var featureAttributes = Dictionary(Text(road))['attributes'];
            if (Lower(k) == fromright_field && newToFromRight[1] != null) {
                newAttributes[fromright_field] = newToFromRight[1];
            } else if (Lower(k) == fromleft_field && newToFromLeft[1] != null) {
                newAttributes[fromleft_field] = newToFromLeft[1];
            } else if (IndexOf(centerline_field_names, Lower(k)) > -1 && featureAttributes[k] != null) {
            } else {
                continue;
        newAttributes[precenterlineid_field] = road[centerlineid_field];
        Push(adds, {
            'geometry': secondGeometry
        break;
// Using the edit parameter return the list of updates and adds for the split roads and add alias names
return {
    "result": {
        "geometry": geom
    'edit': [
        {'className': 'RoadCenterline', 'adds': adds, 'updates': updates, 'deletes': deletes}
};$feature.TEST
TedHoward2
I would point you to lines 145 and 195. Calling Text() on a feature converts date attributes to text which can't be easily converted back. If you are on Pro 3.2 or above you can simply call Dictionary($feature) and dates will be preserved.
// line 145
var featureAttributes = Dictionary($feature)['attributes']
//line 195
var featureAttributes = Dictionary(road)['attributes']
MikeVolz
Are there various formats for a Date field and the custom date field you created is not in the same format as the date fields that are part of the default solution?
John_S
The default solution doesn't include any date fields of any type copied over by this attribute rule.  The documentation for the solution contemplates being able to add your own additional fields that would be handled by this rule, but doesn't give any specifics if that custom field would happen to be a date field.
And I'm simply trying to add a traditional Date field (the field type that is a carry over from ArcMap and stores Date & Time with no time zone/UTC offset info).
TedHoward2
// line 145
//line 195
John_S
Thank you so much for this.  I'm honestly not sure how many times I read through the solution's rule trying to find a cause and completely missed that Text().
This should probably get shared with the ArcGIS Solutions team responsible for the Address Data Management solution as it appears from what I can see that even more recent releases of that solution still include this issue and would benefit from this fix.
Thanks again!
