Calculation rule for line cutting
1269
05-03-2022 01:35 PM
HNTZK46
Hello ESRI people,
I am thinking if it is possible to cut a line at the intersection of an inserted line.
It seems like we can achieve this by a point of point feature class for cutting a line of line feature class. But I am just wondering if we can do by only using a single line feature class, i.e. Both the target line and the inserted line are same feature class.
Thanks in advance!
Tags (1)
JohannesLindner
It should be possible. Something like this (completely untested!)
// Calculation Attribute Rule on LineFC
// Field: empty
// triggers: insert(, update)
// load the whole LineFC
var line_fs = FeatureSetByNAme($datastore, "LineFC", ["GlobalID"], true)
// get the intersecting lines
var intersect_lines = Intersects(line_fs, $feature)
// create and fill adds and deletes arrays
var adds = []
var deletes = []
for(var i_line in intersect_lines) {
    // get intersection geometry
    var i_geom = Intersection(i_line, $feature)
    // there are multiple conditions where we don't want to cut the line:
        // intersection isn't a point (overlapping lines or i_line == $feature)
        // i_line is intersecting $feature on start or end point
    if(i_geom.type != "Point" ||
       Equals(i_geom, Geometry(i_line).paths[0][0] ||
       Equals(i_geom, Geometry(i_line).paths[-1][-1] ) {
        continue
    // cut i_line with $feature, delete the original, add the cut parts
    var cut_parts = Cut(i_line, $feature)
    Push(deletes, {"globalID": i_line.GlobalID})
    for(var p in cut_parts) {
        Push(adds, {"geometry": cut_parts[p]})
// apply the edits
return {
    "edit": [
            "className": "LineFC",
            "adds": adds,
            "deletes": deletes
Have a great day!
Johannes
HNTZK46
Hi Johannes,
I applied your Arcade expression for a line feature class but unfortunately got an error, saying "Arcade error: Unexpected null, Script line: 20".
Unfortunately I don't know how to workaround this. If you could tell me any solution to this, that would be much appreciated.
JohannesLindner
Include a null check in the conditions:
    if(i_geom == null || i_geom.type != "Point" ||
        continue
Have a great day!
Johannes
