Error "The evaluation of attribute rules is cyclic or exceeds maximum cascading level"
411
6
05-13-2025 02:52 AM
GeeteshSingh07
I am working on attribute rule. It is applied on two feature classes:
1. Main_FC
2. FC_Anno
The attribute rule on Main_FC is triggered on 'Update'. The rule is:
var globalId = $feature.GLOBALID;
var attach_anno = FeatureSetByName($datastore, "FC_Anno", ["FEATUREGLOBALID", "GLOBALID"], true);
var related_feature_anno = Filter(attach_anno, "FEATUREGLOBALID = @globalId");
if (related_feature_anno != null) {
    var updates = [];
    for (var f in related_feature_anno) {
        Push(updates, {
            'globalId': f.GLOBALID,
            'attributes': {
                'NAME': $feature.NAME
    return {
        'edit': [{
            'className': 'FC_Anno',
            'updates': updates
The attribute rule on FC_Anno is triggered on 'Insert & Update'. The rule is:
var fglobalId = $feature.FEATUREGLOBALID;
var main_fc = FeatureSetByName($datastore, "Main_FC", ["GLOBALID"], true);
var related_main_fc = Filter(main_fc, "GLOBALID = @fglobalId");
if (related_main_fc != null) {
    var updates = [];
    for (var f in related_main_fc) {
        Push(updates, {
            'attributes': {
    return {
        'edit': [{
            'className': 'Main_FC',
            'updates': updates
The attribute rule works fine if I disable any one of them. When both of them are enabled together, it gives an error: The evaluation of attribute rules is cyclic or exceeds maximum cascading level.
I looked into some of community discussions & solutions suggested by @HusseinNasser2 , and I understand when one feature is edited, it triggers the rule on the other class, which again edits the first class, triggering the rule again... and so on. This causes a cyclic dependency, which leads to the cascading evaluation error. However, I am still struggling to resolve this issue.
Any help on this will greatly be appreciated. Thank you.
Best Regards,
Geetesh
geetesh486@gmail.com
MikeMillerGIS
Esri Frequent Contributor
You need to check if each row has the same name.    Try this:
var main_fc = FeatureSetByName($datastore, "Main_FC", ["GLOBALID", "NAME"], false);
var updates = [];
    if ($feature.NAME == f.NAME){
      continue;
    Push(updates, {
        'attributes': {
if (Count(updates) == 0 ){
    return
return {
    'edit': [{
        'updates': updates
* Edited code, no reason to return Geometry and also needed to add NAME to the FeatureSetByName constructor
MikeMillerGIS
You need to add a check in each that if $feature.NAME == f.NAME, do not update it and exclude it from the return edit payload
GeeteshSingh07
Thank you @MikeMillerGIS for the suggestion. I tried this, it gives no error but also doesn't update the field. May be because I added return statement inside the for loop now?
    var updates = [];
        Push(updates, {
            'attributes': {
If ($feature.NAME == f.NAME ) {
return}
Else{
    return {
        'edit': [{
            'updates': updates
Best Regards,
Geetesh
MikeMillerGIS
var updates = [];
      continue;
    Push(updates, {
        'attributes': {
    return
return {
    'edit': [{
        'updates': updates
GeeteshSingh07
@MikeMillerGIS , unfortunately, it still doesn't work. It doesn't update now. In my original code, I have 4 fields such as NAME, NAME1, NAME2, NAME3. I have added all of them in FeatureSetByName constructor . Also, in attributes section & IF block:
    if ($feature.NAME == f.NAME || $feature.NAME1 == f.NAME1 || $feature.NAME2 == f.NAME2 || $feature.NAME3 == f.NAME3){
      continue;
Best Regards,
Geetesh
GeeteshSingh07
I was able to resolve the update-related issue. @MikeMillerGIS ,
I think the issue was with '||'. It works when I use '&&' function in IF. I should have mentioned it before...
Thank you so much 😄 for helping me in resolving this error. I really appreciate your help.
Best Regards,
Geetesh
Best Regards,
Geetesh
MikeMillerGIS
You still should only change the name field when it is different.  So you should look at doing it this way:
// Need the expects as we are accessing attributes via variable key, this tells the code to retrieve these fields
Expects($feature, "NAME","NAME1","NAME2","NAME3");
var name_fields = ["NAME","NAME1","NAME2","NAME3"];
var main_fc = FeatureSetByName($datastore, "Main_FC", ["GLOBALID", "NAME","NAME1","NAME2","NAME3"], false);
var updates = [];
    var atts = {}
    for (var i in name_fields){
        var name_field = name_fields[i];
        if ($feature[name_field] == f[name_field]){
            continue;
        atts[name_field] = $feature[name_field];
    // IsEmpty does not work on dicts, so convert to text to see if empty
    if (text(atts) == '{}'){
        continue;
    Push(updates, {
        'attributes': {
    return;
return {
    'edit': [{
        'updates': updates
