ArcGIS Pro Data Reviewer for Branch Versioned Service Updates Last Modified Date
1337
03-11-2025 11:45 AM
ShareUser
Esri Community Manager
Is there any Data Reviewer option for ArcGIS Pro that does not require updates to be made directly on the features in the the Enterprise Geodatabase? For example, in ArcMap, Data Reviewer writes errors to a file geodatabase and has no impact on the data in the Enterprise Geodatabase.
We recently migrated from ArcMap 10.8.1 to ArcGIS Pro 3.1.4 and updated our database to Branch Versioning. We have also added Calculation and Validation Attribute Rules to the database. We have been struggling with using Data Reviewer in ArcGIS Pro for many reasons, but a main reason is because running Evaluate Rules updates the Last Edited Date, Last User, and Validation Status for every record. Not only does this take a long time to process, but it overwrites all history of when the real last edits to the records were actually made. In addition to losing that history, some of our integrations utilize "Date Modified" to query only the latest edited records, but running Data Reviewer with Validation Attribute Rules updates the Date Modified of every feature.
My current understanding of Data Reviewer in ArcGIS Pro is you have 2 options:
  1. Validation Attribute Rules with the Evaluate Rules tool. This requires branch versioning, it adds a Validation Status field to each feature class that has an attribute rule, and running Evaluate Rules will update the Last Modified Date and Last User.
  2. Utilizing ArcMap Reviewer Batch Job files in Pro by creating reviewer sessions and running the execute reviewer batch jobs tool. This can only be run on the database, not a feature service, so you cannot run this on a branch versioned named version.
Are there any other options for data quality checks? Or any advice for utilizing Data Reviewer in ArcGIS Pro?
ShareUser
Just to confirm, this is the expected behavior when evaluating features using a validation attribute rule. The editor tracking info is updated whether the rule has been implemented using Arcade or a Data Reviewer check.
Would it be possible to get more info (either here or in a PM) on how this behavior is impacting the "integrations" you mentioned in your post? Would like to share this with the development team for discussion.
Thanks!
ShareUser
Sharing with Attribute rules board for awareness since the observed behavior is the same when using Arcade or Data Reviewer-based validation attribute rules.
ShareUser
Hi, my team is running into a similar issue. Did you find a workaround?
To answer the question asked by JayCary - we want the last edited field to reflect changes made to the shape or the 'important' attributes of a record. Important attributes being everything except the Validation Status field (which we don't use for anything). Updating the editor tracking every time we run Data Reviewer means that we lose a sense of recency and quality of our data, e.g. was this record last updated 10 years ago or 10 days ago?
ShareUser
I agree that this is not what I want from the "Evaluate Rules" command or from Data Reviewer.  ESRI's "expected behavior" is not good from the customer standpoint.
