Can a calculation rule update a record in the same feature class, same field, as the edited record?
2032
09-26-2023 11:49 AM
mfiegeeqt
For example, if a user edits the common_name for OID1, I want the attribute rule to additionally update the common_name for OID 2. Is this possible?
OIDcustom_idcommon_name
1"Group A""Name A"
2"Group A""Name A"
3"Group B""Name B"
4"Group B""Name B"
Bud
Legendary Contributor
I've wondered about this, too.
I posted it as an idea: When a feature is edited, update a different feature in the same FC
JohannesLindner
Yes, that is possible.
You just have to take precautions against infinite loops (feature 1 updates f2, which in turn updates f1, which then updates f2, etc).
// Calculation Attribute Rule on TestPoints
// field: empty
// Triggers: Update
// Exclude from application evaluation!
// get the old and new value
var old_value = $originalfeature.TextField1
var new_value = $feature.TextField1
// abort if value did not change
if(new_value == old_value) { return }
// get all features with the old value that aren't the current feature
var gid = $feature.GlobalID
var other_features = Filter(FeaturesetByName($datastore, "TestPoints"), "TextField1 = @old_value AND GlobalID <> @gid")
// create and fill an update array
var updates = []
for(var f in other_features) {
    Push(updates, {globalID: f.GlobalID, attributes: {TextField1: new_value}})
// instruct ArcGIS to update the other features
return {
    edit: [{
        className: "TestPoints",
        updates: updates
Before:
After refreshing the table:
Have a great day!
Johannes
Jake_S
by Esri Contributor
Any thoughts on this issue? Calculation works and does not work depending on number of features.
Seems this user is using your code and is running into an issue. I can replicate this issue.
@Aнастасия88
~Jake
Aнастасия88
Hi Jake, appreciate for your follow up regarding the problem that I have come across.
I still have not been able to figure out what the cause is. Hope someone will find a solution.
